What's the correct air pressure? - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 5Likes
post #11 of 17 (permalink) Old 03-05-2019, 05:12 PM
ocramida's Avatar
Quoted: 292 Post(s)
Originally Posted by TampaBay6 View Post
Every little imperfection in the road feels like a hammer blow to the car. I'm dropping the pressure.
Actually I find dropping the pressure is worse for ride quality. Increasing pressure adds a bit more cushion. IMO
Your wheels are also exposed to more abuse.
ocramida is offline
post #12 of 17 (permalink) Old 03-05-2019, 06:52 PM
Archerfish's Avatar
Quoted: 168 Post(s)
Originally Posted by tickerguy View Post
Oh, and the added expense too; the tires, despite having LESS material in them always appear to cost more -- usually by a lot too.
This is true. The factory rim size is 19" and we don't have other trim choices in our place. The cost of a single tire is equivalent for a set of tires for our CR-V 98.
I was told that 18" and 20" tires are much cheaper and way easier to look for in stores. They said that 19" tires are somewhat rare. At least, here in our region this is true.
Going back to tire pressure, the door sticker indicates two pressure settings. One is for a fully loaded car and the other is when driving alone.
I decided to be in-between, the fully loaded pressure setting is too harsh for me while the other setting is too soft when a friend is with me from time to time. Since I lose tire pressure for a about 1 psi in a month or so (I believe this is normal, please correct me on this), I won't be below the recommended pressure by the time I check my tires and use my tire inflator.
If I may add, having a tire inflator saved me a lot of trouble back then. I got a punctured tire and I observed the harshness of the ride. I checked my tires and found out one of them is deflated. I used my tire inflator until I reached a vulcanizing shop.
One more thing, the gasoline station is quite far from us. If I were to drive there and have my tires filled up, my tires are already warm. I've read that the pressures indicated on the door sticker are cold tire pressures.
Archerfish is offline
post #13 of 17 (permalink) Old 03-05-2019, 09:14 PM
Quoted: 48 Post(s)
The two main items that change tire pressure are temperature and time.
Tires generally lose 1psi per month
Temperature changes are mirrored by tire pressure in a 10*F-1psi ratio; temperature gets 20* warmer and tires go up 2psi. If the temperature goes down 40* tires should drop 4psi.
On my car the door jam recommends 32psi cold.I check my tires when hot and have them set at 34F and 32R.
Them fancy tires TickerGuy runs only cost $52 a pop when you have an '03 6i with base 16" rims
Mad Myche is online now
post #14 of 17 (permalink) Old 03-05-2019, 11:08 PM
tickerguy's Avatar
Quoted: 946 Post(s)
Groans: 6
Groaned at 11 Times in 10 Posts
Yeah, and the 17" rim version isn't much more. There's plenty to like in a tire that does ok even on snow, is reasonably quiet, has great dry traction and runs 50k miles for about $75..... It doesn't matter much if you only put 10k miles on the car in a year, as they'll deteriorate before they wear out. When you do 30-40k miles in a year.....
TampaBay6 likes this.
tickerguy is online now
post #15 of 17 (permalink) Old 03-06-2019, 07:19 AM Thread Starter
TampaBay6's Avatar
Quoted: 25 Post(s)
I drive around very carefully. I'm not about slamming those Michelins into pot holes and dragging them over railroad tracks. They're the sweetest tires...
Dropped the pressure down to 31 back and 32 front. Did some highway and city driving last night and the ride was much more comfortable. Big difference.
2006 Mazda6, 3.0L v6, six speed auto (all stock, and loving it.)
TampaBay6 is offline
post #16 of 17 (permalink) Old 03-06-2019, 07:29 AM Thread Starter
TampaBay6's Avatar
Quoted: 25 Post(s)
What tire are we talking about?
post #17 of 17 (permalink) Old 03-06-2019, 09:55 AM
tickerguy's Avatar
Quoted: 946 Post(s)
Groans: 6
https://forum.mazda6club.com/wheels-...-15-sport.html
Similar Threads
New Water Pik Shower Head = Amazing Water Pressure!! dougefresh_ Lounge 9 06-28-2011 09:38 PM
Forge Bov mbjel Speed6 Engine/Drivetrain 9 09-24-2007 09:02 PM
AutoEnginuity DataLogger... Wiggum Mazdaspeed6 48 10-09-2006 04:34 PM
Some dyno graphs of my 05 6s 5speed bone stock, and with air box mod Sweet35th Dyno & Track 126 09-07-2006 08:54 PM
TurboXS comes through Again!!!! skelton Speed6 Engine/Drivetrain 160 08-18-2006 05:04 PM
