Tire Calibration Setting? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 13 (permalink) Old 02-26-2016, 12:03 PM Thread Starter
Trippp's Avatar
Quoted: 155 Post(s)
Groans: 5
I know there is the TPMS reset button on the dash board for tire pressure but isn't there also a tire calibration feature buried in the settings somewhere? Maybe I'm thinking of my 09 6. My wife's Lexus has a similar feature. Coulda swore I saw it somewhere.....
'18 Machine Gray GT Reserve
Trippp is offline
post #2 of 13 (permalink) Old 02-26-2016, 12:11 PM
Donkey Grundle's Avatar
Quoted: 439 Post(s)
Groans: 22
What do you mean by tire calibration? Since the TPMS is based on the wheel speed sensors measuring how fast the tires are rotation, that would be what you want to reset with new tires. I just did it when I went to larger 245/45r19's and it worked fine.
Donkey Grundle is online now
post #3 of 13 (permalink) Old 02-29-2016, 08:49 PM Thread Starter
Trippp's Avatar
Quoted: 155 Post(s)
Groans: 5
In my 2009 6 iGT and in my wife's RX, there is a tire size calibration reset separate from the TPMS. Resetting TPMS tells the car that the rotational speeds based on the current PSI is what the correct "pressure" is. But, you could put 240/30 R20s on the car and TPMS can still tell if a tire is low because of rotational differences although the speedo would be off. Tire calibration reset syncs the speedo. Tire calibration is sensitive enough that it was recommended to reset occasionally to account for tire wear and to be sure and do it when installing new tires even if they were the OEM size. I was looking for it because I just put new tires on my '16. Maybe the 3rd gen doesn't have it. I can't find it in the owner's manual.
Trippp is offline
post #4 of 13 (permalink) Old 02-29-2016, 10:35 PM
Quoted: 439 Post(s)
Groans: 22
Damn that's exactly what I need now that I've gone to a taller 245/45/19. Update us if you find something!
post #5 of 13 (permalink) Old 03-01-2016, 08:39 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2873 Post(s)
AFAIK there's nothing in the settings (on the 3.0 gens, not sure about the 3.5 gens) that would allow for setting the tire size to reconfigure the speedo and calibration. That always gets me in the winter because the snow tires I found are slightly too small so the first few weeks the stupid thing keeps telling me my pressure is low. Eventually it figures it out though, but it would be nice to be able to change that setting.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is online now
post #6 of 13 (permalink) Old 03-07-2016, 02:40 AM
coeywong88 is offline
post #7 of 13 (permalink) Old 09-17-2018, 07:16 PM
salasjairo's Avatar
Quoted: 13 Post(s)
With this new size, do you have any problem or rubs with the body?
You change in the series rims?
Greetings
salasjairo is offline
post #8 of 13 (permalink) Old 09-17-2018, 11:22 PM
Banned
Quoted: 329 Post(s)
Groans: 9
Greetings
It depends on what offset your wheels are. As long as you run a wheel with a high offset you won't run into any issues.
Get Inline is offline
post #9 of 13 (permalink) Old 09-17-2018, 11:30 PM
salasjairo's Avatar
Quoted: 13 Post(s)
Greetings
I am thinking in a series rims 45 offset
post #10 of 13 (permalink) Old 09-18-2018, 12:04 AM
Banned
Quoted: 329 Post(s)
Groans: 9
That will work fine. How wide is the wheel? aim for 9" for a 245 tire.
