19" G35 wheels - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 20 (permalink) Old 07-22-2014, 11:21 AM Thread Starter
SBopp's Avatar
Quoted: 43 Post(s)
With the fenders completely rolled and slightly pulled they still rub on turns and medium size dips mainly on the drivers side though. Not really in the position to buy 4 new tires right now. How do you guys think putting the rear in the front and front in the rear will effect it since the fronts are a half inch thinner and there seems to be more room in the front?
SBopp is offline
post #12 of 20 (permalink) Old 07-22-2014, 11:33 AM
ctmazda's Avatar
Quoted: 291 Post(s)
Groaned at 5 Times in 5 Posts
Why would you need 4 new tires? Car is not awd.
And swapping the wheels from the front axle to rear axle will not have any real effect on the car except maybe a slightly more "off" speedo, ever so slightly.
http://tire-size-conversion.com/spee...r-calibration/
Sent from AutoGuide.com App
2004 Mazda 6 Sport V6 MTX-Steel Grey
MSDS Headers/Ported Intake Manifolds + 1/2" Spacer/Injen CAI/3.7L OTB/TGNY TB Spacer/Magnaflow CBE/AWR 88 Mounts/Rotora H2 Ceramic Brakes//CF Evo Hood,Grill,Eyelids,Window Visors,Mirror Covers/CAR-LED Tails/35W 5000k HIDs/55W 6000k Integrated Fogs/LED Fogs/1000w Xplōd Amp/Two 800w 12" Xplōd Subs/15% Tints/18x8.5 +50 Kazera "CF" Rims/Hankook Ventus Evo 245/40/18
Future Mods:Powermod Tuner/Custom DoubleDin/BC Coils
ctmazda is offline
post #13 of 20 (permalink) Old 07-22-2014, 11:36 AM Thread Starter
SBopp's Avatar
Quoted: 43 Post(s)
Speedometer Calibration
The fronts will need to be replaced soon due to camber wear from the previous owner. And if I kept the rears in the back I would need smaller tires for them not to rub. Would it look retarded with wider in the front?
SBopp is offline
post #14 of 20 (permalink) Old 07-22-2014, 05:30 PM
ctmazda's Avatar
Quoted: 291 Post(s)
Well it is a fwd car so it is practical...there's only one way to find out. Swap them before your tires are gone just to see how it looks that way , I don't think you'll really notice too much of a difference anyways.
ctmazda is offline
The Following User Says Thank You to ctmazda For This Useful Post:
SBopp (07-23-2014)
post #15 of 20 (permalink) Old 07-23-2014, 12:48 AM Thread Starter
SBopp's Avatar
Quoted: 43 Post(s)
yea probably not since the rears have a little bit higher offset, you would think it would even out. Ill either do that or try to find a good deal on tires. Not sure if I should go for 225 35r19 on front and back our or maybe a 235 35r19.
SBopp is offline
post #16 of 20 (permalink) Old 05-05-2015, 07:53 PM
mmceorange's Avatar
Quoted: 1047 Post(s)
Did you have any problems getting the center bore of the wheels to fit onto your hubs?
mmceorange is offline
post #17 of 20 (permalink) Old 07-27-2015, 10:15 PM Thread Starter
SBopp's Avatar
Quoted: 43 Post(s)
Hey man I just stumbled upon this. I got rid of these wheels a long time ago but I had to modify the center bore. They were too small so I bored them out with a drill and a metal file until they fit perfectly. Wasn't hard at all and came out pretty good if I might add.
SBopp is offline
post #18 of 20 (permalink) Old 08-05-2015, 07:04 PM
mmceorange's Avatar
Yea. I had a set of the 18s in same style and was going to use a router to open the bore, but due to the work involved in getting to fit the fenders, I decided to sell. I was just curious if for some reason the 19s were less work, because they look so good.
post #19 of 20 (permalink) Old 08-05-2015, 10:35 PM Thread Starter
SBopp's Avatar
Quoted: 43 Post(s)
Dude I wanted the 18s but couldn't find them. I loved that style rim. It only took me like 20 minutes to do all 4 rims. I thought it would be a lot of work but it really wasnt at all
SBopp is offline
post #20 of 20 (permalink) Old 08-08-2015, 08:58 AM
Looks good. Bargain.
Arden is offline
