anyone use 215/40r17's for the front tires? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 07-01-2014, 04:10 PM Thread Starter
Quoted: 4 Post(s)
so i recently obtained for free a pair of Nexen N5000 215/40r17 tires in near new condition. they were on some lexus wheels someone decided to just throw out. i just so happened to be in desperate need of new tires (its a miracle i didnt have a blowout). so i had these tires installed and with the smaller sidewall obviously they look much nicer on the front. i know it was going to throw my speedometer off a bit, but now my TCS light comes on and occasionally when braking (on the harder side) the ABS wants to kick in too. is there any simple solution to this or am i ultimately going to have to rotate them to the back? Advice anyone?
drice9988 is offline
post #2 of 6 (permalink) Old 07-01-2014, 08:13 PM
Riki desu's Avatar
Quoted: 94 Post(s)
Cool. Another person! Im located in Goose Creek and so are at least two other members.
For your question, not really sure how that works but what size are your back tires? I think the main problem would be the tires are different sizes.
I run 215/50r17 all around on the stock rims so far.
2004 Mazda6 Sport GT,Onyx Black
Mods: Injen SP6072P CAI, 3.7l TB, 3/4" IM spacer, Mazdaspeed 3.0L v6 cat back, EGR Optimization/Re-Route, Transmission Cooler + Inline filter, TB coolant bypass/T replacements, 35 watt 5K HID Low Beams and Fogs
2011 Infiniti G37S Coupe,Obsidian Black, MTX
Mods: Complete Aero Body, Midnight Grill, Lip Spoiler, Tanabe Springs, RJM Clutch Pedal, Stillen Gen3 CAI
Riki desu is offline
post #3 of 6 (permalink) Old 07-03-2014, 04:26 PM Thread Starter
Quoted: 4 Post(s)
i have 215/50r17 on the back. i just had to fork out a good chunk of change for a new throttle body. i had one of the defective VP3M4U-9E928-AA tb's and ended up buying a brand new 3.7 with a conversion kit. then after all that i needed a new battery. not much left in the wallet for tires after all that so these 215/40r17s are what's gonna have to do. im having to turn my tcs system off every time i drive so it doesnt try to "correct" itself. in overall tire height difference from the 40s to the 50s is a good 1.69" though. throws my speedometer off by about 5-6mph off
post #4 of 6 (permalink) Old 07-03-2014, 05:09 PM
Quoted: 82 Post(s)
Yeah, if all 4 tires were the same size you wouldn't be having the problem. The difference in RPM between the two sizes is confusing the ABS/Trac system.
2004 Mazda 6 V6/MTX, Steel Gray
kevinspann is offline
post #5 of 6 (permalink) Old 07-04-2014, 12:48 PM Thread Starter
Quoted: 4 Post(s)
This shouldnt be a significant issue should it? im not as concerned about the Trac system as much as the ABS since it affects my braking ability slightly. so far ive noticed that i just need to brake a little lighter and earlier than usual. wondering if it would wear out my brake pads out at a faster rate.
post #6 of 6 (permalink) Old 07-06-2014, 08:38 PM
I have tired it with my car. If your suspension is still original, not a problem at all. But if you have obtained a suspension upgrade, let say lowering spring or coils. The the front wheels may have some rubbing issues in every full turn you do.
6ers is offline
