Wheel bearing issues - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 3 (permalink) Old 04-22-2014, 04:18 PM Thread Starter
strange6's Avatar
Quoted: 9 Post(s)
So, I believe I have a wheel bearing going out. Here is what I know, When I'm driving and turn the steering wheel to the left (even slightly) I get a loud humming noise. also when I'm doing a hard turn into a parking spot I get what sounds like a mild rubbing sound.
If it is just a wheel bearing, is there anywhere specific I should stay away from buying them or just look for them at my local Mazda dealership.
06 speed6 Black Mica #01293 Corksport SRI HKS BOV Meagan Racing Springs CorkSport Front license plate relocation kit Borla 3'' XR-1
strange6 is offline
post #2 of 3 (permalink) Old 04-22-2014, 04:37 PM
Drizzoh's Avatar
Quoted: 335 Post(s)
Groaned at 8 Times in 7 Posts
Send a message via AIM to Drizzoh Send a message via MSN to Drizzoh Send a message via Yahoo to Drizzoh
Mostly likely not a wheel bearing. Sounds more like you busted a ball joint on one of the front control arms. Given the age of these vehicles, they are becoming a very common problem. Get the front wheels off and inspect the bj's, tie rods, bushings and all axle boots. If anything is ripped, spewing grease or torn - time to replace.
Wheel bearings generally emit problems all of the time regardless of what type of driving, not specifically turning.
Andrew |
Drizzoh is offline
post #3 of 3 (permalink) Old 05-06-2014, 11:57 PM
its the wheel bearing. mine is doing the same, i will be replacing it by the weekend on my 03 v6. i also had a previous caliper issue which i think may have led to the bearing failure because of heat. i have done and replaced about 100 wheel bearings in my shop in the last 3 years. sounds just like you described.
idriveafastcar is offline
