3nd-Gen Wheel Thread - POST YOUR PICS/SPECS!!!----
720K views 769 replies 221 participants last post by  Bowl of Fat
#1 · (Edited)
Hi All.
Changed from stock 17 inch to aftermarket 19 inch.
Wheel Specs: HR Racing Alloy (Lexus ISF Replica) 19x8, Offset +45 , PCD 5x114.3 Machined Centrebore to 67.1mm (to fit the Mazda 6).
Tyres (Tires): 245/40R19 Federal Formoza FD2
Also added spoiler, tint, Philips Blue Vision Ultra Main Bulbs/Parkers
We liking it. Image Attached.
#692 ·
#698 · (Edited)
Hey guys. I'm due for new tires and want to get new wheels too. Anybody have experience with any of these?
What's the max width and offset I can run with out rubbing on stock suspension?
I really want the concave look.
The stock offset is +45 Any of those would fit with the right tire and you keep the offset around +40. I'm not sure how much less offset you can go. +35 maybe?
I was hoping some folks that have used those rims would post and let us know how much offset and the size tire they used along with how much room they have.
#700 ·
I went down a size because it's almost impossible to get any of the 19 inch tires here in California - everything 2-3 months wait time.
Andros Spec K 18x8 with Laufenn 225/50R18
I was reading a lot of the Laufenn and even they are very cheap - they not cheap at all. People rave about the tires which are produced by Hankook and so far they have been very pleasant. The car is much less vibrating. Traction and control are the same as before if not a bit improved.
#702 ·
Varrstoen L151 20x10.5 +40 with Achilles ATR Sport 245/35/20
#704 ·
Wheels:
ENKEI Tuning Series TD5 Pearl Black –* 18 x 8 / ET +45 / 20 lbs
Tires:
CONTINENTAL Extreme Contact Sport (97Y) – 235/50R18 / 27.3" diameter / 9.6" wide / 25 lbs
#705 ·
I'm looking into getting a set of 18x8 Konig Oversteers for my '17 and pairing with 225/50R18 tires. The car will be lowered about 1" on Tanabe springs.
Should I go for a 35 or 45 offset? I don't know to how to figure out what clearance I'd need or if it'd matter with this wheel size.
#706 ·
The stock offset for the 19inch rims is 45.
I’m running 19x8.5+54 wheels wrapped in 225/45/19 along with corksport springs/shocks.
I could have probably went with an offset if 35 but that would have been cutting it close! I can’t fit a finger between the tire and fender with ease.
#708 · (Edited)
Bought some JDM Enkei Rivazza 17 7J ET38 rims for winter. Should be very light: at the moment the whell weight with Dunlop Direzza DZ101 215/45 R17 is 38,2 lbs. Since the Dunlops should weight 22 lbs, hopefully 16,2 lbs is the rim weight. Seems almost too good to be true, I will be weighing them anyhow again soon without tyres. Anything below 20 lbs would be more than OK, since the original 17s weigh approx. 25 lbs. Will be fitting 225/55 17 tyres to the rims.
ps. they are 5x114,3, oddly 5x100 is engraved on the rim. They came from a JDM Nissan S15.
edit: ET added
#713 ·
Hi, I have had a MS6 for ~8years and she is getting old so i just picked up a 2018 GS-L turbo in machine metalic.
I need to give the new car some character and I race my cars so i am looking for a more practical style.
I fit the 235/45-18 on 18x7.5 et42 i run on the MS6 just to see were i stood (they are to small and need to go back on the MS6)
I was thinking of running 2017 mustang gt performance wheels 19x9.5 et52.5 front and 19x9 et45 rear with 255/40-19 all around and add Tanabe springs.
Any advice?
Thanks,
John
#720 ·
Nice set up I dig the RPF1's. If you can get a pic I'd appreciate it :)
#717 ·
well I got the rims and tires mounted.
2018 Mustang Performance Pack 1 wheels
Front 19x9.5 et52.5 255/40-19
Rear 19x9 et45 with 5mm spacer 255/40-19
The only issue with the rims is that they are made for bigger brakes so the caliper bracket is really close the hub. A big brake kit or a little grinding might be needed as it is that close.
The good part is that 255 fit, and you can go full lock no rubbing.
The first gen in my mazdaspeed 6 that i just thought i would share since I mentioned it earlier.
#721 ·
I'm thinking of running 18x9.5 front and 18x9 rear with +28, wondering how this set up will look in comparison to yours.
