17x8 +35 offset with S.Techs - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 18 (permalink) Old 02-27-2013, 04:26 PM Thread Starter
Canadian6's Avatar
Quoted: 48 Post(s)
Hey everybody. I destroyed two rims in a massive pothole the other day so I'm in the market for my first set of aftermarket ones. I have my eyes on a set of Rota Grids in 17x8 with a +35 backspacing and Rota G-Forces in the same size with +48 backspacing. I'm curious if they'll fit, I've checked the members wheels forum and just confused myself even more. Currently I have a 2004 Mazda 6 wagon with S.Techs waiting to be installed. Would both/neither of these fit with/without fender rolling(which I don't have)? Thanks and hope to be rocking some awesome new rims soon!
1971 Datsun 510 (New Toy)
100% original. Soon to have built L16/5Speed
2004 Mazda6 Wagon
Engine - MSDS Headers and Catless Y Pipe, Injen Intake, CPE Maf Customizer, TB Coolant Bypass, EGR Mod, Injen Cat Back, 3.7 Optimized Throttle Body, Accel 4v Cobra Coils
Suspension/Exterior - Tein S.Tech Springs, Plasti Dipped Sport Grill, Door Guards Removed
Canadian6 is offline
post #2 of 18 (permalink) Old 02-27-2013, 05:19 PM
tank1707's Avatar
Quoted: 420 Post(s)
Re: 17x8 +35 offset with S.Techs
I have a 03 6 no hatch and am running 18x8 with +35 its not a bad fit for stock height but since I have weight in the trunk (sub box) they run decently on uphill entrances and fast dips. If you lower I'm sure you with have the same problem with a +35 offset
I'm getting my fenders rolled soon and maybe shaving the back of my wheel 3mm to pull it in a bit for a nicer no rub fit.
Sent from my DROID BIONIC using AutoGuide.Com Free App
2003 ATX Speed Yellow 6i:
tank1707 is offline
post #3 of 18 (permalink) Old 02-27-2013, 05:56 PM
CanyonRider's Avatar
Quoted: 181 Post(s)
Go with the +48. The +35 will require a fender roll.
CR
2003 Mazda 6s MTX
Mods - Yeah, I got
My Threads:
Like our Race Team's Facebook page:
CanyonRider is offline
post #4 of 18 (permalink) Old 11-28-2013, 05:34 PM
Ghost6's Avatar
Quoted: 4 Post(s)
I am looking to buy the XXR 522's in 17x8 +35. I have already had the rear fenders rolled from my previous Enkei OR52's which were 17x7 +38. I never rubbed with the OR52's but since the XXR's are a little more aggressive would i need to roll the front fenders also or do you think ill be ok? Im on stock suspension for now and don't plan on any lowering till summer due to winter here. One of my Enkei's are bent at the hub. Bought them used that way and none of the wheel repair shops around here can repair it and the OR52's are discontinued and enkei doesn't have any so might as well get new wheels. Let me know what you guys think.
XXR 522 17x8 +35 w/rolled fenders,Door molding mod,Air box mod,Resonator mod, 35w 8000k hids fog and low beam,Mssport style grille,Glowshift gauges,Glowshift Center triple gauge pod,Spin on oil conversion,Ultra white reverse leds,Corksport led kit,Black Headlight housing, side marker and reflectors smoked,plasti-dip badges black,Tail light mod,Marker light mod , blacked out stock exhaust.
Ghost6 is offline
post #5 of 18 (permalink) Old 11-28-2013, 07:05 PM
Mazda v6's Avatar
Quoted: 98 Post(s)
Sorry man but that wont fit.
I used to have an s tech with a 17x7+48 rims and it still rubbed. I had to get my fenders rolled and flattened and the well liner trimmed and it still rubbed occationally.
You will have to get a stiffer suspension for that wheel. Stech are soft.
Life is like a rock, it's Hard!!! Bwahhahhahha
Mazda v6 is offline
post #6 of 18 (permalink) Old 11-28-2013, 07:09 PM
Quoted: 400 Post(s)
Groans: 16
Groaned at 4 Times in 4 Posts
You're joking I hope? I run 17x9 +43 with a 245/45 tire and my fenders are rolled. Nothing needed to be trimmed. I'm slammed on BCs as well. Op that will fit fine so long as you don't put huge tires on it. You will need to roll your fenders though.
xkreedx is offline
post #7 of 18 (permalink) Old 11-28-2013, 10:13 PM
Mazda v6's Avatar
Quoted: 98 Post(s)
Im not.. well you got a bc coils so they are much stiffer than the stech that the op is planning to get and what I had.. they suck on wide wheel and dips on certain speed.. they will rub if the op gets the stech. So either get the eibach or a coilovers.
Mazda v6 is offline
post #8 of 18 (permalink) Old 11-28-2013, 11:24 PM
Ghost6's Avatar
Quoted: 4 Post(s)
Ok would I need the front feeders rolled also? I'm looking to get these by the end of today or tomorrow morning. I would be running these with the stock tire size. I have already rolled the rear fenders with the guy you gave me but found out one of the enkei's was bent at the hub and hubcap heaven couldn't repair it and I am still gonna go to wheel werks and see if they can repair it but in the meantime I'm just gonna grab a new set
Ghost6 is offline
post #9 of 18 (permalink) Old 11-29-2013, 12:18 AM
Quoted: 400 Post(s)
Groans: 16
Rubbing has nothing to do with suspension. I'm on the softest setting and tucking tire. It has to do with offset width and tire size.
xkreedx is offline
post #10 of 18 (permalink) Old 11-29-2013, 12:18 AM
Quoted: 400 Post(s)
Groans: 16
No. There really nothing to roll in the front you should be good to go dude.
xkreedx is offline
The Following User Says Thank You to xkreedx For This Useful Post:
Ghost6 (11-29-2013)
