Will these rims fit? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 7 (permalink) Old 02-04-2013, 01:04 AM Thread Starter
Quoted: 4 Post(s)
Groaned at 2 Times in 1 Post
the specs are:
17 x 7.5
5x114.3
offset: 50
But it does not give a bore size. It says on the listing that it fits the Mazda 3/speed3, speed6 and mx-5
im pretty set on these rims, so as long as they fit. My 6 is an 07 V6
Thanks!
StevenMazda6S is offline
post #2 of 7 (permalink) Old 02-04-2013, 01:27 AM
davidbrandi05's Avatar
Quoted: 14 Post(s)
They should. I bought 18x8 wheels with a +55 offset for my MS6
Sent from AutoGuide.com App
2006 Mazdaspeed 6
davidbrandi05 is offline
post #3 of 7 (permalink) Old 02-04-2013, 03:26 PM
ctmazda's Avatar
Quoted: 291 Post(s)
Groaned at 5 Times in 5 Posts
Those will fit no problem those are basically stock specs.
2004 Mazda 6 Sport V6 MTX-Steel Grey
MSDS Headers/Ported Intake Manifolds + 1/2" Spacer/Injen CAI/3.7L OTB/TGNY TB Spacer/Magnaflow CBE/AWR 88 Mounts/Rotora H2 Ceramic Brakes//CF Evo Hood,Grill,Eyelids,Window Visors,Mirror Covers/CAR-LED Tails/35W 5000k HIDs/55W 6000k Integrated Fogs/LED Fogs/1000w Xplōd Amp/Two 800w 12" Xplōd Subs/15% Tints/18x8.5 +50 Kazera "CF" Rims/Hankook Ventus Evo 245/40/18
Future Mods:Powermod Tuner/Custom DoubleDin/BC Coils
ctmazda is offline
post #4 of 7 (permalink) Old 02-05-2013, 12:10 AM Thread Starter
Quoted: 4 Post(s)
Thanks.
What size tires should I go with for the 7.5" width?
225 45 17? I want them to fit the tire nice, but not to look too bulgy
Also, I wanted to go with 18" rims, but wouldnt it make the speedometer off by a little bit?
post #5 of 7 (permalink) Old 02-05-2013, 05:53 AM
ctmazda's Avatar
Quoted: 291 Post(s)
If you get 18" rims you just have to run a 40 series tire and the speedo will be very close to stock. You can look up a calculator online and figure out the difference from the stock 50 or 55 series on a 17 versus 40 or 45 series on a 18 and you'll see there is only a few degrees if that of difference depending on your tire height choice.
That is a good tire size for those rims.
ctmazda is offline
post #6 of 7 (permalink) Old 02-06-2013, 10:31 PM
Quoted: 6 Post(s)
Offset: 40
Bolt Pattern: 5x114.3"
is what I have and they rub if people sit in the back
EffinCheesy is offline
post #7 of 7 (permalink) Old 02-07-2013, 01:29 PM
CanyonRider's Avatar
Quoted: 181 Post(s)
Originally Posted by EffinCheesy View Post
Offset: 40
You need more offset. The stock wheel is 17x7, +60. You added width AND pushed the wheel out with the lower offset - not a good combo. You moved the outside edge of the wheel out 27mm (over an inch), but only increased the wheel width by 1/2inch. If you roll the fenders you should be ok.
Good luck,
CR
2003 Mazda 6s MTX
Mods - Yeah, I got
My Threads:
Like our Race Team's Facebook page:
CanyonRider is offline
