MB Battles 17x9 fitment? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 4 (permalink) Old 09-16-2012, 01:44 PM Thread Starter
Just wondering what kind of fender work I should be thinking about if I get the 17x9 Battles. I'm pretty sure I'll have to roll em. But i have a spot of rust on one side, so would grinding them be an option?
hardstyleXmazda is offline
post #2 of 4 (permalink) Old 09-16-2012, 03:32 PM
Nihilus's Avatar
Quoted: 155 Post(s)
Groans: 9
you're in the wheels section and you didn't see the stickies?
06 MX5 GT - w/ Susp. Package (Bilstein shocks and LSD), Prog. Tech. Springs, Bose/xCarlink/10 Inch Fosgate P2 with Alpine 250w amp, RoadsterSport 2 Muffler, Racing Beat catless midpipe, AEM CAI, RHT
05 6i, Glacier Silver - Traded!
Nihilus is offline
post #3 of 4 (permalink) Old 09-16-2012, 05:42 PM
Quoted: 400 Post(s)
Groans: 16
Groaned at 4 Times in 4 Posts
Depends on offset. I run 17x9 with a 245/45 tire without rubbing or negative camber.
tapatalking.. err wait.
xkreedx is offline
post #4 of 4 (permalink) Old 09-16-2012, 06:27 PM
Drizzoh's Avatar
Quoted: 335 Post(s)
Groaned at 8 Times in 7 Posts
Send a message via AIM to Drizzoh Send a message via MSN to Drizzoh Send a message via Yahoo to Drizzoh
IIRC the battles are a +35 offset, so you'll need to run a 225 series tire, roll the fenders and dial in your camber. Can probably get away with -1 deg camber (which is less than stock at -1.2 deg). I would recommend getting them in a 18x9 though as it will look much better than a 17x9 for stretched fitment. Offset is the key though, without knowing the exact offset on those wheels, any fitment questions are pointless.
That being said, I'm running the same wheels as xkreedx with 255/40's and hecka rolled/slightly pulled fenders, -1.4 deg camber front and -1.0 deg rear with 0.1 toe all around. Awesome, awesome wheel/tire combo/fitment and no rubbing.
Andrew |
Drizzoh is offline
The Following 2 Users Say Thank You to Drizzoh For This Useful Post:
hardstyleXmazda (09-16-2012), xkreedx (09-16-2012)
