Air pressure - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 05-04-2012, 12:10 PM Thread Starter
Air pressure
got my new 17" Oe Mazda 6 rims, design 121.
what tire pressure should i use for my tires ?
215/50 91h bridgestoen potenza
2,2 front and 2,4 back ? it's a 2004 Wagon and got 2 heavy 12" woofers and 3 amps in the back. with a big subenclosure.
vang1 is offline
post #2 of 6 (permalink) Old 05-04-2012, 12:18 PM
corey6's Avatar
Quoted: 6 Post(s)
probably 35 front and if you have alot of weight in the back...dont go above 40. i do 35 all around.
corey6 is offline
post #3 of 6 (permalink) Old 05-04-2012, 12:19 PM Thread Starter
Thanks for the quick answer
vang1 is offline
post #4 of 6 (permalink) Old 05-04-2012, 02:08 PM
100% CANUCK
Mr.Smoke's Avatar
Quoted: 1305 Post(s)
Groaned at 8 Times in 8 Posts
+1 to 35 psi.
Mr.Smoke is offline
post #5 of 6 (permalink) Old 05-04-2012, 03:24 PM
TNM6i's Avatar
I run my 215/50s at 35 all around.
2006 6i Grand Sport | Glacier Silver Metallic
Smoked LED Rear Reflectors | Smoked LED Sidemarkers | LED Lighting | CX-7 Antenna | Airbox Mod | 17" Enkei RP03s
Future Plans: Window Tint | Painted Calipers/Hubs | Racing Beat Axle-Back Exhaust
TNM6i is offline
post #6 of 6 (permalink) Old 05-06-2012, 11:53 AM
Quoted: 145 Post(s)
Groans: 5
Groaned at 8 Times in 6 Posts
These are eurometric 17" tires with a 91-SL load series, not usually available in the US. They take just 1 more psi vs our 17" 93-XL (32 psi @ door B-piller), for the same max car load capacity. These 17" tires only have a 36 psi max running pessure with 1356 lbs on the tire, vs the 41 psi max for the US 93-XL tires with
1433 lbs on the tire.
Bottom line, your 17" tires are not as strong as the 17" 93-XL's that are oem in the US.
I suggest trying 34 psi all around, and check if the rears "squish out" more than fronts, due to the stereo load + friends & stuff inside. If they do bulge out more than fronts, up the rears to 36 psi.
04 6S atx hatch
93 RX-7, 75 Trident
KevinK2 is offline
