New Wheels Rub Even After Fender Roll - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 15 (permalink) Old 04-14-2012, 09:50 PM Thread Starter
Hey guys...
So i have a problem.
I recently picked up a set of MSR rims 18x8 with an offset of 45 on 225/45/18 Eagle GTs. With a fender roll, i reduced the rubbing. however even with a couple people in the back, it rubs on every minor dip and bump.
What are my options going forward? I dont mind getting rid of the rims, but the tires i would love to keep as theyre a pretty good set.
ooomayor is offline
post #2 of 15 (permalink) Old 04-14-2012, 10:36 PM
hotstreak2002's Avatar
Quoted: 30 Post(s)
You could add some negative camber if they are rubbing on the fender.
2010 i Touring Plus Kona Blue
Suntek Tint | Tinted Markers | Aluminum Pedals
Strut Tower Bar | Eibach Pro-kit | Koni Yellows | RX-8 wheels
DDM 5000k HIDs | LEDs | OEM LED Tails | CorkSport SRI | HD Lip
hotstreak2002 is offline
post #3 of 15 (permalink) Old 04-14-2012, 10:48 PM
bmorrisj's Avatar
Where did you roll it? The rear wheel wells need to be rolled tight in the thin area directly behind the passenger door.
2007 w/ Cheez
// COBB AP // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs //
Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber
// Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob //
bmorrisj is offline
post #4 of 15 (permalink) Old 04-15-2012, 12:36 AM Thread Starter
I will take pictures in the morning. I really do not want to get rid of the rims, nor the tires. I am not sure cuz i asked another guy to do them.
what about you? youve got +35 and 235 tires, how much rubbing are you getting?
ooomayor is offline
post #5 of 15 (permalink) Old 04-15-2012, 12:37 AM
MATR6's Avatar
Quoted: 19 Post(s)
I had 225/45s on my 18X7s with 42mm offset that rubbed with fender roll. Switched to 225/40s & stopped rubbing.
My offset sticks out 3mm(0.1") more than your wheels, so lower profile tires.
'07 Speed6 GT LPM #8903
AutoExe Low Down Springs | Billstein HD | CARLED Tailights | Mazdaspeed OC | Redline Goods SB | TWM Stage 1 SS & Bushings | XCarlink | Enkei RS5 18X7 42mm offset | 225/40 Hankook Ventus V12 EVO K110
MATR6 is offline
post #6 of 15 (permalink) Old 04-15-2012, 12:42 AM Thread Starter
Just checked...untouched completely stock. I will have that area rolled and hopefully that helps
But your rims are an inch less wider...or does that not come into play since the tires are the same width?
ooomayor is offline
post #7 of 15 (permalink) Old 04-15-2012, 01:05 AM
Project_dog's Avatar
Quoted: 12 Post(s)
would 225/40/18 tire help?
***RIP mazda 6i RIP***
Project_dog is offline
post #8 of 15 (permalink) Old 04-15-2012, 10:13 AM
MATR6's Avatar
Quoted: 19 Post(s)
According to this Custom rims, wheel tire packages for your ride - RIMSnTIRES.com my wheels stick out 0.1" more than yours. I plugged in your wheel specs vs mine. I had 225/45s & it scraped, 225/40s did fine, but still scraped with ppl in back seat going over RR tracks.
MATR6 is offline
post #9 of 15 (permalink) Old 04-15-2012, 12:41 PM
bmorrisj's Avatar
225/40 tires are too short, less sidewall to rub though.
I'm on coilovers 18x8+35 235/40 and only rub on fast hard dips... And that's only because my rear c/o shocks are out the door.
2007 w/ Cheez
bmorrisj is offline
post #10 of 15 (permalink) Old 04-15-2012, 03:02 PM Thread Starter
you may be right.
The gouge marks on the tires line up to that part of the fender that hasnt been rolled. Aside from which there isnt any part of the fender that could make that gouge elsewhere.
Name:	2012-04-15 14.40.05.jpg
ID:	82381   Click image for larger version
Name:	2012-04-15 14.41.20.jpg
ID:	82382   Click image for larger version
Name:	2012-04-15 14.49.32.jpg
ID:	82383   Click image for larger version
Name:	2012-04-15 14.49.41.jpg
ooomayor is offline
