New Wheels Rub Even After Fender Roll - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 15 (permalink) Old 04-15-2012, 03:09 PM
bmorrisj's Avatar
the wheel doesn't go straight up and down on compression/rebound. This car has a rear trailing arm, the wheel will rotate towards the front of the car on compression. That's why the area behind the door needs a good roll.
Also your wheels are +35 offset, they are the same as mine.
2007 w/ Cheez
// COBB AP // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs //
Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber
// Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob //
bmorrisj is offline
The Following User Says Thank You to bmorrisj For This Useful Post:
ooomayor (04-15-2012)
post #12 of 15 (permalink) Old 04-15-2012, 03:11 PM Thread Starter
Thanks a lot.
The part where it is rolled is a pretty good roll, very tight. where it isnt...is simply not. I will have this done and see what happens
The wheels are +45
I saw the back of the wheel, it said so :/
ooomayor is offline
post #13 of 15 (permalink) Old 04-15-2012, 03:22 PM
bmorrisj's Avatar
You sure? These wheels are only available in +35 and +42, and yours are sitting out pretty far.
045 - MSR Wheels
2007 w/ Cheez
bmorrisj is offline
post #14 of 15 (permalink) Old 04-15-2012, 03:56 PM Thread Starter
Damnit, now im doubtful its 45.
When i pull these off to roll I will check again. I could have sworn i saw ET45 stamped back there
ooomayor is offline
post #15 of 15 (permalink) Old 09-09-2012, 03:53 PM
Final Impact's Avatar
Quoted: 533 Post(s)
Groaned at 4 Times in 4 Posts
Thread revival - when rolled properly by someone who's got it together, does it tweak the outer lip? Tire caught mine and with the right light you can see it deflected the panel a small amount.
And what is the offset of the OEM stock 18" wheel?
I've got 18 X 8 +45 w/225/40's. How tight a roll can the panel handle before getting all wavy?? Are we talking new paint or what??
Thanks - had it 8 days now and trying to decide how to live with it.
V6 repair info here:
Final Impact is offline
