Do I need to replace all 4 tires? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 9 (permalink) Old 11-08-2010, 05:06 PM Thread Starter
Both of my front tires and bad and need to be replaced but do I need to replace all 4 or can I replace just the 2 bad tires?
jumpman23j is offline
post #2 of 9 (permalink) Old 11-08-2010, 09:08 PM
daztd's Avatar
Quoted: 35 Post(s)
Do you have a regular 6 or a Speed 6? If it's a regular 6 then you can just replace the 2 tires and put the new ones up front. If it's a Speed 6 and the tires are fairly new then u will be ok with just 2 new tires. But if they are worn....you will need to do all 4.
2006 MazdaSpeed 6 Grand Touring | Velocity Red Mica
DashHawk, CS TIP/SRI/TMIC, SU MM, JB EGR block plate/plug/TB TIG, CPE RDM, Perrin EBCS, Turbosmart BPV,TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, silicone boost tubes, Bilstein HD, LED bulbs, TRS projectors, HID fogs, Hawks pads, Amsoil diff/pto/trans, navi, XCarLink USB
daztd is offline
post #3 of 9 (permalink) Old 11-08-2010, 10:15 PM Thread Starter
It's a regular 2006 mazda6. Anyone have any experience with Fuzion HRI's?
post #4 of 9 (permalink) Old 11-18-2010, 08:13 AM
If it's a regular 6 then you can just replace the 2 tires and put the new ones up front..
No no NO! This is a common misconception that really needs to go away. Always put your better tires on the rear, even in a FWD car. It's actually more dangerous to put better tires in the front. New tires on the front can cause major oversteer issues if you happen to hydroplane.
DraconWolfX is offline
post #5 of 9 (permalink) Old 12-21-2010, 11:37 PM
I want the best ones up front so car is less likely to hydroplane in a curve and can still steer at safe speeds. It don't take much speed in a light car and half worn tires to get in trouble. I nearly lost it once because the front hydroplaned in a slow curve and couldn't steer till speed reduced enough.
Speed135 is offline
post #6 of 9 (permalink) Old 12-21-2010, 11:51 PM
NascarGreg's Avatar
Groaned at 12 Times in 9 Posts
I understand your fear but...understeer is always better and safer than oversteer. Understeer is easier to recover than oversteer, especially in a fwd car. If you hydroplane in a curve, just ease off the gas a bit and straighten the wheel. You will recover control much faster and in a controllable manner. Oversteer is, especially in this example, likely unrecoverable. The added grip from the fronts will more readily induce oversteer, especially off-throttle, with a radically different grip front-to-rear. Think back to most NASCAR single-car crashes. They are almost always as a result of oversteer, on or off throttle. The overwhelming majority of the remaining wrecks are from blown front tires and the resultant loss of control. You rarely see an understeer-related crash. If we where talking about a RWD car, then my argument would be to put them on the rear first...though some here will argue that too
Greg
2004 Champagne 6s 5spd Sport w/Bose...stock, for now.
NascarGreg is offline
The Following User Says Thank You to NascarGreg For This Useful Post:
Mz6GreyGhost (12-22-2010)
post #7 of 9 (permalink) Old 12-23-2010, 12:45 PM
backroad101's Avatar
Quoted: 9 Post(s)
If the back end is getting squirrly, it is best to have the new tires in back to keep the rear end planted.
'04 Mazda 6s 4dr (Glacier Silver)
18" '09 RX-8 rims/tires, HIDs, K&N filter, 45/20% window tint, debadged emblems, 194 LEDs, '07 black trimmed taillights w/red turn signals, chrome JDM grille, door handles & trunk lip, billet lower grille, strut tower brace, LeBra hood protector, XM Radio
backroad101 is offline
post #8 of 9 (permalink) Old 12-23-2010, 11:07 PM
Greg, Incident was with 67 Comet Cyclone GT, had Firestone Wide Ovals on Louisville interstate in the rain. Should have waited for the really bad 68. You are certainly right, oversteer gets you in big trouble. I was just talking hydroplaining that scared me that day. Those wide ovals lasted 11K with no power steering and skinny steering wheel. Oh, and 11 MPG and wasn't that fast.
Speed135 is offline
post #9 of 9 (permalink) Old 12-24-2010, 11:00 PM
Quoted: 9 Post(s)
Survey says......new in the rear.............. #1 answer
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=52
http://www.michelinman.com/tire-care/tire-saving-tips/replacement-questions/ last one
http://www.tirereview.com/Article/81718/always_install_two_new_tires_on_the_rear_axle.aspx#
