What to expect with a 235/40/18 upgrade? - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #11 of 17 (permalink) Old 07-08-2009, 11:33 AM
SmokeU6s
After reading that exact article I went into my local Discount Tire Co. to check em out and the guy working there said you can expect 45000miles from them even though the warranty Discount Tire is 30000 (or somewhere around there). But he said it all is dependent on how you drive because he figured that the estimate he gave me is an underestimate because its what Hankook gives them which he figures is with mixed driving. He guesses that if you drive like a little old lady you'd easily make it to 60000 or if you are hard on them or use em for auto x or something you would of course get considerably less. After he told me that I walked out and was like DER! Doesn't take a genius to know that how you drive affects how your tires last.
hyperlite is offline
post #12 of 17 (permalink) Old 07-08-2009, 12:18 PM
smokeU6s's Avatar
Send a message via AIM to smokeU6s
hyperlite,
thanks for the update. Considering they are about $20/tire cheaper than the avids they look to be my next purchase.
All Black Mazda6s 04 ATX 5door | Bose | Moonroof | CP-E MAFci Intake | Painted Yellow Calipers | Magnaflow catback | B&M tranny cooler | Magnafine Transmission Filter | Anzo Clear Side Markers | Weapon X Coil on Plugs
smokeU6s is offline
post #13 of 17 (permalink) Old 07-08-2009, 12:34 PM
posttosh's Avatar
Quoted: 27 Post(s)
Groaned at 3 Times in 2 Posts
QUOTE (smokeU6s @ Jul 8 2009, 08:02 AM)
posttosh,
CND just placed the Hankook Ventus in 2nd place in a tire test, and the price can't be beat.
Whats the estimated tread life?[/b]
I have not seen any recent Car and Driver test results, but that is consistent with a spate of recent tests by German enthusiast magazines. (BTW, there are several models of Ventus. The Hankook Ventus S1 evo that Tire Rack sells, for instance, is a very different tire than the Hankook Ventus V12 evo that has excelled in the German testing.)
The UTQG Treadwear rating of the Hankook Ventus V12 evo is 280. The OEM Michelin Pilot HX MXM4 tires have a UTQG Treadwear rating of 300; theoretically, then, the Hankooks would wear out in 14/15ths (fourteen-fifteenths) the number of miles compared to the Michelins. So, if you get 36,000 miles out of the Michelins, then -- theoretically -- you would get 33,600 miles on the Hankooks. (Due to granularity -- Treadwear ratings are in multiples of 20, so the difference between "280" and "300" could represent anywhere from 1 to 39 units -- and due to differences among manufacturers in interpreting the detailed mandatory procedures for the testing of Treadwear, the Treadwear numbers should not be parsed too finely.)
posttosh is offline
post #14 of 17 (permalink) Old 09-04-2009, 11:49 PM Thread Starter
Just installed RX8 wheels with Potenza RE760 in the 235/40/18 size.
Handling is like night and day compared to the stock tires and wheels.
Will upload some oics soon.
PtonDad09 is offline
post #15 of 17 (permalink) Old 02-23-2010, 01:37 PM
daztd's Avatar
Quoted: 35 Post(s)
Exclamation
QUOTE (DaveR @ Sep 4 2009, 09:49 PM)
Will upload some oics soon.[/b]
How do you like your Potenza RE760?? looking at getting some soon. Thanks
2006 MazdaSpeed 6 Grand Touring | Velocity Red Mica
DashHawk, CS TIP/SRI/TMIC, SU MM, JB EGR block plate/plug/TB TIG, CPE RDM, Perrin EBCS, Turbosmart BPV,TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, silicone boost tubes, Bilstein HD, LED bulbs, TRS projectors, HID fogs, Hawks pads, Amsoil diff/pto/trans, navi, XCarLink USB
daztd is offline
post #16 of 17 (permalink) Old 06-09-2011, 11:26 AM
Although this is an old thread I thought I'd share my experience going 235 40 18.
on my Mazda 6 Sport Wagon.
I have sportmax aftermarket wheels. I had 215 45 18 on these wheels earlier. I just moved to the 235/40/18's Kumho Ecsta AST anddd....... NOT GOOD. The rear wheels rub when I go through a dip even if its a shallow dip but at highway speeds. I've old had this happen so far with 3 people in the car. I installed the tires yesterday and have had it rub really hard atleast 4 times.
So it doesn't rub the entire wheel well lip but just a 2inch section near the rear door (i don't know if you guys can visualize that from my description).
The front wheels are no problem at all with the wheels turned end to end. I have to agree though handling is GREAT & the 1 inch increase in tire width makes the car look smashing. BUTTT I'll be moving back to the 215-40-18 for the rears. Can't afford to change all 4.
2and4 is offline
post #17 of 17 (permalink) Old 06-12-2011, 11:47 PM
Awong124's Avatar
It all depends on the wheels. I have 235s on my car and never really had a problem. They rubbed before I rolled my rear fenders properly, but nothing after that.
2006 Mazda 6 Sport GT-V6 MT
Awong124 is offline
