What Tire Brand you have? - Page 39 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #381 of 564 (permalink) Old 10-01-2008, 06:43 PM
goguen89's Avatar
Send a message via MSN to goguen89
I'm running 215/50R17 BFGoodrich Traction T/A
Very good in the wet stuff, even better in the dry.
Very stiff sidewalls compared to the crap it had when I bought my car.
Rougher ride but I like the sporty feel of them and they have much better wear than the ones i had before (Cooper Lifeliner GLS)
2005 Mazda6i Sport GS Manual Steel Gray - 17x8 Enkei RPF1 GOLD with 235/45ZR17 Toyo Proxes4 (saving 8lbs per corner) - K&N Filter - Airbox Mod - LED Backup Lights - LED front and rear dome lights - SS Defender shift knob - Pulstar Pulse plugs - Mobil1 synthetic - Apexcone 35W 8000K HID kit in low beam and fog light - CX7 Antenna
[url="
size="2">Not slowing down for turns improves your gas mileage
goguen89 is offline
post #382 of 564 (permalink) Old 10-01-2008, 11:17 PM
posttosh's Avatar
Quoted: 27 Post(s)
Groaned at 3 Times in 2 Posts
QUOTE (ashutoshsm @ Oct 1 2008, 10:43 AM)
Are you basing those numbers on ACTUAL tire specs (which vary and are not precisely what the sidewall says)?[/b]
Dunlop states that the Direzza DZ101 in the 215/45R17 suze requires 842 revolutions to cover one mile.
Michelin states that the Pilot HX MXM4 215/50R17 in the 93V configuration require 819 revolutions to cover one mile.
The sidewall specs suffer from granularity. A section width must be specified as a number ending in -5, so a 210.1 mm wide tire is a 215, and a 209.9 mm wide tire is a 205. Aspect ratios are also stated as multiples of five, so a tire that has a sidewall height that is 47.4 percent of its section width is a 45, and a tire that has a sidewall height that is 47.6 percent of its sidewall height is a 50.
but based ONLY upon stated (sidewall) tire size comparisons at Miata.net's Tire Calculator, the error is a 'mere' -3.3%, not -9.7%.[/b]
The Miata.net calculator assumes that a 215/45 tire has a section width of exactly 215.000 mm and an aspect ratio exactly 45.000 percent. Neither of those conditions actually obtains in the real world.
Sounds like you're assuming (or can you confirm?) a uhge inaccuracy in the Dunlop/s stated size! Or am I missing something?[/b]
Clickable links:
For the Dunlop Direzza DZ101 215/45R17 (842 revolutions per mile);
for the Michelin Pilot HX MXM4 215/50R17 93V (819 revolutions per mile).
819 divided by 842 equals 0.972624 -- that's a 2.7316 percent difference; 842 divided by 819 equals 1.0280083 -- that's a 2.8083 percent difference. Round either to three percent. Did I write 9.7 percent above? (I did.) Sorry, my bad.
posttosh is offline
post #383 of 564 (permalink) Old 10-14-2008, 03:33 PM
I replaced the stock set on my 06 speed6 with Kuhmos. 18mos later they are worn badly, going to try out some goodyears.
rjhicks is offline
post #384 of 564 (permalink) Old 11-03-2008, 05:09 PM
Michelin Pilot Sport FTW.
suhrich is offline
post #385 of 564 (permalink) Old 11-13-2008, 03:26 PM
I just put a set of Goodyear GT's on the car. I replaced a set of Perilli's M&S that lasted 24K miles. The Goodyears feel good in the rain and on the diffrent types of road I encounter on my way to work. The tread depth seems more than the Perilli's when they were new, and they are quiet.
Nelson
nelsong is offline
post #386 of 564 (permalink) Old 11-21-2008, 06:41 AM
808MS6's Avatar
Send a message via AIM to 808MS6
Sumitomo HTRZ III 225-40-18. Daily driving and autocrossing, they work very well, a bit more grip than the stock RE050A's but just as noisy. They lose their grip when they get over 170 degrees. Highly recommend if you want a tire with good road manners, but enough grip for those autocross sundays. Oh did I mention how cheap they are? They go for $111 at tirerack!
Mazda hates you.
808MS6 is offline
post #387 of 564 (permalink) Old 11-29-2008, 03:57 AM
Thumbs up
QUOTE (WickedFast @ Oct 19 2005, 11:04 AM)
Just bought Fuzion ZRi(s) for $91 each at tirerack.com. So far the difference is night and day compared to those HORRIBLE stock Michelins. Better braking, no squalling, VERY grippy, less understeer, strong sidewalls (very little "bulge" and no rolling even at a 35psi inflation rate--max pressure is 55psi!). Going to the race track this Saturday to give them a *real* test. WOO HOO!!![/b]
I have heard very good reviews about this tire and plan to get them. How have they held up?
Megatron is offline
post #388 of 564 (permalink) Old 12-06-2008, 09:49 AM
DashingMax's Avatar
Continental ContiExtreme Contact
2006 MazdaSpeed6 Grand Touring - Everything except NAV! All stock.
2007 Mazda CX-9 Grand Touring - ALL Options - If it doesn't have it, Mazda never offered it!
Things that make you go Zooooom!
DashingMax is offline
post #389 of 564 (permalink) Old 12-06-2008, 09:59 AM
aprolla23's Avatar
Send a message via MSN to aprolla23 Send a message via Yahoo to aprolla23
Yokohama's here. Got them dirt cheap too. Love live.com's cashback.
Now stock 2006 MS6
aprolla23 is offline
post #390 of 564 (permalink) Old 12-09-2008, 06:15 PM
ble
Kumho ecsta DX. Handles great and very smooth riding. Great traction for the Wisconsin winters.
ble is offline
