What Tire Brand you have? - Page 27 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #261 of 564 (permalink) Old 06-16-2007, 12:34 PM
Awong124's Avatar
Thanks for the reply. A rule of thumb I usually go by with the UTQG wear rating is multiply the number by 200 to get the life of the tire in km. But where I live we get so much rain the life becomes significantly longer. The original set of Goodyears I used year-round on my old Ford Windstar lasted over 100,000km and still had quite a bit of tread left when I replaced it with Bridgestone Turanzas. Those Goodyears had a UTQG rating of 350.
2006 Mazda 6 Sport GT-V6 MT
Awong124 is offline
post #262 of 564 (permalink) Old 06-16-2007, 09:10 PM
posttosh's Avatar
Quoted: 27 Post(s)
Groaned at 3 Times in 2 Posts
Interesting thoughts. So do you (and anyone else) actually recommend "downsizing" to 205/50 or 55 on stock or equivalent wheels?[/b]
Yes to the 205/55, if the chosen tire is the Yokohama ADVAN Sport. No to a 205/50 of any brand.
posttosh is offline
post #263 of 564 (permalink) Old 06-16-2007, 10:51 PM
firedawgs's Avatar
Just put on the car:
Toyo T1R 225/45/18
firedawgs is offline
post #264 of 564 (permalink) Old 06-16-2007, 11:41 PM
posttosh's Avatar
Quoted: 27 Post(s)
I think what he's saying is Advans at 205/55 *could* outhandle Toyo T1-R at 225/45. And I seriously doubt that is consistently repeatable with the larger (more flex-susceptible) sidewall
Of course, if he means 205/55 will always outhandle 225/45 of any given kind of tire, he's high
Oh, btw - even IF he were right on the first one - I *only* want 225/45 or even 215/45 or 215/50 - not 205/55.
As far as rotational diameter goes, all these sizes are close enough to be just fine - in fact, even on my 16s, I run 215/55 [/b]
O.K.: Let us assume that a 205/55 tire has a section width of exactly 205mm and an aspect ratio of exactly 55 percent. (Actually, it has a section width anywhere between 200mm and 210mm and an aspect ratio anywhere between 52.5 percent and 57.5 percent. See the sidebar below.) Let us also assume that a 225/45 tire has a section width of exactly 225mm and an aspect ratio of exactly 45 percent. Then the length of the sidewall of a 205/55 tire is 205 x 0.55 = 112.75mm, and the length of the sidewall of a 225/45 tire is 225 x 0.45 = 101.25mm. In that case, the difference in length between the sidewalls is 11.5mm, or 9/20th inch, not that much a difference in the greater scheme of things. However, on a 7" rim, the sidewall of the 225/45 tire will be cinched in like this: \ /, whereas the sidewall of the 205/55 will be closer to straight up-and-down, like this: ||. The 205 is more likely to handle in a symmetrical manner in response to lateral forces than the 225/45 will (on the 7" rims) for that reason alone. The concept is explained, in somewhat different terms, at this link.
As to flex susceptibility, many other factors than length enter in. Most high performance tires -- including the Yokohama ADVAN Sport -- have inserts in the sidewalls to fine-tune the flex. A "touring" tire with an identical sidewall length to an ultra-high performance tire will, mounted on the same rims, have more flex, in order to give a softer ride. The technology is in place to give a tire whatever flex is appropriate, more or less without regard to the sidewall length (within reasonable parameters, of course). As you undoubtedly know from your experience with the Toyo T1-S, they give an outstanding ride and good road roughness absorption, at the (acceptable to many) cost of a little vagueness in steering precision -- at least that was my experience with those tires in the 225/55R16 size. However, that size is one of the sizes in which Toyo employed polyester as the body (carcass) plies. Perhaps the sizes in which Toyo used rayon for the carcass material handled more precisely.
The fact is, among tires that fit on a 7" rim, a 45 aspect ratio is too short for any tire that has an adequate load index for a Mazda6. If you want a 225 section width on a 7" rim, you should go wth a 225/50. Or, if you want a 225/45, you really should be looking at a 7.5" rim. (The 215/45, if you could find one, would bee too small, and effectively would alter your gear ratios.)
The contact patch of a 205/55R17 tire inflated to 35 psi will be the same size as the contact patch of a 225/45R17 tire inflated to 35 psi -- the same amount of "rubber on the road" -- but the shapes of the respective contact patches will be different. The 45-series tire will be more susceptible to outside inputs (from the steering wheel or from irregularities in the pavement) to effect a change in direction, compared to the 55-series tire. Conversely, compared to a 225/45, a 205/55 will have more of a gyroscopic action ("wanting" to stay pointed in the direction they are rotating) than the 225/45 will, and will tend to track better. That will make the steering of the 205/55 a bit less "twitchy," thus requiring fewer micro steering corrections, than the 225/45 when traveling down a straight road, all other factors being equal.
SIDEBAR: as to the precision of a specific size designation, let us compare two 205/55R17 ultra high performance tires, the Michelin Pilot Sport PS2 and the Continental ContiSportContact 2. According to the respective manufacturers' data sheets, the 205/55R17 Continental will get 844 revolutions per mile, and the 205/55R17 Michelin will get 803 revolutions per mile, which indicates a 5.1 percent difference in overall diameter of the respective mounted tires. Plug that into your on-line tire size calculators.
posttosh is offline
post #265 of 564 (permalink) Old 06-17-2007, 10:16 AM
Six-wheeler's Avatar
Send a message via MSN to Six-wheeler
(The 215/45, if you could find one, would bee too small, and effectively would alter your gear ratios.)[/b]
Not that I disagree - after my brief experience with 215/50 on 17x7, I think this size is more appropriate - but if what you're saying is true, then why did the 6 sold in our part of the world have 215/45R17 as the "stock" size?
Shady
1994 Mercedes E320 sedan. How it's done right.
2009 JDM Mazda 6 2.5 MTX #1. Most people are mediocre by choice. I'm not most people.
2009 JDM Mazda 6 2.5 MTX #2. A fool and his money - but it is his money.
1991 Mitsubishi Lancer 1.5 GLX-i sedan. Mom's. Don't ask.
Six-wheeler is offline
post #266 of 564 (permalink) Old 06-17-2007, 10:30 AM
posttosh's Avatar
Quoted: 27 Post(s)
after my brief experience with 215/50 on 17x7, I think this size is more appropriate - but . . . then why did the 6 sold in our part of the world have 215/45R17 as the "stock" size?[/b]
Beats me
posttosh is offline
post #267 of 564 (permalink) Old 06-18-2007, 03:36 PM
ashutoshsm's Avatar
Send a message via AIM to ashutoshsm Send a message via Yahoo to ashutoshsm
Not that I disagree - after my brief experience with 215/50 on 17x7, I think this size is more appropriate - but if what you're saying is true, then why did the 6 sold in our part of the world have 215/45R17 as the "stock" size?[/b]
The American car-buying public likes cushier rides -hence the greater sidewall.
I believe the two available optional wheel/tire sizes in Europe (in 15 and 16) match the 215/45-17 ratio better. And that the car's gearing is designed to use those.
I don't doubt they've recalibrated the speedos installed on North American 6's for 215/50-17 and 205/60-16, though!
-ashu
Wheels, tires, fluids and roof-mounted bike/ski rack. That's enough mods for me!
ashutoshsm is offline
post #268 of 564 (permalink) Old 06-29-2007, 10:08 PM
Grantsfo's Avatar
235/40/18 Falken Azenis Sport RT 615. Just had them installed today on 18x7.5 rims. Yeehaww!
2006 Mazdaspeed 6 GT
The Hiroshima Hippo!
Grantsfo is offline
post #269 of 564 (permalink) Old 07-06-2007, 12:08 AM
forrest's Avatar
Send a message via AIM to forrest
Just put 'em on today:
MazdaSpeed forged 18 x 7.5 rims with Toyo Proxes T1R 215/45-18 93Y.
Yeah, light rims and finally some good tires!
MS6 GT Whitewater Pearl Mica Nav SR
forrest is offline
post #270 of 564 (permalink) Old 07-06-2007, 08:14 AM
Vault172's Avatar
Send a message via AIM to Vault172 Send a message via MSN to Vault172
225/50/R17 Bridgestone Potenza RE960 AS Pole Position tires (4) installed last night.
Pics and thoughts to follow....
2004 6 Sport Wagon - Glacier Silver - MTX - Bose - Moonroof - 2 Rockford 12" HE2s - Rockford 1500 watt amp - Escourt Passport 8500 X50 Blue - Sirius
Vault172 is offline
