Choosing the Right Size Tire - Page 29 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #281 of 304 (permalink) Old 02-27-2014, 11:10 AM
dan.lotfy's Avatar
Quoted: 18 Post(s)
Originally Posted by Akira View Post
Even tho the streched look is sick; I cant go that route.
Could you post some pix?
DaN
Mazda 6 '14 - Blue Reflex
SkyActive G 2.5
19" Grand Touring
dan.lotfy is offline
post #282 of 304 (permalink) Old 02-27-2014, 11:14 AM
Akira's Avatar
Quoted: 77 Post(s)
I literally just purchased the wheels so I wont have them for atleast a week
Akira is offline
post #283 of 304 (permalink) Old 03-01-2014, 12:05 PM
changing my tire size
Hello.I am new to the site. I have read the post on tire sizes. However. I would like to change the tires that came on my car from 225/40/18 to a 225/45/18. Can I do this without modifying my fenders? I have a 2005 mazda 6s. Thank you for your help in advance.
bmwlife1995 is offline
post #284 of 304 (permalink) Old 03-28-2014, 11:16 PM
Original rims what tire?
On my original MS6 rims which tire can I use it? 225-45-18 or 225-40-18
mazda64 is offline
post #285 of 304 (permalink) Old 04-07-2014, 11:06 PM
Hello, I just bought a 2005 Mazda 6. It has the stock 17" wheels with 215-50-17 tires. I am due for new tires and want to keep the stock wheels but was wondering what size tire would give the best handling. Thanks! Brenda
Mazda Sixx is offline
post #286 of 304 (permalink) Old 04-18-2014, 10:50 PM
My 2006 6s sport has stick 215/45/18. But I'm thinking of going to a 225/40/18 with a wider wheel
xrazrbulletx is offline
post #287 of 304 (permalink) Old 04-19-2014, 04:15 PM
Quoted: 143 Post(s)
Groaned at 6 Times in 6 Posts
Nice contribution, very good-- Solid facts--- no BS. Thanks Oldvet
Oldvet is offline
post #288 of 304 (permalink) Old 09-21-2014, 06:32 PM
Quoted: 25 Post(s)
I have a problem with aftermarket 17's I have on my 1st gen 6, I have P225-45-R17's on there and if I go over a bump the wrong way, even on a straight stretch, the back wheels are shearing rubber off where the sidewall meets the tread and tearing up the inner quarterpanel... the front has been fine so far... Are these tires not recommended or should i look at possibly faulty shocks in the rear? It seems predominantly in the rear right but is visible on the rear left.
Also if it's relevant, the tires are a full set of Continental ContiPro's and the rims are a either an 8 or 8.5 inch wheel base, I believe it's 8.5
Last edited by DragonLord3688; 09-21-2014 at 06:44 PM. Reason: Tire description + rim info
DragonLord3688 is offline
post #289 of 304 (permalink) Old 09-21-2014, 09:18 PM
HerronScott's Avatar
Quoted: 154 Post(s)
Check out this post.
Stock Wheel & Tire information
Mentions that you may need to roll the rear fenders with wider tires and/or aftermarket rims with a different offset.
Original factory 17" rims.
17x7 (60mm, 21.1lbs)
Tire - Michelin Pilot HX MXM4 215/50/17
Scott
2004 Mazda 6s GT MTX sports package
HerronScott is offline
post #290 of 304 (permalink) Old 09-22-2014, 12:49 AM
ctmazda's Avatar
Quoted: 291 Post(s)
Groaned at 5 Times in 5 Posts
Yeah it sounds like you just need to roll your rear fenders. It's a very quick and easy process and will completely eliminate the issue you are having as long as they are rolled all the way down to the bottom of the side skirt, close to where you are getting rubbing when the suspension compresses.
Without the rear fenders rolled, the tolerance for any non oem spec wheel is tight and more or less hit or miss wether you will rub or not.
Sent from AutoGuide.com App
2004 Mazda 6 Sport V6 MTX-Steel Grey
MSDS Headers/Ported Intake Manifolds + 1/2" Spacer/Injen CAI/3.7L OTB/TGNY TB Spacer/Magnaflow CBE/AWR 88 Mounts/Rotora H2 Ceramic Brakes//CF Evo Hood,Grill,Eyelids,Window Visors,Mirror Covers/CAR-LED Tails/35W 5000k HIDs/55W 6000k Integrated Fogs/LED Fogs/1000w Xplōd Amp/Two 800w 12" Xplōd Subs/15% Tints/18x8.5 +50 Kazera "CF" Rims/Hankook Ventus Evo 245/40/18
Future Mods:Powermod Tuner/Custom DoubleDin/BC Coils
ctmazda is offline
