Choosing the Right Size Tire - Page 24 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #231 of 304 (permalink) Old 04-18-2010, 04:18 AM
Can someone help?
CX7 18 X 7.5 50 offset will 225/45/18 fit with this wheel on a 2.3 Mazda 6 Hatch 2007?
Thanks
Gaz
gazoom is offline
post #232 of 304 (permalink) Old 04-22-2010, 04:37 PM
I would appreciate some assistance. I have a 2004 mazda 6 with 215-50-R17 all seasons needing replacement. I can't find a decent replacement in that size, but can find 205s or 225s (other specs the same). I see the 205s are not onthe tire list here-but I have varying opinions as to what would be best here-Any Advice?
grluce is offline
post #233 of 304 (permalink) Old 04-26-2010, 08:38 PM
yvkostad's Avatar
iv read over the thread and have even tried out the prescribed size of 225/45/18 on my 18in x 8.5 width. Unfortunately that size was far to skinny for my 8.5 width tires. since then iv check and rechecked the thread and gone to numerous shops with little success on what size is the right size for my wheels. thus far iv narrowed it down to 235/40 or 245/40....any thoughts on this....am i far off...please help a desperate man out.
~Unity Renders Power~
yvkostad is offline
post #234 of 304 (permalink) Old 04-26-2010, 08:51 PM
JML
JML's Avatar
There are a good many "decent" tires in that size! 215/50-17 is the OEM size for the later iterations of the car, and while there are not 150 choices, there are plenty of very good all season replacements. Did you go to the Tire Rack site? There are 58 tires they carry in that size; 36 are all-season tires, at many prices.
2008 Mazda6 5-door i-Touring (Volcanic Red)
JML is offline
post #235 of 304 (permalink) Old 09-24-2010, 09:20 PM
I have a 2004 Mazda 6s Sedan, with the 6 cylinder engine. I am looking for replacement tires for my vehicle. The originals are the Michelin Pilot HX MXM4 size 215/50R17/93V on the original rims; I've done all my research and have been looking at tires in the same exact size, but most have load ratings of 95, instead of 93. Is it safe to use the 95 load ratings on my vehicle, I was considering the following tires: Bridgestone Turanza Serenity 215/50R17/95V; Continental Extreme Contact DWS --in size 215/50R17/95V or 95Z, -, MIchelin Primacy MXM4 size 215/50R17XL 93V BSW; yokohama S. Drive--215/50R-17 95W XL B;--Toyo PROXES- 215/50ZR17 95W (from what I've read I need a tire with a load rating of at least 93 and speed rating has to be V or Higher.) I'm looking for all season tires. I'm looking for a tire that handles well, and can provide decent winter traction as I live in Michigan! Which is a good tire that other people have put on their Mazda 6S's or another comparable tire that can be reccommended? Please help
zoomzoom2368 is offline
post #236 of 304 (permalink) Old 09-24-2010, 10:09 PM
MZR-6i's Avatar
Quoted: 55 Post(s)
Originally Posted by gazoom View Post
Can someone help?
Thanks
Gaz
yes they will fit...as long as your car is not lowered.......definate fender roll on rears.You can also go 225/40/18
2015 6i sport MT 6 speed
12k fog lights, MV-Tuning bodykit, CS Motor Mount, Antenza badged, H&R springs, CS adjust shocks, quad exhaust tips, Megan Front Strut bar, Varrstoen L151 20x10.5+40, Achilles ATR Sport tires 245|35|20
SOLD..
.. (tear) 04 6i HB, JDM EVO VIII wing....
MZR-6i is offline
post #237 of 304 (permalink) Old 09-25-2010, 10:09 AM
Mz6GreyGhost's Avatar
Quoted: 840 Post(s)
Groaned at 6 Times in 3 Posts
95 is fine. Going higher than a Load Rating of 93 is not a problem (91 with the 16" wheels), but going lower is not wise for a lot of reasons.
In case it helps, you can also look into tires with a Speed Rating of H as well. They are suitable for the 6, and they also tend to have a longer treadlife.
As far as your suggestions, if you're sticking to all-seasons, stick with the Continentals. I've heard nothing but good things about these tires, offering excellent dry and wet traction, along with outstanding snow traction for a performance all-seasons. The Bridgestone is more of a touring tire, which you may not like due to it's lower performance limits. Michelins as a whole are simply overrated and overpriced, and snow traction is a bit scary with the Primacys. The Yokos you listed are summer tires, so I wouldn't even consider them if you plan on driving in ANY snow/sleet/slush or any weather under 40 degrees. Summer tires in general are simply deadly in the winter.
You won't consider getting a separate set of winter tires?
Mz6GreyGhost is online now
The Following User Says Thank You to Mz6GreyGhost For This Useful Post:
zoomzoom2368 (09-25-2010)
post #238 of 304 (permalink) Old 09-25-2010, 04:17 PM
thanks for the help!
Yes I would consider a set of winter tires. What are some good winter choices for my car that you can suggest? Should I order tires with the rims attached, or just order the winter tires and have them put on my current rims. I'm not looking to spend a whole lot of money I'm thinking of staying with the 17" rims, two of my current 4 tires are pretty worn. I saw a post about performance winter tires. Thats probably what I would get.
post #239 of 304 (permalink) Old 09-25-2010, 08:42 PM
Quoted: 840 Post(s)
Personally, I'd find a set of cheap 16" steelies, or used 16" rims from a Mazda 3, 5 or 6 from a junkyard or Craigslist, and get a set of 205/60-16s (the OEM size) for winter tires. Not only are the 16" tires less expensive than comparable 17" tires, but you also save the wear-and-tear of both the tires and rims, as well as not having to pay $20 per tire, to swap them on and off your OEM rims twice per year. I bought a set of 16" steelies with tires from Tirerack when I first got my '04, and I'm using them again on my '10 (with newer winter tires).
As for winter tires, I ran the Dunlop WinterSport M3, and they were excellent winter tires, offering great traction and control in rain, snow, slush, etc. as well as offering excellent handling for any "spirited" driving on the drier, sunny days (unlike regular winter tires that tend to get "sloppy"). The replacements, the WinterSport 3D, are also very good, and are used by more than a few other 6 owners. Michelin also makes some decent winter tires, as well as Continental with their new ExtremeWinterContacts.
I'd shy away from Bridgestone Blizzaks, since I've owned two different sets of them, and I've found that the useful winter treadlife to be lower than other brands. I've gotten more seasons of useful winter traction from all other brands.
zoomzoom2368 (09-27-2010)
post #240 of 304 (permalink) Old 09-27-2010, 01:33 AM
Thanks for your help, Mz6GreyGhost
