Choosing the Right Size Tire - Page 16 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #151 of 304 (permalink) Old 11-24-2007, 02:47 PM
i am strongly considering getting some 5zigen lighweight wheels; 17x7. and have no idea what size tires to get. i think i had enough of my 18". no matter what kindaof tires i put on it and how many times i balance them they always feel like there out of balance; and i cant stand it anymore. time for a change.
werm9 is offline
post #152 of 304 (permalink) Old 11-24-2007, 07:57 PM Thread Starter
Tire Guy's Avatar
i am strongly considering getting some 5zigen lighweight wheels; 17x7. and have no idea what size tires to get. i think i had enough of my 18". no matter what kindaof tires i put on it and how many times i balance them they always feel like there out of balance; and i cant stand it anymore. time for a change.[/b]
Do your wheels have hub centering rings?
_______________
<div class='quotetop'>QUOTE
Tire Guy is offline
post #153 of 304 (permalink) Old 11-25-2007, 06:19 PM
ok here is a question.... 245 50 r16 technically fits on the stock 16 7 inches being the minimum width for it. but from what i can tell it wont fit on the car with the stockers due to the front spindle rubbing can anyone confirm this?
2003 6S 5 speed. 116000 miles. fidanza flywheel. specd stg 2 clutch . air box mod. rb springs and tok&#39;s for shocks. msds headers full exhaust with magnaflow resonator and dynomax super turbo&#39;s rb sway bars. ebay front strut brace 17x7.5 with 235 45 17 azenis and oh ya there is a lil headwork
235 whp 219 wtq (avg of 3 dynojet dynos) rpm rear and side smokes markers 8k 35w hids in lows and fogs. try as you might but you just cant keep up.
midastech390 is offline
post #154 of 304 (permalink) Old 11-25-2007, 06:21 PM
Do your wheels have hub centering rings?[/b]
im pretty sure they do. why?
werm9 is offline
post #155 of 304 (permalink) Old 11-26-2007, 06:46 AM Thread Starter
Tire Guy's Avatar
im pretty sure they do. why?[/b]
Just wondering if perhaps that&#39;s the cause of your vibration. I had 18 inch PIAAs on my other 6 and never had a problem with vibration. I have some RX-8 wheels that I&#39;ll be installing soon (I hope) and I don&#39;t expect any vibration problems, either. Vibration issues aren&#39;t something inherent to 18s, but anytime you install aftermarket wheels, you do run the risk of vibration issues to either hubcentricity or radial runout (depending on the quality standards of the wheels you bought). My point is that your vibration problems aren&#39;t simply because you have 18s, it&#39;s going to be something related to tire or wheel quality (or hubcentricity).
_______________
Tire Guy is offline
post #156 of 304 (permalink) Old 12-30-2007, 08:17 PM
Does anyone know roughly how much difference there is in fenderwell clearance between the standard 6 and MS6?? In this thread some of the sizes listed as "won&#39;t work" are commonly used on an MS6. 215/50/17 is said to be borderline at best, but that&#39;s a hair smaller in diameter and obviously no wider than the stock 215/45/18. So there must be a little more room in the MS6s.
HiOfficer is offline
post #157 of 304 (permalink) Old 01-16-2008, 09:10 PM
just wondering what size tire is best suited for a 18*7.5 wheel with 45et and if ill have any problems with rubbing if the fenders are not rolled.im looking at the enkei lm1 for a 06 s .thanks
allan is offline
post #158 of 304 (permalink) Old 01-16-2008, 09:37 PM
Jax6S's Avatar
just wondering what size tire is best suited for a 18*7.5 wheel with 45et and if ill have any problems with rubbing if the fenders are not rolled.im looking at the enkei lm1 for a 06 s .thanks[/b]
From the first page:
215/45R18 7.0"-8.0" 35 psi (6s, 6i), 38 psi (Mazdaspeed6) *original equipment size*
225/40R18 7.5"-9.0" 38 psi
225/45R18 7.0"-8.5" 38 psi
If you want to be safe, pick 215/45R18
2006 Black Mazdaspeed6
Jax6S is offline
post #159 of 304 (permalink) Old 01-16-2008, 09:50 PM
If you want to be safe, pick 215/45R18[/b]
thanks bro does the load rating have to be 91 and higher as i have found the 215 18 with a rating of 89
allan is offline
post #160 of 304 (permalink) Old 01-16-2008, 10:10 PM
Jax6S's Avatar
thanks bro does the load rating have to be 91 and higher as i have found the 215 18 with a rating of 89[/b]
yes, 91 is recommended. See sticky
Jax6S is offline
