Members Wheels - Page 38 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 8Likes
post #371 of 514 (permalink) Old 09-14-2009, 11:46 PM
xGiLBE33's Avatar
QUOTE (nate0123 @ Sep 9 2009, 10:58 AM)
I asked in PM and didn't hear back.[/b]
if i had to guess... either rva or nova. cuz i definitely havent seen him in the 757 area..
xGiLBE33 is offline
post #372 of 514 (permalink) Old 09-18-2009, 01:59 PM
Ok, so I need winter tires on steel rims, I found a good deal on some winters from a Ford Fusion..
Our stock 16" steel rims"
Offset: 55mm
Backspacing: 5.90"
Bolt Pattern: 5-114
Rec. Tire Size:205/60-16
Stock Ford Fusion 16"
Offset: +42mm
Backspacing: 5.43"
Bolt Pattern: 5-114
I see plenty of people in here with +42 offset wheels, but not sure about the backspacing
The_Trader is offline
post #373 of 514 (permalink) Old 09-18-2009, 02:16 PM
Six-wheeler's Avatar
Send a message via MSN to Six-wheeler
It's not the backspacing you should worry about. With rim width (6.5) being equal, From 55 to 42, you'll have 13mm of extra backspacing, so no worries there.
What you should worry about, however, is rubbing. Despite the fact that they will physically fit on the 6, the Fusion's wheels will stick out 13mm more than Mazda's OE steel wheels in relation to the wheel wells and fenders. And with the inherent sidewall "bulge" of the 205/60 tire size, you will run the risk of rubbing.
Another thing you should consider is center bore. I haven't made actual measurements, but from what I saw, when I considered buying a set of Milan (same as Fusion) wheels to use on my old 6, the center bore appeared to be significantly bigger than that of the 6 (67.1mm).
So it might not be that good of a deal after all. Should you actually go for the Fusion's wheels (with rubbing issues notwithstanding), you'll need to spend extra money on buying (or even fabricating) centering rings. And those are especially tricky to use with steel wheels.
Another issue. With such as "extreme" offset as that of the Fusion's wheels (as compared to the 6), there will be abnormal stress on the lower ball joints. To put it as simply as possible, road forces will load the ball joints a bit sideways, causing them to be stressed more to one side instead of being loaded equally. I once used wheels with a 40mm offset, and had to change the lower ball joints (entire control arms, actually) twice in 10,000 kilometers! Not good!
Shady
1994 Mercedes E320 sedan. How it's done right.
2009 JDM Mazda 6 2.5 MTX #1. Most people are mediocre by choice. I'm not most people.
2009 JDM Mazda 6 2.5 MTX #2. A fool and his money - but it is his money.
1991 Mitsubishi Lancer 1.5 GLX-i sedan. Mom's. Don't ask.
Six-wheeler is offline
post #374 of 514 (permalink) Old 09-18-2009, 02:27 PM
QUOTE (Six-wheeler @ Sep 18 2009, 03:16 PM)
Another issue. With such as "extreme" offset as that of the Fusion's wheels (as compared to the 6), there will be abnormal stress on the lower ball joints. To put it as simply as possible, road forces will load the ball joints a bit sideways, causing them to be stressed more to one side instead of being loaded equally. I once used wheels with a 40mm offset, and had to change the lower ball joints (entire control arms, actually) twice in 10,000 kilometers! Not good![/b]
Thanks for the awesome response, time to keep on looking!
post #375 of 514 (permalink) Old 09-22-2009, 05:21 PM
Send a message via AIM to tinkerbell22 Send a message via Yahoo to tinkerbell22
QUOTE (critical6 @ Jan 17 2005, 08:32 AM)
...in my defense (since i dont like people posting about their rims and not posting photos of them on their cars)
what are the name of these wheels? They are HOT!!!
tinkerbell22 is offline
post #376 of 514 (permalink) Old 09-26-2009, 06:32 PM
Divinity D-66 18x7.5 +40
Nankang NS-II 215/40/18
Lowered on Mazdaspeed Springs (not fully settled)
No rubbing as of yet..
TaddO 2 is offline
post #377 of 514 (permalink) Old 10-25-2009, 10:47 PM
hi everyone i got a 18 x 8.5 +45 w/ a 225/40/18 tire. what do you guys think?
[attachment=44230SC04883.JPG][attachment=44231SC04884.JPG][attachment=44232:
DSC04885.JPG][attachment=44233SC04879.JPG][attachment=44229SC04881.JPG]
ID:	73436   Click image for larger version
ID:	73437   Click image for larger version
ID:	73438   Click image for larger version
ID:	73439   Click image for larger version
vader_6 is offline
post #378 of 514 (permalink) Old 10-25-2009, 11:15 PM
nate0123's Avatar
Send a message via AIM to nate0123
Hard to tell much from that picture, aside from the tire not really being wide enough for the rim, and your ride height being accentuated by the aftermarket wheels.
2003 Mazda6 S 3.0 5-speed Manual
Mazdaspeed Hatch/Wagon Springs | OEM Mazdaspeed6 Shocks | Cordova Motorsports Optimized Throttle Body | CP-E Wishbone Motor Mount | Magnaflow Catback Exhaust | 17x7 Mazda MX-5 Wheels | 225/50-17 Toyo Proxes4 Tires | Clear Sidemarkers | OEM Mazdaspeed6 Tail Lights | AudioLink iPod Adaptor | Protege5 Leather Shift Knob
nate0123 is offline
post #379 of 514 (permalink) Old 10-25-2009, 11:28 PM
yeah i know but li like the look and the ride is ok. i added some pic. im new to this forum so dont know how to post a descent image still having problem in sizing up the image...
vader_6 is offline
post #380 of 514 (permalink) Old 10-26-2009, 02:34 AM
Banned
car DVD player online store
7 inch monitor touch High Definition (HD) screen Mazda 3 Car DVD Player with GPS Navigation System Bluetooth TV
Product Description:
7 inch monitor touch screen double-Din complete car entertainment system
Compatible with DivX,MP4,MP3,multiple regions DVD, VCD, CD and CD-R/CD-RW
Built-in GPS function and Bluetooth for hands free call (play CD/DVD/FM while watching GPS navigation image)
Keys with touch sensor
OSD menu with graphical user interface
USB port and SD slots
Built in TV tuner,PAL/NTSC or SECAM compatible
Built in FM/AM tuner,OS: WIndows CE 5.0
Warranty:One year
ashona is offline
The Following User Says Thank You to ashona For This Useful Post:
SteelTech6 (05-26-2011)
