The Best Suspension Upgrade Under $300? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 2Likes
  • 1 Post By idrive
  • 1 Post By DJ Raydiate
post #1 of 8 (permalink) Old 06-17-2019, 04:05 PM Thread Starter
Modzas6x's Avatar
Quoted: 35 Post(s)
Talking The Best Suspension Upgrade Under $300?
So the CorkSport Rear Sway Bar has dramatically transformed the 6's handling. Even stock suspension of the 6 is really good, but with the RSB it has almost no body roll even in very sharp turns and cornering. The only problem is that it has slight interference with the control arm, but it is not too severe and only rubs slightly in certain scenarios.
CorkSport Rear Sway Bar Video:
(interference shown at the end)
Youtube:
Website:
eBay profile:
Instagram:
2015 Mazda 6 Sport
-2.5L/AT
Mod List
1. Debadge (lol) 03/09/2019
2. Interior LED's 03/16/2019
3. Front Strut Tower Bar 03/23/2019
4. Front License Plate Delete (lol) 03/24/2019
5. CorkSport Axelback Exhaust 03/29/2019
6. CorkSport Rear Sway Bar 06/15/2019
Modzas6x is offline
post #2 of 8 (permalink) Old 06-17-2019, 04:56 PM
DJ Raydiate's Avatar
Quoted: 101 Post(s)
Where on the arm and or bar is it hitting? Are you ever going to use the 2nd hole or no? If it's just that very end hitting the arm, I'd just take a grinder to the end and shave it a little bit. Even if you go to use the 2nd one, a little bit of shaving shouldn't ruin the integrity of the bar. If you do grind it or the arm, just remember to touch up the paint to prevent rusting.
Ray.
2003 6s
DJ Raydiate is offline
post #3 of 8 (permalink) Old 06-17-2019, 06:22 PM Thread Starter
Modzas6x's Avatar
Quoted: 35 Post(s)
The right side of the end piece. I don’t think it’ll be a huge problem so I may leave it alone, but yeah the only solution I’ve heard of so far is to shave off part of the second hole (which I wouldn’t be using).
Youtube:
Website:
eBay profile:
Instagram:
2015 Mazda 6 Sport
-2.5L/AT
Mod List
Modzas6x is offline
post #4 of 8 (permalink) Old 06-17-2019, 08:11 PM
Quoted: 101 Post(s)
Personally I'd rather shave it and make them clear than to leave it alone to make them clear on their own. I don't like things hitting each other when it comes to the suspension lol.
Ray.
2003 6s
post #5 of 8 (permalink) Old 06-17-2019, 08:40 PM Thread Starter
Modzas6x's Avatar
Quoted: 35 Post(s)
Same here but idk if it affects the integrity of the sway bar I guess that’s my biggest concern.
Youtube:
Website:
eBay profile:
Instagram:
2015 Mazda 6 Sport
-2.5L/AT
Mod List
Modzas6x is offline
post #6 of 8 (permalink) Old 06-18-2019, 12:11 AM
idrive's Avatar
Quoted: 300 Post(s)
Groans: 6
I'd get the Dremel out and grind it down. If it needs more than you're comfortable shaving off I'd send it back.
The Ultra Racing on our 6 has zero issues and looks to be the same size as the one pictured but I don't remember it having two different mounting options.
The Hellwig on my Truck has three different mounting options.
DJ Raydiate likes this.
Build Thread:
idrive is online now
post #7 of 8 (permalink) Old 06-18-2019, 10:22 AM
Quoted: 101 Post(s)
Welcome to the world of custom automotive!! Sometimes when we install aftermarket parts, some things may need to be modified for it to fit and or work.
That very end is not doing anything to help the integrity of the the entire bar. If it was hitting something in the middle of the bar, that is a little different depending where it is hitting and how much and what would need to be shaved.
If it is hitting someting, it is limiting the full travel of the suspension. Even if it hits only in certain situations, it's still limiting it. Who knows, one day when you get more comfortable with the new driving abilities of the 6 and you decide to do a track day or an autox day, you will be limited by it hitting.
I'd still say shave either the bar, the arm or a little bit of both. You want full travel of the suspension for when those days come. It could come in handy on the streets as well. I've had to "whip" my 1st gen several times in the 4 years that I've owned it to avoid accidents here where I live. The last thing I want while trying to avoid an accident is to be tapped out on anything dealing with brakes, tires, and suspension.
Do yourself a favor and go ahead and get rid of the interference I honestly think that you are doing more harm potentially leaving it as is vs shaving the bar just a little.
idrive likes this.
Ray.
2003 6s
post #8 of 8 (permalink) Old 06-22-2019, 08:35 PM
deadBattery's Avatar
CorkSport is notorious for poor quality control. You saw it in the video. It's too wide. Had it been built properly, it would be exactly the same width. I'd send it back and demand one that is correct. BUT, I know what a pain it is to install. I put one on my '14 - 6 and the end link holes were too big. It would clunk in hard turns as the bolt shifted around. No amount of tightening would fix it. I sent it back and bought a JBR (James Barone Racing) bar. Sweet!
2014 Mazda 6 Touring
deadBattery is offline
