Different brake systems on the Mazda6? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 5Likes
post #1 of 18 (permalink) Old 05-16-2019, 06:13 AM Thread Starter
Hi Guys
I have been lurking in this forum for some while now. I have a 2005 Mazda6 Sport with the 2006 facelift. Love the car but it needs a few repairs from time to time.
The issue at hand is that I need a new front left brake caliper since the old one is worn and sticking.
But here comes the wierd thing why the many different brake systems?
On a page with spare brake calipers i have encountered at least these brands for the brake system: Akebono, Shin Tec, NBK, Nabteco?
What is the difference between these? And how do I figure out which one I need? Why so many available haven't seen that before?
I replaced the brake pads and rotors not long ago and I got Akebono pads then. They fit perfectly. But can I then assume that the caliper is also Akebono?
Regards
PommFritz is offline
post #2 of 18 (permalink) Old 05-16-2019, 07:52 AM
DJ Raydiate's Avatar
Quoted: 92 Post(s)
I don't think you need to worry about the brand vs the application. There are many brands for different parts but they should all be within Mazda specs. The 1st gen can be confusing when it comes to the brakes because they were still "figuring it out". When getting brake parts, as long as you get the right ones for your system, it could have whatever brand name it wants.
The main things to note are 03-05 or 06-08, ABS or non ABS, and Mazdaspeed or non Mazdaspeed.
The cool thing to also note is if you have the original 03-05 system, swapping to 06-08 from the hard lines down is a little upgrade because they are a little bigger. From what I've read, swapping from the 03-05 system to a Mazdaspeed system is an even bigger upgrade.
Ray.
2003 6s
DJ Raydiate is online now
post #3 of 18 (permalink) Old 05-16-2019, 07:56 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2883 Post(s)
Just to remind people looking at this thread - he's up in Denmark, which is most likely why the brands he has up there are different than what most of us in the U.S. see.
I would say, if you're not sure, then go with the brand that you already know fits the car.
Typically, there will be several manufacturers who develop sets of parts for many cars. It's common to find at least a few who make identical parts for the same car. For example, RockAuto alone has Power Stop, Centric, Raybestos, Nugeon, Beck/Arnley, ACDelco, and Cardone all listed as having calipers/parts for the 2006 Mazda 6.
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #4 of 18 (permalink) Old 05-17-2019, 02:39 AM
Quoted: 434 Post(s)
Below are the 2006 MPS brakes on the 2004 6 wagon. They are behind 18inch wheels.
If the brakes bolt on and clear all the moving bits then it will work. The above modification was the same as doing a brake job and the improvement was huge.
I would choose the part based on warranty and reviews. All will likely work well.
Name:	2004 Mazda 6 with 320mm Mazdaspeed 6 brakes and RX8 18ince wheels.jpg
Mozz-D
DrFeelGood is offline
post #5 of 18 (permalink) Old 05-17-2019, 08:40 AM
b1lk1's Avatar
Quoted: 312 Post(s)
Groans: 20
If you used all speed brake calipers I hope you switched the master cylinder too as it has a larger bore to deal with the need for more pressure and volume for the bigger calipers.
b1lk1 is offline
post #6 of 18 (permalink) Old 05-17-2019, 01:31 PM
Quoted: 434 Post(s)
Thanks @1blk1 for the thoughts. Since I am disk/disk (1-piston) to disk/disk (1-piston) and I don't race the car I was not interested in increasing my pedal effort with the larger bore of the speed 6 unit. While it's true it may reduce my pedal slack a fraction, I have never felt these brakes to have excessive travel before braking contact. The stock master cylinder has no problem achieving 1200+ PSI before or after the upgrade.
What I have now is significantly reduced stopping distance at the same pedal pressure (relative) and the same stopping as before with reduced pedal pressure (relative).
Cheers.
Mozz-D
post #7 of 18 (permalink) Old 05-17-2019, 02:00 PM
b1lk1's Avatar
Quoted: 312 Post(s)
Groans: 20
It has nothing to do with pressure. You would not feel a difference in the pedal between the 2. The key difference is volume, the larger calipers require more volume, not more pressure.
I'm not saying it is dangerous, I am saying you are leaving some of the advantages of the larger brakes off the table as without the higher volume of fluid they simply will not push as hard as they could. If you think those brakes are great now you would very likely be quite surprised once the proper master cylinder is put in. Your choice, but you are leaving a fair bit of performance by not doing this.
b1lk1 is offline
post #8 of 18 (permalink) Old 05-17-2019, 02:51 PM
Quoted: 434 Post(s)
Thanks for the comment. I disagree, as pressure is the only thing it is about. That is the very nature of hydraulic systems. Volume just ensures that as the pads wear down the system doesn't drop low and suck air. Volume does not push the piston out, pressure does. And for pedal feel, a 0.25 in increase in diameter will increase pedal force (to do the same work) by just over 75%
Thanks for letting us disagree.
Back to our previously scheduled thread.
Mozz-D
post #9 of 18 (permalink) Old 05-17-2019, 03:20 PM
b1lk1's Avatar
Quoted: 312 Post(s)
Groans: 20
Doesn't matter if you post it twice, it does not make it right. Volume is just as important if not more important, especially for rear brakes. It was more obvious on 80's/90's trucks with 1/4 " rear lines to feed the massive 13"+ drum brake systems. They simply required more volume.
As for Speed6 brakes with a stock 6 master, you are not pushing the same amount of fluid with the stock master. You get the SAME pressure with MORE volume with the Speed master. If you cannot grasp that you are trying to fill up bigger calipers with an undersized pump (master) then it should make more sense. The Speed6 master is identical in every way except for bore. This in no way effects pressure. It only effects volume.
It is simple science, Google is your friend if it still doesn't add up.
b1lk1 is offline
post #10 of 18 (permalink) Old 05-17-2019, 03:33 PM
jman1200's Avatar
Quoted: 90 Post(s)
jman1200 is offline
Similar Threads
2014+ Mazda6 12.6" 4 Piston Performance Big Brake Kit MadStyle Suspension / Brakes 38 01-18-2019 05:47 PM
2003-2005 MAZDA6 Antenna Mast, Undercarriage Panel and Brake Fluid Reservoir Cap MAZDA6305 Want To Buy 4 04-27-2013 07:53 AM
3rd-Gen (2013/2014) Mazda6 bziko98 3rd-Gen 1373 04-23-2013 10:53 AM
FS: Mazda6 Mint Hawk HPS Brake Pads and Sparco 4pt Harness Titanium6 Buy/Sell 8 06-16-2006 11:37 AM
Rotora GB: Rotors, Brake Kits, SS Lines, Pads, More! PRacing Vendor Deals 6 03-19-2006 01:48 PM
