Replaced Factory Rotors and Pads with EBCs - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 2Likes
  • 1 Post By Jerrycobra
post #1 of 6 (permalink) Old 03-19-2019, 07:15 PM Thread Starter
Jerrycobra's Avatar
Quoted: 307 Post(s)
So as its already common knowledge the stock brakes on the 3rd gen suck, i got the pulsing brakes right on schedule between 30 to 40k miles. I decided to finally replace them with a set of aftermarket EBCs last Nov. The front is the ultramax slotted rotors with redstuff pads, P/N S4KF1663 , and rear I just threw in red pads, P/N DP32171C. If you researched earlier brake threads there was some issues with suppliers sending the wrong rear redstuff pads and that they were not available, well I can now safely say that DP32171C are in production and does fit 2014-2015 3rd gen 6s, but I can't guarantee they will work with the updated 2016+ model with the electronic E brake.
As far as braking performance goes these are great, no squealing, plenty of stopping power, my limiting factor of stopping distance is the crappy OEM tires I still have(will replace very soon). The only downside these have is when they are cold they don't stop as well, they need heat to work their best.
Also as a word of caution, I ran into an issue with air getting stuck inside the dust boost when I was reseting the front brake pistons, so they were sticking out. Not knowing how to fix it I just tried to finesse the pad into place to not pinch to boot. Then I found this youtube video:
Well I took the pads out to check and ended up pinching and tearing one of the boots, and wished I found that video earlier. Anyways I was able to find a caliper rebuild kit (Centric P/N 143.45028)and just replace the boot without needing to replace the whole caliper for a silly mistake. So learn from my mistake, don't do it again like me.
Name:	new brakes.jpg
DrFeelGood likes this.
2014 Mazda 6 Touring Liquid Silver
[ OVT 91 octane tune ][ CS Power Series SRI+Airbox ][ Racing Beat Axleback ][Paddle Shift retrofit][ Morimoto XB35 35w 5000k HID lows ][ LED interior lights and plate lights ][ 3M FX HP Tint ][ Dipped rims and dipped trim ]
Jerrycobra is offline
post #2 of 6 (permalink) Old 03-19-2019, 08:52 PM
Archerfish's Avatar
Quoted: 135 Post(s)
Originally Posted by Jerrycobra View Post
... I can now safely say that DP32171C are in production and does fit 2014-2015 3rd gen 6s, but I can't guarantee they will work with the updated 2016+ model with the electronic E brake.
You got me excited until you mentioned the E brakes...
Archerfish is offline
post #3 of 6 (permalink) Old 03-19-2019, 09:11 PM Thread Starter
Jerrycobra's Avatar
Quoted: 307 Post(s)
parts sites are quoting DP32287C for 2016+ models, but the official EBC catalog does not reflect that yet.
calcaneous likes this.
post #4 of 6 (permalink) Old 03-19-2019, 09:14 PM
Quoted: 430 Post(s)
Those are pretty sweet!
Mozz-D
DrFeelGood is offline
post #5 of 6 (permalink) Old 03-19-2019, 09:50 PM
Banned
Quoted: 560 Post(s)
Groans: 5
Groaned at 48 Times in 41 Posts
thats what mechanics are for
Mazda6Suspension is offline
post #6 of 6 (permalink) Old 05-17-2019, 01:35 PM
fireandicekarim's Avatar
Quoted: 46 Post(s)
Also as a word of caution, I ran into an issue with air getting stuck inside the dust boost when I was reseting the front brake pistons, so they were sticking out. Not knowing how to fix it I just tried to finesse the pad into place to not pinch to boot. Then I found this youtube video: https://www.youtube.com/watch?v=ezYhKfiTcBw Well I took the pads out to check and ended up pinching and tearing one of the boots, and wished I found that video earlier. Anyways I was able to find a caliper rebuild kit (Centric P/N 143.45028)and just replace the boot without needing to replace the whole caliper for a silly mistake. So learn from my mistake, don't do it again like me.
Unfortunately, I did the EXACT same thing with the dust boot and tore both my fronts thinking I set them back properly. Living in the NE I knew it would be a bad idea to not replace these.
So yup, I bought two seal replacement kits and rebuilt the two front calipers. Not a fun experience to be honest, but it was interesting to learn how to do that. Also just like you, I saw this video right after I tore the seals.
Excalibur - 2014 Snowflake White Pearl Mazda 6
fireandicekarim is offline
Similar Threads
Aftermarket Brake Pads? Mazda Gremlyn Suspension / Brakes 135 09-14-2015 12:44 PM
Here they are, boyz! Many of you were looking for them! Torsional_Stiffness 3rd-Gen 24 06-02-2014 01:05 PM
Rotors, pads, fluid: all new, all around posttosh Suspension / Brakes 4 10-02-2012 05:23 PM
Review of Centric Premium front rotors and Posi-Quiet Semi-metallic pads for MS6 FreeRider Mazdaspeed6 11 11-16-2011 11:40 PM
Follow-up: PBR Ultimate pads and Raybestos rotors posttosh Suspension / Brakes 0 04-22-2007 06:14 AM
