Front Tower Strut Bar - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 10 (permalink) Old 03-11-2019, 07:02 PM Thread Starter
Modzas6x's Avatar
Quoted: 31 Post(s)
I’m thinking of installing this part for my car because I want it to be a bit stiffer especially in corners. Is there a noticeable difference with this suspension piece added?
Youtube:
Website:
eBay profile:
Instagram:
2015 Mazda 6 Sport
-2.5L/AT
Mod List
1. Debadge (lol) 03/09/2019
2. Interior LED's 03/16/2019
3. Front Strut Tower Bar 03/23/2019
4. Front License Plate Delete (lol) 03/24/2019
5. CorkSport Axelback Exhaust 03/29/2019
6. CorkSport Rear Sway Bar 06/15/2019
Modzas6x is online now
post #2 of 10 (permalink) Old 03-11-2019, 07:35 PM
idrive's Avatar
Quoted: 295 Post(s)
Groans: 6
IMO it is an excellent upgrade to the front suspension at a very reasonable price while adding very very little (maybe 1 lb?) additional weight. Check out the link to my build thread below in my signature.
Build Thread:
idrive is online now
post #3 of 10 (permalink) Old 03-11-2019, 11:35 PM Thread Starter
Modzas6x's Avatar
Quoted: 31 Post(s)
Talking
Thanks for the input! This reply has pushed me over the edge to go on and buy it for my 2015!
Youtube:
Website:
eBay profile:
Instagram:
2015 Mazda 6 Sport
-2.5L/AT
Mod List
post #4 of 10 (permalink) Old 03-12-2019, 02:52 PM
TalonTsi90's Avatar
Quoted: 92 Post(s)
Groans: 5
Groaned at 7 Times in 7 Posts
They separated the strut towers from the firewall after 08?
2006 6 Hatch Grand Touring 5spd Sunroof
TalonTsi90 is offline
post #5 of 10 (permalink) Old 03-12-2019, 11:35 PM
Quoted: 42 Post(s)
IIRC the 2nd gen changed front suspensions.
Mad Myche is offline
post #6 of 10 (permalink) Old 03-13-2019, 12:21 AM
Quoted: 434 Post(s)
Chassis stiffening is always worth it. The trick is to find where it's needed.
My early gen (also double wishbone) moderately benefited from a lower chassis bar but I felt nothing doing the strut bar afterward.
Not sure if there is any similarity but looking at pictures of the GJ it looks like the strut tops are right up against the firewall. I would imagine that to be pretty stiff.
How about doing them both, (upper and lower)?
or F&R upper bars
Down the rabbit hole we go...
Mozz-D
DrFeelGood is offline
post #7 of 10 (permalink) Old 03-13-2019, 05:14 PM
Quoted: 82 Post(s)
2nd gen was a refinement of the 1st gen's upper/lower control arm (aka double wishbone) setup - 3rd gen jumped to a MacPhearson Strut type. As far as I know the shock towers are still super close to the fire wall and connected to it, just not with any diagonal braces.
What exactly do you mean by wanting it to be a bit stiffer in the corners? This won't stiffen the suspension, but it will stiffen the body shell which should let the suspension work a little better. You'll probably feel it's effect by making turn-in a little quicker with less slop, plus it should feel more solid while turning and over road imperfections (more planted in bumpy corners). I know some guys fill the holes in their control arm bushings with urethane and stiffen those bushing, but otherwise you can't really make the suspension "stiffer" without changing out components.
Have fun and make sure to review your strut brace! I would look at doing rear brace(s) as well, every ride in the back of my dad's 2015 makes me feel it could use a bit more chassis stiffness back there. In fact, I'd just go down the rabbit hole and do as many chassis braces as is reasonable for you. I thought the 6's chassis and body shell were pretty stiff when I drove one after it came out back in 2013, but driving my dad's 2015 6 back to back with my ATS shows how much the 6 could be improved.
*SOLD* 2005 Mazda 6s Sedan Grand Touring ATX
Michelin Pilot Super Sport 225/45 R17 tires (Winter Bridgestone Blizzak WS-70 205/60R16); Racing Beat springs; Koni FSD dampers; Steeda 22.5mm rear sway bar; SURE RDS-06 Rear Brace Bar; Steeda Fusion Strut Tower Brace (w/harness carrier bend-mod
2013 Cadillac ATS 3.6 Premium RWD 225/255 Pilot Super Sports, JacFab Ported Intake Manifold and Manifold Spacer.
Sydtron is offline
post #8 of 10 (permalink) Old 03-14-2019, 10:44 AM Thread Starter
Modzas6x's Avatar
Quoted: 31 Post(s)
Talking
You're right about it not stiffening the suspension (I should have been more clear I'll be using coilovers for that.) But yeah, an update I did purchase a lightly used one from eBay (500 miles of usage) and I am anxiously waiting for it to come in so I can install!
Youtube:
Website:
eBay profile:
Instagram:
2015 Mazda 6 Sport
-2.5L/AT
Mod List
post #9 of 10 (permalink) Old 05-17-2019, 10:44 AM
crazy_raccoon's Avatar
Does it really make a huge difference though for the front strut car at least? I just picked up a '17 Touring and noticed the shock towers are close to the firewall still. Back in the day with the older Integras and Civics, chassis stiffening played a huge roll because the shock towers were much further away from the firewall and rear/under braces put the chassis components together compared to nowedays which everything is literally one piece instead.
crazy_raccoon is offline
post #10 of 10 (permalink) Old 05-19-2019, 01:13 PM Thread Starter
Modzas6x's Avatar
Quoted: 31 Post(s)
I’ve had them for over 2 months and it feels very different. The car does handle significantly better with everything else being the same so I would recommend
Youtube:
Website:
eBay profile:
Instagram:
2015 Mazda 6 Sport
-2.5L/AT
Mod List
Similar Threads
Zeffer's Catalog - Front Lips and Bumpers Zeffer Exterior Modifications 1 08-19-2017 09:49 PM
Tower Strut Bar Shane23 Suspension / Brakes 44 03-08-2007 11:14 PM
tanabe strut tower bar on a speed6 seoulful Suspension / Brakes 43 08-07-2006 11:40 AM
Front Strut Tower Bar on 6S COOL 6 Suspension / Brakes 30 04-20-2005 03:28 AM
Need Help with Tanabe Front Strut Tower Bar COOL 6 Suspension / Brakes 13 03-20-2005 09:29 PM
