Lowering Spring Options - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 11 (permalink) Old 01-02-2019, 04:32 PM Thread Starter
bluedevil6's Avatar
Quoted: 116 Post(s)
I have an 07 Hatch V6 I would like to buy a set of lowering springs after I deal with my subframe debacle and I'm not quite sure who to go with, here's what I'm considering so far:
Manzo LSMA6-0309 https://www.drivenbystyle.com/2003-2...ngs-37568.html -------I'm attracted to these because of the price of course BUT I've never heard of this brand
Megan Racing MR-LS-M603L4 https://www.drivenbystyle.com/2003-2...ngs-10854.html
Eibach https://eibach.com/us/i-2008-pro-kit...4-springs.html
Also considered Racing Beat but I think I'm looking for more of a drop than they are supposed to give. I have also looked at Tein and H&R but I don't think I want to spend that much on springs for this car. Are there any others I might not have heard of?
Thanks in advance for any opinions.
FULL DISCLOSURE I'VE NEVER USED LOWERING SPRINGS BEFORE
2007 6 Hatch 3.0 V6 ATX
Still Want lowering springs, sway bars, subframe brace, strut tower brace
Places to find me-
bluedevil6 is online now
post #2 of 11 (permalink) Old 01-02-2019, 04:34 PM Thread Starter
bluedevil6's Avatar
Quoted: 116 Post(s)
I’m really just looking to close the gap between the wheel arch and tire I think these current gaps are just too big
Rear
Front
Places to find me-
post #3 of 11 (permalink) Old 01-02-2019, 06:59 PM
blackerphotos's Avatar
Quoted: 49 Post(s)
Just be careful relative to 4i vs V6 designations; the spring rate will be different due to the weight of the motors. I noticed the Megan Racing springs are for ‘4 cyl/V6’. They’re not the same and it would stand to reason that the drop on the front end will be a little different, with the V6 being slightly lower than the 4i on that set.
If it were me (and it was when I bought my Eibach wagon springs), I’d make sure I ordered springs specific to my car.
@blackerphotos on Instagram, Facebook & Twitter
blackerphotos is offline
post #4 of 11 (permalink) Old 01-02-2019, 07:40 PM Thread Starter
bluedevil6's Avatar
Quoted: 116 Post(s)
Originally Posted by blackerphotos View Post
Just be careful relative to 4i vs V6 designations; the spring rate will be different due to the weight of the motors. I noticed the Megan Racing springs are for Ď4 cyl/V6í. Theyíre not the same and it would stand to reason that the drop on the front end will be a little different, with the V6 being slightly lower than the 4i on that set.
If it were me (and it was when I bought my Eibach wagon springs), Iíd make sure I ordered springs specific to my car.
Yeah I noticed the same thing about the Megan racing ones tbh Iím really leaning towards the eibachs if I canít find any reviews on the manzoís I was able to find that the manzo brand ones were listed for the V6 from multiple online stores
Places to find me-
post #5 of 11 (permalink) Old 01-02-2019, 10:22 PM Thread Starter
bluedevil6's Avatar
Quoted: 116 Post(s)
So I have just spent a couple of hours sifting through ancient threads on lowering springs, so allow me to refine my question some since I know nothing about lowering a car. Has anyone heard of or used the Manzo springs? If not I think Iíll probably stick with my original plan of eibach. That leads to my next question the wagon springs are rated for a slightly larger drop would those work on my hatch?
Places to find me-
post #6 of 11 (permalink) Old 01-02-2019, 11:57 PM
Quoted: 49 Post(s)
I think if your options are strictly between sedan (the Eibach link you posted) or wagon springs (the ones I have), you’d definitely be better off with the wagon springs. The wagon and the hatchback have additional weight in the rear because of the additional glass (moreso the wagon with the two extra side back windows), and the hatch/liftgate.
If there isn’t a set specific to the hatchback, I’d go with the wagon springs. If you were to use the sedan springs, the additional weight of your hatchback will result in noticable sag in the rear.
post #7 of 11 (permalink) Old 01-03-2019, 12:47 AM Thread Starter
bluedevil6's Avatar
Quoted: 116 Post(s)
That is exactly what I was thinking, with the weight of the hatch it would probably make the most sense to use the wagon springs.
Places to find me-
post #8 of 11 (permalink) Old 01-03-2019, 03:30 AM
Quoted: 317 Post(s)
You and @blackerphotos nailed it.
check my experience here.
The front spring rates are likely almost identical between the V6 and L4 but there is a huge difference in the rear springs.
I installed the sedan springs on the rear with about 1" of spacer and the level was fine but it could not control the extra mass over bumps. The racing beat springs are no longer made for the wagon and hatch. I have Racing Beats spring rates listed for comparison in the bost referenced above, they are all 20% stiffer than stock. You can still find the Mazdaspeed springs for the wagon/hatch (GRMS-8M-H15) and they are about 30% stiffer. Be advised that if you live in the "rust belt" they have had difficulty with salted roads and longevity (not powder coated).
I went with a 20mm lowering and I cannot pull into curb stops without hitting the front end. I have had to moderately watch driveways. Two of the springs you listed have a 50+mm drop, this will mean that with the long overhang on the Mk1 you are going to have to crawl and angle up many driveways. There will likely be some that you just cannot traverse. If you want it "dumped" then they may be the way to go.
I am running a King spring "lowered coil" out of Australia on the rear and have been extremely happy with it. Had I to do it again I would go with those spring both front and back but a full set would come at a premium (postage). They are a 30mm drop (which I spaced up 10mm) and have a 30+/- rate increase.
I have run the Eibach springs on Volvo wagons (850, 245), Datsun 240Z, Celica RWD, Corolla, and others with great results. They are just a little lower (~40mm drop) than I wanted with the driveways I have to pass on a daily basis. The 240Z is still wearing them after 26 years.
Good luck and it going to be tough to make it look better than it already does.
For perspective @kiwiatenza is on King "Super Lows" (-50mm)
Check out his ride below. (I traded his pictured taillights for mine)
https://forum.mazda6club.com/newbie-...ml#post4992914
Name:	King Spring Part Numbers Mazda6 GG_GY.jpg
Modifications:
.MSP slotted brakes & rotors
DrFeelGood is offline
post #9 of 11 (permalink) Old 01-03-2019, 09:18 AM Thread Starter
bluedevil6's Avatar
Quoted: 116 Post(s)
Thanks @DrFeelGood for the info it really helps. I know Iím probably going to have to worry about scraping things but thatís not the end of the world my previous car (pics below quality is not so good as I was taking pictures of pictures lol) was a 2000 eclipse and it sat so low from the factory that speed bumps, drive ways and curb stops were always a problem so I got used to being careful then. As for the drop thatís another thing the eibachs have going for them the drop is only rated 1.6 inch rather than 2+ which I think will look better and it will probably make it easier to change out the wheels if I ever find any. I also like that youíve had them on a car for 26 years with no issues that longevity for me is a big selling point as well as the stiffness because now that I have engine performance where I want itís time to tackle handling future upgrades after springs will be the H brace, strut tower brace and eventually better sway bars.
I didnít even realize the speed6 springs were different, though itís good to know they donít handle salt well.Lowering Spring Options-img_0938.jpgLowering Spring Options-img_0937.jpg
Places to find me-
post #10 of 11 (permalink) Old 01-03-2019, 08:59 PM
b1lk1's Avatar
Quoted: 272 Post(s)
Groans: 19
I have Eibach Proline 2"-2.5" drop springs going back on my car this winter and it gets it down low but I never scraped anything except when parking. Made the car handle stupid well, but I also have Koni ADJ Yellows all around too. Can't wait for the spring, getting a bunch of stuff done this winter with the car off the road for a change.
b1lk1 is offline
