Brakes click when depress while in reverse only - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
post #1 of 14 (permalink) Old 11-16-2018, 01:23 AM Thread Starter
Quoted: 29 Post(s)
Issue: 2017 Mazda6
When in reverse, I hear a single click everytime a depress the brake. When I let go of the brake and depress again, I hear another single click. What's the cause of this? Everything else is seems fine.
My cars still under warranty but if it's diagnosed as non-warranty item they'll charge me labour.
Sound seems to be coming from the outside of the car but i can hear in inside.
stovetop is offline
post #2 of 14 (permalink) Old 11-16-2018, 07:56 AM
Garrett Smith's Avatar
Quoted: 20 Post(s)
I have this exact problem on my 2014 touring I have no idea what's causing this...
Sent from my Pixel 2 XL using Tapatalk
'14 Mazda 6
Garrett Smith is offline
post #3 of 14 (permalink) Old 11-16-2018, 10:34 AM
Chazzy J's Avatar
Quoted: 55 Post(s)
My 2018 started doing something similar not too long ago at about 12k. I feel like it's the caliper, but I'm not really sure. Haven't had a lot of time to investigate. Nor does it really bug me, just an annoying sound.
As @amati5 helped me understand in a previous thread, maybe it's the caliper pins that need to be lubed? But who knows...
2018 Mazda6 Signature
- Soul Red/Parchment
Chazzy J is offline
post #4 of 14 (permalink) Old 11-16-2018, 12:42 PM
MadStyle's Avatar
Quoted: 224 Post(s)
Groaned at 3 Times in 2 Posts
That one click sound is your brake pads moving forward when braking, it does so once it gets loose over time, happens on a lot of cars, some more noticeable than others. Try adding new shims to the pads if it's bothering you or ride it out till when you need new pads.
MadStyle is offline
post #5 of 14 (permalink) Old 11-16-2018, 12:58 PM
Quoted: 20 Post(s)
So it's not something that would hurt the car. Just a sound?
'14 Mazda 6
post #6 of 14 (permalink) Old 11-16-2018, 03:58 PM
MadStyle's Avatar
Quoted: 224 Post(s)
If your pads are still good, then yes will not hurt anything, It's the pads moving inside caliper. If it's constantly clicking when driving or braking then your pads are not seated correctly on the calipers, in that case remove and reinstall and make sure they are seated properly.
MadStyle is offline
post #7 of 14 (permalink) Old 11-16-2018, 04:21 PM
commodore_dude's Avatar
Quoted: 7 Post(s)
Happens on both my 6 and my Wrangler, so I assume it's pretty normal.
commodore_dude is offline
post #8 of 14 (permalink) Old 11-16-2018, 08:13 PM
GTEyes's Avatar
Quoted: 49 Post(s)
My car has started doing this as well...
GTEyes is offline
post #9 of 14 (permalink) Old 11-17-2018, 07:59 AM
jcme0557's Avatar
Quoted: 196 Post(s)
Its called "pad slap" and its the normal sound of the brake pads being moved by the rotor and contacting the caliper. There should be small spring clips to help absorb the energy and reduce the sound. Sometimes those clips get lost during brake repairs? Also, dirt, grease, salt, rust, etc. can collect and cause the pad to stick and release increasing the energy transfer and sound. Usually a good cleaning and lube will help with this.
2016 Mazda 6 Touring (w/6-speed manual transmission)
OE fog lights, navigation, auto-dimming mirror,
Tanabe front strut bar, Michelin Pilot Sport AS3+ tires
Orange Virus Tune-91-octane, Racing Beat rear muffler
jcme0557 is offline
The Following 2 Users Say Thank You to jcme0557 For This Useful Post:
Bill_k (11-17-2018), GTEyes (11-17-2018)
post #10 of 14 (permalink) Old 11-17-2018, 09:52 AM
Quoted: 20 Post(s)
So just hit it with some brake clean and grease?
'14 Mazda 6
