JC's Review of Corksport BBK - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 2Likes
post #1 of 20 (permalink) Old 08-10-2018, 02:20 PM Thread Starter
JC79G35's Avatar
Quoted: 87 Post(s)
Post JC's Review of Corksport BBK
I will use Zeffer's formula for reviews since he pretty much nailed it (why reinvent the wheel?)
https://corksport.com/2014-mazda-3-big-brake-kit.html
What is it?
It's an upgraded front brake kit that replaces the front calipers/rotors/lines. The brake rotor is larger and of course slotted. The caliper is not only prettier than stock, but has 4 pistons. Finally, the stainless steel lines to increase efficiency.
What's nice?
First, the looks are better than stock (duh). Second, stopping power is improved, actually took a little getting used to the shorter stopping distance. Third, the installation process was quite easy for your do-it-yourself mechanics. Corksport made this product very well on how easily it comes together. Finally, the lighter setup (and I can confirm this as the box with the stock parts in where the CS stuff was in was considerably heavier) gave my car a slightly noticeable better response.
What's not-so-nice? (sorry Zeffer, had to modify that lol)
You live in state that has winter and/or salt? Have fun with the brake lines. I first tried a line wrench and rounded it. I then tried a vice grip pliers but to no avail. Luckily, I had a friend with a torch so we heated up the driver's side line and got it off with vice grips, no problem. Another thing was vice grips size matters. We got the passenger side off with no heat. Turns out the size of the vice grips I was originally using were too large. Just an FYI for anyone tackling this.
Ease of install:
As I mentioned, the install (besides the brake line removal) was pretty easy. One thing to mention - keep the lines attached after loosening them and just rest the removed stock caliper on something. It will save you a ton of time bleeding. Oh yeah, the bleeding part. That's what I was most nervous about, but with keeping the lines attached and swapping them out once the new setup is in, it took only a few minutes to fully bleed the new calipers.
In conclusion, I really do like this kit. It is not terribly expensive in comparisons to BBK out there for other cars. The look, stopping power, and less unsprung weight.
toy4x likes this.
2014 Mazda6 GT
Corksport * Racing Beat * Koni * Gram Lights * MV Tuning
JC79G35 is offline
post #2 of 20 (permalink) Old 08-10-2018, 02:39 PM
Banned
Quoted: 329 Post(s)
Groans: 9
What is it?
What's nice?
Ease of install:
Nice write-up, plus the pic at the end is a bonus. I like how Corksport's brake kit is slotted rather than drilled.
SS brake lines are kind of pointless though. The inside of your brake lines are already lined with steel.
Get Inline is offline
post #3 of 20 (permalink) Old 08-10-2018, 03:17 PM Thread Starter
JC79G35's Avatar
Quoted: 87 Post(s)
Thanks, was not aware of the existing lines. Although they come with the set and you can't reuse the stock lines anyway on the upgraded calipers, so no biggie in the end.
2014 Mazda6 GT
JC79G35 is offline
post #4 of 20 (permalink) Old 08-10-2018, 06:26 PM
Quoted: 12 Post(s)
Don't forget to do brake bedding. or avoid hard braking for 500 mile
w1000i is offline
post #5 of 20 (permalink) Old 08-10-2018, 10:26 PM
Banned
Quoted: 560 Post(s)
Groans: 5
Groaned at 48 Times in 41 Posts
from a distance people probably think they are covers lol
they just dont have that stock look
Mazda6Suspension is offline
post #6 of 20 (permalink) Old 08-13-2018, 10:12 AM Thread Starter
JC79G35's Avatar
Quoted: 87 Post(s)
Actually, they do include the steps to properly bed the brakes in the instructions. Very easy to do (just need no traffic, that's kinda the hard part :P)
2014 Mazda6 GT
JC79G35 is offline
post #7 of 20 (permalink) Old 08-14-2018, 01:16 PM
Dougspeed's Avatar
Quoted: 114 Post(s)
These look good, they fill in the wheels nicely and I'm all for less unsprung weight and better pedal feel.
That being said, my only concern is that when it comes to replacement, it appears that these rotors are a size specific to this Corksport kit and it can't be replaced with any other brand of rotors like Centric, Brembo, EBC or any of the other large aftermarket brake suppliers.
Dougspeed is offline
post #8 of 20 (permalink) Old 08-14-2018, 01:33 PM Thread Starter
JC79G35's Avatar
Quoted: 87 Post(s)
Funny you mention that, I was thinking the EXACT same thing today, except it was more in line with brake pads then the rotors. I am going to hit Corksport up about that.
2014 Mazda6 GT
JC79G35 is offline
post #9 of 20 (permalink) Old 08-14-2018, 02:24 PM
Banned
Quoted: 329 Post(s)
Groans: 9
For high performance brakes like Corksports, yes. But for regular street brakes? There's no need.
Pedal feel is largely influenced by servo motor, and stopping power is largely influenced by the grip of the front tires, so considering that replacing the pads/rotors on this BBK may be a bit of a challenge, I think it would simply be best to just stick to German OEM stuff such as Textar/Ferodo/Pagid/Jurid pads and Zimmerman rotors.
post #10 of 20 (permalink) Old 08-14-2018, 02:44 PM
Dougspeed's Avatar
Quoted: 114 Post(s)
Being that this is a Japanese car, most of those brands don't manufacture pads or rotors for it. I have used Zimmerman on the e39 and honestly, it was no better and possibly slightly worse than the OE branded parts. Just that they were quite a bit cheaper so that was a plus.
For Mazdas, and most other Japanese brands, the only choices outside of OE are usually Centric, Brembo, Akebono and EBC amongst the larger name brands. Also, it's not just the grip of the front tires, more aggressive pads make a significant difference in braking power AND pedal feel as well. On my old SC400, I experimented with a few different brands, some made the pedal feel worse and more vague than stock, other more aggressive pads gave it a confidence inspiring bite as soon as I depressed the brake pedal.
