Air Lift Performance 3P - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
post #11 of 26 (permalink) Old 07-26-2018, 10:43 AM Thread Starter
MadStyle's Avatar
Quoted: 250 Post(s)
Groaned at 3 Times in 2 Posts
Originally Posted by patrickyip415 View Post
Thanks for the input! I appreciate it. I'm going back and forth between the two choices. I really like MadStyle's set up since it looks so clean, but I feel like Accuair will still give me functionality in the trunk since its just the tank, meanwhile Airlift will need to add the compressors. At the same time, having 2 compressors is safer since if one were to fail, then the second one will kick in. My concern is that the two compressors with Airlift will make the car louder than it should be. I'm pretty sure I wouldn't hear it since I play my music at 30+ on the volume level.
Does that mean the 3P system is all that is really needed?
To break it down, If you travel with passengers front and back often, or track the car, then you would want the 3H to automatically keep the car at whatever height, 3P will keep the car at certain PSI's but when you add more weight like a bunch of friends in the car you will have to manually increase the PSI to keep your original ride height temporarily not a big deal for me, very rarely I had to do that. You can always upgrade to 3H anyway after getting the 3P, It's plug n play minus the install of the sensors of course and you can go back and forth 3P to 3H or back to 3P if a sensor break or something.
MadStyle is offline
post #12 of 26 (permalink) Old 07-26-2018, 04:50 PM
Quoted: 14 Post(s)
You mean Accuair Endo CVT tank w/ internal compressor. It's quiet but runs about $1350.
For about $350 (a whole $1000 less) you can get a seamless aluminum tank and a pair of Viair 444C Compressors (It's what I did).
So you just have to choose between the two, lower budget or lower sound. And keep in mind the compressors are not on the whole time, just when the tank dips below a certain PSI.
And the tank/compressor is apart from the Air management. You can get whatever tank/compressor you want, and then get either the Airlift 3P/3H or the Accuair e-level. I would't even touch the regular Accuair switchback.
Attached a picture of how my install is going so far. Very similar to MadStyle's setup, except I plan to hide the management as well (Which I have not purchased yet).
MadStyle likes this.
ihavenoname is offline
post #13 of 26 (permalink) Old 09-04-2018, 04:45 PM
patrickyip415's Avatar
Quoted: 12 Post(s)
Yeah, I really want to lower the car but don't have the funds lol
How is the installation so far?
Do you guys think the new Airlift 3S is worth it?
2016 Mazda 6 Touring Meteor Gray Mica
CS SRI and CS Catback Exhaust
patrickyip415 is offline
post #14 of 26 (permalink) Old 09-04-2018, 04:53 PM Thread Starter
MadStyle's Avatar
Quoted: 250 Post(s)
Airlift 3S - I am not fond of it, It's a manual, meaning you have to maintain you psi level manually, if the psi goes down you constantly have to adjust it. 3P maintains your PSI, if it drops down or goes up too high and it readjust to your specific PSI settings. The 3S is basically a budget setup with no bells and whistles but it's cheaper.
MadStyle is offline
post #15 of 26 (permalink) Old 09-04-2018, 05:04 PM
Quoted: 12 Post(s)
That sounds like a pain. 3H/3P sounds a lot better.
I really hope there's a sale or something that will make it easier for me to purchase Airlift materials.
How's your experience having bags for about a year and a half now? Anything you don't particularly like?
post #16 of 26 (permalink) Old 09-04-2018, 05:34 PM Thread Starter
MadStyle's Avatar
Quoted: 250 Post(s)
I have no complaints, pretty solid system no issues yet, I check my bags everytime I check my tire pressures as a precaution but they are running solid still no sign of wear yet.
Cost wise this setup will still be a pretty penny on sale, I would suggest buying in pieces if you're serious, buy the the struts a pair at a time, they are cheaper. The Air Management kit, is the most expensive part at $1500 bucks. Front bags or rear bags are like 900 bucks or so per pair, also installation cost is another big cost, depending on shop It'll cost anywhere from 900 bucks and up and about 2/3 days without your car unless you want to do it yourself.
MadStyle is offline
post #17 of 26 (permalink) Old 09-04-2018, 05:59 PM
Quoted: 12 Post(s)
Yeah, I see what you mean. I did a quick build on bag riders to see how much 3H would cost and it was a little over 4k.
Hopefully there's a sale, but right now, I'm leaning towards using TJ Hunt's website w/ throtl.
With a discount from signing up as a member, its under $3600 not including shipping (however much that is)
Accuair's EndoCVT w/ struts would be at least 4600
Installation price doesn't sound too bad especially with the one you recommended me before. The harder parts getting to places without a car.
Do you ever hear the compressors with the way you set them up farthest away from the driver and front passenger?
post #18 of 26 (permalink) Old 09-04-2018, 06:40 PM
Quoted: 14 Post(s)
Install is going good, made a thread on it.
https://forum.mazda6club.com/picture...ort-build.html
I wouldn't touch the 3S, especially without a remote.
if you are on a budget, get the 3P. $1,275 on Amazon, ebay, etc. with free shipping.
Front/rear struts and bags about $1825 on Airlift's site plus shipping. If you call them they may even give you a better deal.
Comes out to $3100, plus compressors and a tank.
You could do the install yourself. I started out mounting the tank, manifold and everything else, leaving the bags for last. Not a single day of down time for the car.
With some basic tools and a lot of patience you can do everything over a few days/weeks, depending on the time you have, and how clean of a job you want to do.
post #19 of 26 (permalink) Old 10-23-2018, 06:29 PM
Quoted: 12 Post(s)
Since air suspension isn't very popular on the gen 3, do you guys happen to know if it will interfere with CS rear sway bar?
post #20 of 26 (permalink) Old 10-24-2018, 02:15 AM Thread Starter
MadStyle's Avatar
Quoted: 250 Post(s)
Should not have any issues with em.
#tap-translate { all: initial; } @keyframes translation-button-slide { from { transform: translateX(100%); } to { trasnform: translateX(0); } } @keyframes fadein-background { from { opacity: 0; } to { opacity: 0.7; } } @keyframes fadeout-background { from { opacity: 0.7; } to { opacity: 0; } } @keyframes fadein-button { from { opacity: 0; } to { opacity: 1; } } @keyframes translation-slidein { from { transform: translateX(-50%) translateY(-100%); } to { trasnform: translateX(-50%) translateY(0); } } @keyframes translation-slideout { from { trasnform: translateX(-50%) translateY(0); } to { transform: translateX(-50%) translateY(-100%); } } @keyframes spinner { from { transform: rotateZ(0deg); } to { transform: rotateZ(360deg); } } #tap-translate *, #tap-translate *::before, #tap-translate *::after { box-sizing: border-box; } #tap-translate .container { position: absolute; top: 0; left: 0; font-size: 16px; font-family: sans-serif; line-height: 1.2; color: black; z-index: 1000000000; } #tap-translate .translation-button { animation-duration: 0.1s; animation-timing-function: linear; animation-fill-mode: forwards; display: flex; align-items: center; justify-content: center; cursor: pointer; background: #f9f9fa ; box-shadow: 0 0 5px #ccccc6 ; user-select: none; -moz-user-select: none; } #tap-translate .translation-button:active { background: #e1e1e6 ; } #tap-translate .translation-button.m-corner { animation-name: translation-button-slide; position: fixed; top: 20px; right: 0; width: 70px; height: 50px; } #tap-translate .translation-button.m-corner .translation-button_image { width: 50px; height: 50px; } #tap-translate .translation-button.m-next-to { animation-name: fadein-button; position: absolute; border-radius: 50%; width: 40px; height: 40px; } #tap-translate .translation-button.m-next-to .translation-button_image { width: 35px; height: 35px; } #tap-translate .translation { position: fixed; } #tap-translate .translation.m-closing .translation_background { animation-name: fadeout-background; } #tap-translate .translation.m-closing .translation_content { animation-name: translation-slideout; } #tap-translate .translation_background { animation-name: fadein-background; animation-duration: 0.2s; animation-timing-function: linear; animation-fill-mode: forwards; position: fixed; top: 0; left: 0; background: black; width: 100vw; height: 100vh; } #tap-translate .translation_content { animation-name: translation-slidein; animation-duration: 0.2s; animation-timing-function: linear; animation-fill-mode: forwards; position: fixed; top: 0; left: 50%; background: #f9f9fa ; width: 90%; max-width: 400px; transform: translateX(-50%); } #tap-translate .translation_loader { animation-name: spinner; animation-duration: 1s; animation-timing-function: linear; animation-iteration-count: infinite; border: 5px solid #e1e1e6 ; border-top: 5px solid #0096dd ; border-radius: 50%; margin: 15px auto; width: 45px; height: 45px; } #tap-translate .translation_info, #tap-translate .translation_error { padding: 15px; } #tap-translate .translation_info { overflow-y: auto; max-height: 80vh; } #tap-translate .translation_main.m-single { font-size: 18px; font-weight: bold; } #tap-translate .translation_secondary, #tap-translate .translation_language { padding-top: 10px; } #tap-translate .translation_language { font-size: 14px; } #tap-translate .translation_error { text-align: center; } #tap-translate .translation_error-sign { font-size: 50px; color: #d71111 ; } #tap-translate .translation_buttons { display: flex; flex-flow: row nowrap; user-select: none; -moz-user-select: none; } #tap-translate .translation_button { cursor: pointer; background: #e1e1e6 ; padding: 15px 0; text-align: center; width: 100%; } #tap-translate .translation_button:active { background: #afafb5 ; } #tap-translate .translation_button.m-primary { background: #0096dd ; color: white; } #tap-translate .translation_button.m-primary:active { background: #066896 ; }
MadStyle is offline
