I need advice on Speed6 strut mounts - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 7 (permalink) Old 06-18-2019, 09:27 AM Thread Starter
Here's the deal:
Mazda lists a unique part number for the front strut mounts on the Speed6.
However, many aftermarket parts retailers, including Rock Auto, show that the mounts for the V6 and the I4 will fit the Speed6.
I am inclined to believe this bad info since OEM is a unique PN. Rock Auto is known for incorrect parts compatibility. This has stung me more than once.
What aftermarket parts brands and numbers will work for the Speed 6? Is the only option OEM? Or will the strut mounts for the I4 and V6 work?
Thanks for your help.
Rose City Speed6 is offline
post #2 of 7 (permalink) Old 06-18-2019, 08:07 PM
Quoted: 451 Post(s)
Originally Posted by Rose City Speed6 View Post
Here's the deal:
I don't have a speed6 but I do have as 'S' model and have waded through the strut top changes recently.
There were changes made to the strut mounts that appear to coincide with the "facelift". The Mk1 (03-05) used what appear to be a solid center mounting.
However (I believe there was a TSB about this) they were troublesome due to noise.
The later Mk1.5 (06-08) used a strut mount with integrated thrust bearing.
The OEM numbers have superseded the older solid style to ones with thrust bearings.
Looking at the KYB mounts you can still see the differences.
KYB SM5548 (2003 Mazda 6s)
KYB SM5540 (2006-7 Mazdaspeed 6, 2006-2008 Mazda 6 s,i)
I have a strong suspicion that in this case it will not matter. I say order the speed version or the 06-08 6s one.
Mozz-D
DrFeelGood is offline
post #3 of 7 (permalink) Old 06-19-2019, 09:46 AM Thread Starter
Thanks for this!
post #4 of 7 (permalink) Old 06-19-2019, 12:15 PM
Quoted: 451 Post(s)
Thanks for this!
Sure. Will you post back either way it works out? By then you may be able to list it in the Speed section.
Good to see a fellow Rose City dweller.
Mozz-D
post #5 of 7 (permalink) Old 06-27-2019, 04:34 PM
Quoted: 82 Post(s)
The factory speed6 mounts also used a steel bearing, I've seen plastic versions in the non-speed6 mounts.
2004 Mazda 6 V6/MTX, Steel Gray
kevinspann is offline
post #6 of 7 (permalink) Old 06-27-2019, 10:25 PM
Quoted: 44 Post(s)
So which ones did you install? I have the 03 "i" and have been thinking about getting them replaced soon
Mad Myche is offline
post #7 of 7 (permalink) Old 06-28-2019, 11:15 AM
Quoted: 451 Post(s)
I ended up installing the MOOG K160103. I have had excellent luck with this brand over the decades (555 made in Japan).
Mozz-D
