Power Steering Pipe Leaking bad - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 6 (permalink) Old 05-25-2018, 06:32 PM Thread Starter
Quoted: 4 Post(s)
The power steering slowly leaked out of my '06 mazdaspeed6. I filled up. Checked for leaks. No leaks. Turned the car on turned the wheel a bunch, no leaks. I start to drive it and it pours all down the street. It's a pretty bad leak now. It is leaking at the section of pipe that goes in the driver side wheel well. It's all rusty where those round fins are. I think it is part number 32410b but that is expensive. Like 130 dollars. Is that just how much it is? I need it like ASAP this is my DD. Thank you!
Jay Watson is offline
post #2 of 6 (permalink) Old 05-25-2018, 07:27 PM
Quoted: 398 Post(s)
@Byakuya or other moderator. Would you please move this to the appropriate section? Thanks
I think you may be referring to part # GP7B-32-410B (ATX) or GK2A-32-410H (MT)
It does rust out and cause problems. I suggest replacing it.
Try a salvage yard. I don't believe it is speed specific, only 4-cyl and your transmission type (MT or ATX)
I once repaired a rusted fuel tank (looked like it was hit with a blast from a shotgun) by removing it and cleaning it with a wire wheel then spray solvent and a nice coat of JB Weld followed by new paint. Worked for nearly 8 years till I sold it.
Not ideal but if you are on a budget (12 yr old speed 6 may not be for you...) it could bridge the gap.
Good luck.
DrFeelGood is offline
post #3 of 6 (permalink) Old 05-25-2018, 07:57 PM Thread Starter
Quoted: 4 Post(s)
I actually just found an old thread of the same exact issue!
http://forum.mazda6club.com/mazdaspe...ps-cooler.html
Reading it now. It actually looks different. Might be a GP9E32410C? or B? IDK
It actually looks like it has a heat sink cooler on it. Is there some sort of aftermarket part that would be cheaper? I may just end up putting some jb weld on it idk.
post #4 of 6 (permalink) Old 05-26-2018, 10:55 AM
Quoted: 398 Post(s)
If it is a return line it will be operating under low pressure. You could cut the bad section out and replace it with rubber hose and clamps; depending on where it is.
post #5 of 6 (permalink) Old 06-09-2018, 05:47 PM Thread Starter
Quoted: 4 Post(s)
I ended up going with the dm power steering cooler kit. It was worth a Benjamin Franklin. Easy to install. Works like a charm. Will last a long long time.
https://www.damondmotorsports.com/products/mazdaspeed6
post #6 of 6 (permalink) Old 06-09-2018, 05:57 PM
Quoted: 398 Post(s)
That was an excellent decision I think. Keeping fluids from overheating is key and difficult with how hot it gets under-hood on these creatures.
