Steeda Adj End Links - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 1Likes
post #11 of 20 (permalink) Old 06-17-2015, 10:39 AM
HovA's Avatar
Quoted: 499 Post(s)
Aahhh, very clever sir. I was trying to think of a safe way to spread the bracket arms. That seems like the perfect method. I'll be (attempting) to install them tonight. My mechanic said the links lower bushing was 1/8" too wide. I realized late last night that they never compressed the sides of the bushings. I used a C-Clamp and quickly compressed the sides....I found my 1/8" of compression. :-)
Gone but not forgotten
Manual 06' 3.0 Wagon
Tein S-Techs, Flush tails, TWM shifter & more
New Bitch:
03' Protege5 follow me on IG @Hova_Wins
-{Enter Witty Remark Here}-
My
HovA is offline
post #12 of 20 (permalink) Old 06-24-2015, 08:00 AM
djmarkian's Avatar
Quoted: 99 Post(s)
Groans: 13
Groaned at 6 Times in 6 Posts
Originally Posted by TiGraySpeed6 View Post
Totally capable of daily driver use!
No NVH or anything, and they don't use spherical rod ends like the AWR EL's do so I expect that these will not only be quieter but will last quite a bit longer too.
Ive got the rears installed already, about 1/4 inch longer than stock, and they fit better than the Racing Beat EL's that I was using, and have more busing area to absorb NVH than the RB's do.
Looking forward to installing the fronts.
Couple pics of the rears-
I didn't know these existed so I went with AWR's, but only the fronts. I'm yet to replace the rears...
2006 Mazdaspeed 6 sport #01820 - Whitewater Pearl
COBB AP(PD Tuning), JBR 3.5 int, HKS SSQV, Denso ITV22, CS HPFP, FMIC, BSD w/PTP baffle, ADD W1 catch can, MF cat-back/Greddy Muffler, GS in manifold, XS Power ex manifold, ATP DP/vb HF cat, resonator, EGR delete, Sparco Ring SW w/NRG quick release hub, Bride Stradia, STRI Xline Boost, OEM Clutch w/Fidanza FW, TWM stage 1, COBB shift knob, CS F&R bar, Megan H-Bar, H&R coils, Whiteline RSB, Konig Backbone 18x8 et45, Falken Azenis 245/40-18.
djmarkian is offline
post #13 of 20 (permalink) Old 08-07-2015, 07:12 AM
23TDuratecMerkur's Avatar
Quoted: 111 Post(s)
Do these end links work on a MS6?
Fully Bolted 2004 V6 | MSDS Headers | Injen CAI | MagnaFlow CBE | Brembo BBK | BC Racing Coilovers |
23TDuratecMerkur is offline
post #14 of 20 (permalink) Old 08-07-2015, 08:02 AM Thread Starter
Lowspeed
TiGraySpeed6's Avatar
Quoted: 621 Post(s)
Groaned at 8 Times in 8 Posts
iTrader: 2 reviews
Yes.
And with no real malice I feel compelled to add "obviously"....
I'm the one who started this post about installing the parts on my car, and it's in the Speed6 section.
1and1
TiGraySpeed6 is offline
post #15 of 20 (permalink) Old 08-07-2015, 03:10 PM
Quoted: 111 Post(s)
Yes.
No worries.I'm thick skinned. I'd have said the same thing.
Early morning post, should have read the section.
post #16 of 20 (permalink) Old 05-11-2016, 01:59 PM
6erforlife's Avatar
Quoted: 81 Post(s)
@TiGraySpeed6 did you ever cut the hole a bit larger in the lca so that you could fit the Steeda endlink on the stiffer setting? I've been noticing some creaking sounds and upon inspection, my oem end link is essentially destroyed on the driver side. Was considering going with an adjustable end link and both the steeda and awr look incredibly beefy compared to stock
Liquid Platinum 07 Speed 6
#10177
JBR 80duro RMM, 70 duro TMM/PMM, Sure Juggernaut, Sure Dreadnaught
GTX3071, Cobb AP, HTP3.5" Intake, Streetunit TMIC, M2 DP, TurboSmart BOV, Grimmspeed EBCS, AT Internals, GP Werks BSD & Baffle, Denso ITV22, TWM Stage 2, Dashhawk, JBR OCC, JBR TB TIG, SURE IM TIG, VTCS Delete, Ford Transit Oil Filter Conversion, Clean Valves!
LED tail lights, 20% tint, EVO X rims and VG Sharkfin
Big Turbo baby!
Soon to install CPE Exh. Mani
6erforlife is offline
post #17 of 20 (permalink) Old 05-11-2016, 02:22 PM Thread Starter
Lowspeed
Quoted: 621 Post(s)
iTrader: 2 reviews
I did open up the rear LCA's to better allow the stiff setting on the WhiteLine RSB. Used a small diameter grinding wheel (read that as "worn out") to open up the side towards the front of the car, only takes a few minutes per side once you drop the arm & remove the spring. Remember to spray a touch of black paint on the bare metal to prevent rust.
In other news- the Steeda links are off the car now. As a matter of fact they only lasted about a year / ~14,000 miles. I'm back on stock fronts and RacingBeat rears.
1and1
6erforlife (05-12-2016)
post #18 of 20 (permalink) Old 05-12-2016, 12:14 AM
6erforlife's Avatar
Quoted: 81 Post(s)
Nice! I've been planning on checking a shop's work on my coilover install anyway so grinding out the lca would be a good time to get it out of the way as well. The spray is sound advice. I'll even go a step further and apply a little naval jelly to try and rid them of rust while I'm at it (damn Jersey winters lol)
Well that's disappointing. Why did you decide to go with the racing beat instead of a different adjustable end link? I've been searching online for the best way to optimize a rear sway and I've read that the bar should be parallel to the ground with no preload on either side. The stock end links definitely applied some sort of load to the bar that I imagine aided in their demise.
#10177
Big Turbo baby!
post #19 of 20 (permalink) Old 05-12-2016, 09:47 AM Thread Starter
Lowspeed
Quoted: 621 Post(s)
iTrader: 2 reviews
Rear end links- few things here-
The upper part of the steeda is good enough. No real problems there.
The lower portion won't really allow the link enough movement to lean far enough to connect to the stiff mount on the WL RSB. Remember, it's got to lean so much that you're looking at modifying the LCA, and the bushing design with it's large washer style outers just won't let that happen properly. To correct it you need to swap the lowers with Spherical Rod Ends like AWR uses. Problem with SRE's is that they're loud and short lived. You can get rear end links from AWR ready to install but expensive, or build your own for much less from someplace like Midwest Controls, but will need to make your own spacers for the lower mount- the SRE's aren't wide enough so need two spacers each to center and support them.
FWIW, you can build your own, both front and rear, with parts from Midwest Controls. They carry the exact same pieces that Steeda uses, so if you wanted to put the extra effort in you can make a set and not need to pay for the Steeda name.
As for length, you can't really make them any shorter or they will contact the LCA, and making em longer, if you're lowered, will only increase the problem you want to fix.
RacingBeat rear end links are sturdy, inexpensive and functional enough to work.
As for the steeda fronts, stock front end length is same as the steeda at full short adjustment. The ball joint ends wore very fast and started knocking over any little bump. I tossed my 100,000+ mile stockers back on just to test, and haven't taken them back off yet...
1and1
6erforlife (05-13-2016)
post #20 of 20 (permalink) Old 05-13-2016, 03:33 PM
6erforlife's Avatar
Quoted: 81 Post(s)
Thank you for taking the time explain in such a thorough manner This is exactly the information I've been searching for in regards to our car. It seems like any modification we want to do comes at a compromise and this is certainly no exception. I was perfectly fine with cutting the lca but if it's as you explained, the steeda doesn't allow you to run the stiff setting on a lowered car properly and SREs wear out fairly quickly, I don't really see a point in going through all the trouble unless it was a dedicated track car...which it isn't....at the moment ...lol
I checked out Midwest controls and I wouldn't even know where to begin with all of those options haha. After doing some research on nonadjustable endlinks i.e. Stock, Moog and RacingBeat, I feel like the Racingbeat looks like the best option, especially with your endorsement haha. Thanks again TiGray for sticking with the community and sharing your experiences. Much appreciated!!
#10177
Big Turbo baby!
