How do I remove the oil drain from a KO4 turbo ? - Page 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #51 of 53 (permalink) Old 01-02-2014, 01:27 PM
Lowspeed
TiGraySpeed6's Avatar
Quoted: 621 Post(s)
Groaned at 8 Times in 8 Posts
iTrader: 2 reviews
There are a few very skilled folks in the central FL area that would be willing to lend a hand I'm sure, but you'll find it's really no more complex than other stuff- Just a bolt at a time till it's done I've worked with a few folks down that way and would be happy to shake the tree for ya
When it comes to breaking things, blown engines & whatever, you're pretty safe! With a BNRs3 you have to work it pretty hard to get into that area- ask me how I know... lolz
I had planned on, and posted repeatedly, that I was gonna go s1, but when it came time to get the credit card out I bit the bullet & went for it. I've never regretted the decision.
I also know this tuner who would take great care of you & make sure nothing bad ever happened to your engine.....
1and1
TiGraySpeed6 is offline
post #52 of 53 (permalink) Old 01-02-2014, 09:42 PM
Selene's Avatar
That would be great! I hear you with the one bolt at a time (though some bolts take a bit longer than others haha) but it would be nice having a little guidance. I also would be appreciative of the recommendation on the tuner as I would love to be able to drive my girl for another 10 yrs... I'm planning on trying to do it in the upcoming weeks. I'll PM you my contact info to make it easier. I'll try to search around as this was probably already answered somewhere else, but what kind of mods were needed to fit in the BNR 3 in there?
06 MS6: COBB AP, Cp-e 3in downpipe, Cp-e tmic, color-matched badgeless front grill, Autotech HPFP, EBC Red stuff and USR slotted rotors, Audiolink ipod adaptor, Valentine 1
coming soon: BNR 3, grimmspeed EBCS, Bosch 3 Bar MAP, HTP 3" one piece intake/TIP
Selene is offline
post #53 of 53 (permalink) Old 01-03-2014, 08:05 AM
Lowspeed
Quoted: 621 Post(s)
iTrader: 2 reviews
Tuner- I run a company called FLOWTuned, have worked with several here on the forum
http://flowtuned.com
https://www.facebook.com/flowtunedsystems
Parts to buy-
- - For any BNR - -
- Gaskets- one for ExMani to turbo, one for turbo to DP. Get Mazda OEM for their high quality, but shop all over for best price cause they're not particularly inexpensive...
- - For BNRs3 specifically - -
- Coolant line - 11" of 6AN braided hose from any local hose place will work- they'll cut it to length for you. Remember to pick up a pair of hose clamps. Cost for braided hose will be ~$8, looks nice & is well protected. BNR includes the new fitting for the turbo.
Highly encouraged upgrades-
- 3 Port EBCS of your choice - Cobb, Grimmspeed, Perrin, Stratified, even a MAC DIY, they're all pretty much the same. Stratified makes a nice one & comes with all the tidbits & vac line you'd need. Cost varies, but ~$125
- 3 BAR MAP Sensor - Allows your ECU & EBCS to read & react to pressures higher than 23psi. The sensor & pigtail adapter so it's plug-n-play, and the combined pair cost less than $100
Have a good 0WGDC map ready to go when you start the car the first time- you'll want to 1) verify your install without stressing anything, and 2) learn what your WG spring pressure is set to. Once you know those two things then you start dialing in boost.
Some threads to read-
How to: Free up room for turbo work - Mazdaspeed Forums
Freeks BNR install - Mazdaspeed Forums
BNR S3 Installed - Mazdaspeed Forums
BNR S3 Swap How To - Mazdaspeed Forums
Oh, and got your PM- I'll read it through in detail later on today!
1and1
