noname's 16 sport build - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 5Likes
post #1 of 54 (permalink) Old 08-25-2018, 02:54 AM Thread Starter
Quoted: 14 Post(s)
Starting a thread to show some of the stuff I have been working on.
Car is still a work in progress but figured I would document it.
We begin our journey May the 4th (be with you) 2015... Someone totaled my car.
Bought the 6 around a week later, had just arrived at the dealer. Can't find a picture of it, assume it looked like this.
After BC coils (adjusted as low as possible) and some too small rims.
After some "correct size" wheels/tires & rolling/pulling the fenders.
And somewhat halfway through the air suspension install (Today, August 24th 2018)
Will continue posting pictures of some steps along the way tomorrow, mostly of the air install.
Took longer than I though to organize the pictures.
ID:	223450   Click image for larger version
ID:	223452   Click image for larger version
ID:	223454   Click image for larger version
ID:	223456   Click image for larger version
ihavenoname is offline
post #2 of 54 (permalink) Old 08-25-2018, 07:13 AM
Quoted: 7 Post(s)
Your 6 looks great! It's cool to see someone else who upgraded from a Lancer. When I had mine, I thought it was fun, but now I don't miss it at all.
Current: 2016 Mazda6 Grand Touring
  • LED Interior Bulbs
  • 20mm Spacers on all 4 corners
Sold: 2011 Mitsubishi Lancer ES Sport
  • Duckbill Spoiler
  • BC Racing Coilovers
  • Megan Racing Rear Camber Arms
  • Tsudo Headerback Exhaust
  • 17" BBS RS reps
arrowz93 is offline
post #3 of 54 (permalink) Old 08-25-2018, 01:39 PM Thread Starter
Quoted: 14 Post(s)
It was a fun car for me, don't miss it either, but every now and then I reminisce.
That was actually her second rodeo as well.
Anyways, on to the 6.
First thing I did was install the BC coils and the small white rims.
Removed them a few days later and put them up for sale as I could not get out of the neighborhood without scraping the whole bottom part of the car on a speed bump.
ID:	223462   Click image for larger version
ID:	223464   Click image for larger version
ID:	223466   Click image for larger version
ID:	223468   Click image for larger version
post #4 of 54 (permalink) Old 08-25-2018, 02:29 PM Thread Starter
Quoted: 14 Post(s)
Next step was 6" 9k Swift springs for the front (Could have gone 7" long and softer without rubbing and still get the same drop).
This picture was after last year's hurricane, the front still had the regular springs.
Rim and tire info.
Front: 20x9 +32 & 245/35
Rear: 20x10.5 +42 & 275/30
Swapped out the springs.
End Result.
How the clearance looked.
Had to buy these as well, I set the camber as low as I could in the front but the adjustment knobs were hitting the body and broke off.
ID:	223480   Click image for larger version
ID:	223482   Click image for larger version
ID:	223484   Click image for larger version
ID:	223486   Click image for larger version
ID:	223490   Click image for larger version
post #5 of 54 (permalink) Old 08-25-2018, 05:20 PM Thread Starter
Quoted: 14 Post(s)
Here's where the Air install begins.
The plan: Keep as much as possible hidden in the trunk.
First thing I did was resurface and polish the tank.
From this.
Took it down to 120 grit, pits were very deep.
Sanded up to 3000 grit.
Cleaned and Polished.
End Result.
Also polished the hardware that holds it in via the same process and ran a tap over all of the threads to clean them up.
More pictures in the attached below, the ones on top get the message across.
ID:	223536   Click image for larger version
ID:	223538   Click image for larger version
ID:	223540   Click image for larger version
ID:	223542   Click image for larger version
ID:	223546   Click image for larger version
ID:	223548   Click image for larger version
ID:	223550   Click image for larger version
ID:	223552   Click image for larger version
post #6 of 54 (permalink) Old 08-25-2018, 09:31 PM Thread Starter
Quoted: 14 Post(s)
On to mounting the tank!
Simple enough, 4 riv-nuts, spaced so the hardware would be close to the edge of the tank.
And a half hour trying to fit myself into the trunk to mount the tank without scratching it.
Note: Used Tesa tape so there would be no metal to metal contact.
Looks dirty from all the handling on the tank putting it in.
More pictures is the "attachments" section
ID:	223556   Click image for larger version
ID:	223558   Click image for larger version
ID:	223560   Click image for larger version
ID:	223562   Click image for larger version
ID:	223566   Click image for larger version
ID:	223568   Click image for larger version
post #7 of 54 (permalink) Old 08-26-2018, 03:04 AM Thread Starter
Quoted: 14 Post(s)
Next up, preparing a place to mount the compressors.
I got the plastic trunk trays and cut the cubbies off, slapped a 3/4" piece of plywood and glued it in place.
Used some gorilla glue since I didn't want to waste my expensive 3M epoxy.
Works fine but I in hindsight, I think I should have gone with the epoxy.
Followed up with some black spray paint, my intention was to leave it like this.
As you can see I didn't like it. Got some Walmart fabric I had and spent the rest of the day wrapping this stuff.
Turned out good enough to pass my quality control.
ID:	223572   Click image for larger version
ID:	223574   Click image for larger version
ID:	223576   Click image for larger version
ID:	223578   Click image for larger version
post #8 of 54 (permalink) Old 08-26-2018, 03:40 AM Thread Starter
Quoted: 14 Post(s)
Time to put the puppies in.
Basic stuff here.
Mounted the compressors on isolators and bolted them to the plywood.
Extra holes for the air hose and the power cables, some grommets to pretty up the holes and a pair of legs from L brackets for the left side to keep it level.
Mounted them as close as I could to the walls.
More pictures in the attachments.
ID:	223584   Click image for larger version
ID:	223586   Click image for larger version
ID:	223588   Click image for larger version
ID:	223590   Click image for larger version
ID:	223594   Click image for larger version
ID:	223596   Click image for larger version
post #9 of 54 (permalink) Old 08-26-2018, 04:24 PM Thread Starter
Quoted: 14 Post(s)
Did this before the the compressors but anyways.
The green mat under the spare tire was stuck to the tire wall and looked like sht.
Had to rip it out and clean the area.
Put deadening all over the trunk, trunk lid and front doors.
More pics in the attachments.
ID:	223600   Click image for larger version
ID:	223602   Click image for larger version
ID:	223604   Click image for larger version
ID:	223606   Click image for larger version
ID:	223610   Click image for larger version
ID:	223612   Click image for larger version
ID:	223614   Click image for larger version
post #10 of 54 (permalink) Old 08-27-2018, 11:39 AM
Sys
I'm a little confused about the timeline. The car was totaled, and then purchased?
Sent from my ASUS_Z01RD using Tapatalk
Sys is offline
