Help! O2 sensor location - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 5 (permalink) Old 06-16-2019, 12:43 PM Thread Starter
White knight6's Avatar
Quoted: 4 Post(s)
So I have a 2003 mazda 6s 3.0L v6 and I need to know which sensor is bank 2 sensor 2 in the o2 sensors along the exhaust and which side of the motor it’s on I’m new to this but I need to fix that cause it’s throwing a check engine light.
White knight6 is offline
post #2 of 5 (permalink) Old 06-16-2019, 01:11 PM
jman1200's Avatar
Quoted: 92 Post(s)
Groans: 5
Cylinders 1, 2 and 3 are the ones close to the firewall therefore those are bank 1. Bank 2 is the one close to the rad, sensor 1 is before the precats located close to the manifold, sensor 2 is past the precats, you'll have to get under the vehicle to see it.
jman1200 is online now
post #3 of 5 (permalink) Old 06-16-2019, 01:20 PM Thread Starter
Quoted: 4 Post(s)
Originally Posted by jman1200 View Post
Cylinders 1, 2 and 3 are the ones close to the firewall therefore those are bank 1. Bank 2 is the one close to the rad, sensor 1 if before the precats located close to the manifold, sensor 2 is past the precats, you'll have to get under the vehicle to see it.
Okay I’ll take a look thanks for the help is there only one sensor down there? I’ve been told there are only 3 sensors in total but I wanna make sure before I mess anything up.
post #4 of 5 (permalink) Old 06-16-2019, 08:22 PM
Quoted: 451 Post(s)
Originally Posted by White knight6 View Post
So I have a 2003 mazda 6s 3.0L v6 and I need to know which sensor is bank 2 sensor 2 in the o2 sensors along the exhaust and which side of the motor itís on Iím new to this but I need to fix that cause itís throwing a check engine light.
@jman1200 has got it.
Mozz-D
DrFeelGood is offline
post #5 of 5 (permalink) Old 06-20-2019, 02:09 PM
Quoted: 8 Post(s)
I am curious what code is it showing. Depending on what the code is it may be the Intake Plenum Gasket or Mass Air Flow sensor.
Xalint6 is offline
