Light smoke from under the hood - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 2 (permalink) Old 06-15-2019, 06:50 PM Thread Starter
Sorcerer's apprentice's Avatar
Question Light smoke from under the hood
Let me give a background of the car condition. I have a 2018 Mazda 6 with around 16k on the ODO. I've followed the manual and service schedules to the T and never went gung-ho on the throttle.
Now since last couple of days I've seen very light colored smoke from under the hood even with 3 miles drive from home to my work place ( goes away in 10-20 secs) There's no burning smell or visible point from where the smoke emanates.
I cranked up the hood to check if there's liquid spill but fortunately none. I went to nearby Mazda, they checked and sent me away with "no issues" as all the checks were good. The temp stays around midway on the dash and all the fluid levels are up to mark as well.
It rains almost every evening so my guess is that the moisture content in the air around engine bay might be causing smoke (now guessed vapor). I'll try click photo's if it happens again.
Any suggestions or opinions on what else to check would be really helpful as I don't want to crank the hood after every drive with the horror that something might be on fire.
Sorcerer's apprentice is offline
post #2 of 2 (permalink) Old 06-19-2019, 11:51 AM
waughoo's Avatar
Quoted: 422 Post(s)
Is the AC on? Vapor can be generated when the cold lines thaw after the car turns off and the heat from the engine melts the frost generated on the hose fittings.
Alex
, and
waughoo is offline
