Over heating - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 11 (permalink) Old 05-10-2019, 06:59 PM Thread Starter
Quoted: 9 Post(s)
Over heating
Hey what's up guys just trying to get some info just installed a new thermostat fan control module and fan relay still over heating any suggestions where I should start looking it still over heating and I have a pretty good hunch that is the fans themselves
Angelj1989 is offline
post #2 of 11 (permalink) Old 05-10-2019, 07:19 PM
Quoted: 430 Post(s)
Hello. Do you have a 6cyl or 4cyl?
Are you boiling over? Have you replaced your radiator/coolant pressure cap? Does your heater blow hot? Did you purge the air from the coolant? Are your fans turning on? Hopefully those questions spur some thoughts about where to check.
Mozz-D
DrFeelGood is online now
post #3 of 11 (permalink) Old 05-10-2019, 11:17 PM
Archerfish's Avatar
Quoted: 136 Post(s)
This is a great example of asking the right question at the right time!
If I may add, and this I experienced myself, check the rotation of the fan. I don't know how but someone has interchanged the terminals on our CR-V 98 when they replaced the motor fan and so it was overheating when idle.
Archerfish is online now
post #4 of 11 (permalink) Old 05-11-2019, 02:40 AM Thread Starter
Quoted: 9 Post(s)
6cyl My heater it's hot the cap seems fine but guess that's where I'll start I did not purge the air that's another thing I should check but it started over v heating before I drained any coolant my fans turn on but seem to turn off rather quickly in my opinion I'm going to have to see tomorrow if they stay on consistently
My opinion is that it's the fans because I had a bad control module maybe bad control module could have messed up the motors on the fans but I really have no idea
post #5 of 11 (permalink) Old 05-11-2019, 02:45 AM
Quoted: 430 Post(s)
If the car is running hot those fans should be roaring. Is the gauge telling you its hot or is it boiling over? Its possible you have a faulty temp sender. Any fault codes?
Mozz-D
post #6 of 11 (permalink) Old 05-11-2019, 09:11 AM Thread Starter
Quoted: 9 Post(s)
No codes and to be honest I haven't checked the coolant to see if it's boiling but I soon as I start seeing it go up I blast the heater I'm going to have to check today
post #7 of 11 (permalink) Old 05-11-2019, 02:02 PM
Quoted: 430 Post(s)
Good idea. For me in the past with other cars if it is not leaking out (obviously), or steaming out the tailpipe, there is air trapped in the system (heater would be cold), the thermostat is installed backwards or upside down (jiggle pin should be at top) or the radiator cap is bad and it cant keep enough pressure so it boils over.
Here is the list from the factory service manual.
Name:	Overheating Concerns (AJ) List.jpg
Mozz-D
post #8 of 11 (permalink) Old 05-11-2019, 05:44 PM
Led light
If I want to install LED lights to my interior on my 2008. What do I need so my room fuse will stop popping?
Dre9602 is offline
post #9 of 11 (permalink) Old 05-16-2019, 06:39 PM Thread Starter
Quoted: 9 Post(s)
Not boiling over no codes fans barely turn on maybe the control module they sent me was bad I dont know it's been like a week any other help would be great
post #10 of 11 (permalink) Old 05-16-2019, 07:00 PM
Quoted: 430 Post(s)
Fans barely turning is a problem. You could buy a cheapo one from Amazon (I did several years ago with good results) or ideally you would test it to verify before buying.
I am attaching the FSM procedure below. Good Luck.
Name:	Fan Control Module  testing (AJ) 01.jpg
ID:	227780   Click image for larger version
Name:	Fan Control Module  testing (AJ) 02 .jpg
Mozz-D
Similar Threads
Awful smell when heating is on fowler77 2.0 Diesel 1 04-28-2014 06:36 AM
Going crazy my red keeps on heating up redmazda Mazda6 (Atenza) 0 05-25-2013 09:06 PM
battery- over heating LKmazda Electrical / HVAC 4 11-29-2010 09:12 PM
Solution for heating issue Steve 6er Mazda6 (Atenza) 1 01-19-2003 11:15 AM
The heating is lousy Steve 6er Consumer Reviews 9 12-13-2002 07:46 AM
