Just installed an injen cold air intake i need help. - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 2 (permalink) Old 04-14-2019, 08:43 PM Thread Starter
So i just got a new cold air intake for my 05 mazda 6s 3.0 wagon. 99.99% sure i did everything right. But when i hit the throttle the engine like.. Dies like my lights get reall dim and the engine dies down. Please help
Brandonmiller44 is offline
post #2 of 2 (permalink) Old 04-15-2019, 11:14 PM
hurddawg's Avatar
Quoted: 59 Post(s)
I would double check to make sure you have the hose clamps are tight and the intake tubing is fitted into the silicone couplers properly. Double check that the MAF is it plugged in and properly. I would also check to make sure that the o-ring on the MAF is there and in good shape. Mext make sure the PCV hose is attached on both ends...in the valve cover and the hose to the intake pipe. Shouldn't be much else. Might want to check around to see you didn't bump/knock off any of the connectors in that vicinity as well. Only one comes to mind is the TB connector.
Any CELs?
- 1957 Chevrolet Sports Sedan
hurddawg is offline
Similar Threads
DIY: Cheap, Easy Cold air intake code fix!! (3.0) DJ Raydiate Engine / Suspension / Drivetrain 6 02-23-2019 08:14 AM
How a high flow intake can make power gains on a modern Mazda6 engine solar365 Engine / Drivetrain 85 03-26-2014 10:12 AM
2008 Mazda 6 Cold Air Intake Installed jdizzle1988 Engine / Drivetrain 14 05-31-2012 10:46 PM
Injen cold air intake and CP-E fix 03-05 V6s 3.0 StylnCamaro Engine & Transmission 5 09-24-2010 05:54 PM
Fs Injen Cold Air Intake With 2 Filters + Free Chrome Trunk Lid executive 6 Engine & Transmission 7 09-24-2007 07:17 PM
