-   Newbie Section (https://forum.mazda6club.com/213-newbie-section/)
-   -   Just installed an injen cold air intake i need help. (https://forum.mazda6club.com/newbie-section/439660-just-installed-injen-cold-air-intake-i-need-help.html)
Brandonmiller44 04-14-2019 08:43 PM
So i just got a new cold air intake for my 05 mazda 6s 3.0 wagon. 99.99% sure i did everything right. But when i hit the throttle the engine like.. Dies like my lights get reall dim and the engine dies down. Please help
hurddawg 04-15-2019 11:14 PM
I would double check to make sure you have the hose clamps are tight and the intake tubing is fitted into the silicone couplers properly. Double check that the MAF is it plugged in and properly. I would also check to make sure that the o-ring on the MAF is there and in good shape. Mext make sure the PCV hose is attached on both ends...in the valve cover and the hose to the intake pipe. Shouldn't be much else. Might want to check around to see you didn't bump/knock off any of the connectors in that vicinity as well. Only one comes to mind is the TB connector.
Any CELs?
