Help! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 11 (permalink) Old 03-25-2019, 02:41 PM Thread Starter
mmoore9323's Avatar
Quoted: 9 Post(s)
Help!
Hey everyone. I just bought a 2005 6 s wagon. I love it but I was tracking down an oil leak and I think it might be the oil pain gasket. How much should i expect to pay to replace it and should I as a n00b attempt what seems like a difficult job (pretty sure the cv axle has to be moved out of the way to take out the pan..)?? Anyway thanks in advance.
mmoore9323 is offline
post #2 of 11 (permalink) Old 03-25-2019, 11:49 PM
MazdaMetalhead's Avatar
Quoted: 157 Post(s)
Welcome! Always good to see another wagon join up. I haven't experienced this particular problem but I'm sure someone else can offer guidance.
Manual transmissions, wagons, and heavy metal are awesome. Zoom-Zoom \m/
2004 Mazda 6s Wagon - 3.0L V6 | 5MT | Steel Gray Metallic |
Mods: 2015 OEM 17" 6 rims | NGK Iridium IX plugs | Matte black painted OEM wheels (winters) | Red painted calipers | Light black "smoked" headlights | R1 Concepts eLine rear rotors and pads | Rear V6 emblem added
Other Mazdas owned: 2015 Mazda 5 Sport ATX (current), 2010 Mazda 6 ATX (traded), 1997 Protege MTX (sold)
MazdaMetalhead is offline
The Following User Says Thank You to MazdaMetalhead For This Useful Post:
mmoore9323 (03-26-2019)
post #3 of 11 (permalink) Old 03-26-2019, 12:32 AM
waughoo's Avatar
Quoted: 422 Post(s)
Welcome to the forum. There is a dedicated group of us on here with wagons. Glad to have another amongst the ranks!
The pan should not be too terribly hard to do, but it does require a clean place to work as you are opening up the crank case. If you've done any wrenching before, it should not be that big of a deal to do.
Alex
, and
waughoo is offline
The Following User Says Thank You to waughoo For This Useful Post:
post #4 of 11 (permalink) Old 03-26-2019, 09:17 PM Thread Starter
mmoore9323's Avatar
Quoted: 9 Post(s)
Smile
hey man thanks for the welcome Just got back from the dealership and for the whole shebang it's probably going to cost me around $500. The gasket itself is about $50. So now I just have to think it over because the leak is pretty small all things considered. anyway i probably was hasty with this thread anyway. Will definitely lurk a bit to see whats going on here.
post #5 of 11 (permalink) Old 03-26-2019, 09:34 PM Thread Starter
mmoore9323's Avatar
Quoted: 9 Post(s)
i have not worked on cars much honestly, but i work as a pipe/hvac mechanic for a contractor so i'm not totally green. i was mostly worried about removing and putting the cv axle back, seems like a bit of work.
I love my wagon it's an '05 V6 i'll put some pics up soon. also--maybe you can answer a burning question. i bought this used and the trans fluid is kind of dark. do you think i should change it? it's not completely black, but i've been put off by a few people saying it's a bad idea. anyway man thanks for the reply
post #6 of 11 (permalink) Old 03-27-2019, 01:17 AM
waughoo's Avatar
Quoted: 422 Post(s)
I love my wagon it's an '05 V6 i'll put some pics up soon. also--maybe you can answer a burning question. i bought this used and the trans fluid is kind of dark. do you think i should change it? it's not completely black, but i've been put off by a few people saying it's a bad idea. anyway man thanks for the reply <img src="http://forum.mazda6club.com/images/smilies/5.gif" border="0" alt="" title="" class="inlineimg" />
We look forward to seeing it!! Search for the wagon love thread. We have been trying to gather as many photos of the long tops all consolidated in one place as we can.
As for the trans fluid, @DrFeelGood is who I'd recommend weigh in here on your question. He will steer you right.
Alex
, and
waughoo is offline
mmoore9323 (03-27-2019)
post #7 of 11 (permalink) Old 03-27-2019, 01:05 PM
Quoted: 432 Post(s)
hello there, and welcome to the Forum. I drive a 5-speed automatic transmission and based on my experience keeping clean fluid is a pretty good idea. When I got my car, it had a fairly pronounced shift shock when going into 3rd gear. I decided to drain the transmission fluid and refill with Mobil 1 ATF MV synthetic. After refilling, I put the car in drive with the engine running and left it there for a minute then put it in reverse left it there for a minute back in Drive left it there for a minute. I would then drain the fluid, refill with the appropriate amount, and repeat the procedure. I did this for a total of 3x using about 10 quarts of fluid total. It should be noted that the engine and transmission were thoroughly heat soaked before beginning this process. my 3rd gear hard shift went away and has stayed away for the 60000 miles since. Every 30000 miles I do one drain and refill. I currently have 180,000 miles.
Mozz-D
DrFeelGood is offline
post #8 of 11 (permalink) Old 03-27-2019, 08:34 PM Thread Starter
mmoore9323's Avatar
Quoted: 9 Post(s)
Very good to hear something straightforward. There are a lot of old wives tales about this. I can't feel any sluggishness or slipperyness in the transmission, i just checked the fluid and it looked a little dark. I think I will use the method you described. Thanks for helping me out with this. Could you let me know what "heat soaked" mean in this context?
I will definitely find the thread. I can't keep it looking clean since every day it ends up completely covered in tree pollen wtf
post #9 of 11 (permalink) Old 03-27-2019, 08:50 PM
Quoted: 432 Post(s)
It means thoroughly heated through. Not just until the gauge reads warm. I only say it so the fluid runs thin even when you replace it with room temp new.
Double check your fluid type. The 5-speed uses MV (multi vehicle) and the 6-speed uses T-IV. Check the dipstick or owners manual. Clean healthy fluid is your best insurance against trans failure.
Can't wait to see it.
Mozz-D
post #10 of 11 (permalink) Old 03-27-2019, 11:33 PM
waughoo's Avatar
Quoted: 422 Post(s)
I have the same problem at my house... we have a lot of evergreen trees on and around our lot. I looked out the window the other day and the otherwise clear day had turned foggy yellow!!?!??! I had washed the car the day before and it now looked like I'd driven down a dry river bead for a few miles. Crazy!
Alex
, and
waughoo is offline
