New speed 6 owner !! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 8 (permalink) Old 02-03-2019, 11:52 AM Thread Starter
Hello guys I stumbled on this site and was happy to see all the information , I recently picked up an 06 2.3 turbo awd, unfortunately the motor sounds bad , haven’t really looked into it but it sounds worse than a timing chain or lifters , not quite a knock so I believe it’s top end , I’ve seen a lot of n/a guys swapping in the 2.5 but I haven’t found a decent answer if the 2.5 will swap into mine , I expect I’ll need a tune (I’m sure this info on that here) , I already have a 10 or 12 2.5 from a fusion , but being I’m turbo will it work ? I’m not looking for hp gains at the moment , I just want it to run and drive thanks for any help !!
12feltonz is offline
post #2 of 8 (permalink) Old 02-03-2019, 01:22 PM
Quoted: 363 Post(s)
Hello, welcome to the forum. If you are not sure what the problem is, the dealer could do a diagnostic for a bit of cash. You may just need a new top end and timing components, maybe less. A low mileage used or re-manufactured long block can be had for around $3000 and that should definitely get you going for a little bit.
A quick search (I recommend it) shows:
https://forum.mazda6club.com/2-5l-i-...rbo-2-5-a.html
https://forum.mazda6club.com/2-5l-i-...ompatible.html
Good Luck. Let us know how it turns out.
Modifications:
.MSP brakes &
slotted rotors
DrFeelGood is offline
post #3 of 8 (permalink) Old 02-03-2019, 01:59 PM
waughoo's Avatar
Quoted: 347 Post(s)
Welcome to the forum. The stock block that isn't from a speed 6 would not be my first choice. Being a turbo engine, there are sometimes differences between the blocks. That said, I am not a speed expert by any means. I do know that the variable valve timing solenoid needs regular service or replacement and when not done, can have serious effects on the engine internals. I think I would start by pulling the engine and removing the head to see what you see. You could also try pulling spark plugs and checking with a horoscope for valve strikes. Just a couple ideas.
Alex
, and
waughoo is online now
post #4 of 8 (permalink) Old 02-03-2019, 02:09 PM Thread Starter
Thanks for the info , I’m probably going to pull the motor for further inspection , I have a bit of experience with engines but not too much with turbos , that being said I’m hoping at least for now the 2.5 will work , but it’s possile that it may not run too much to rebuild mine , guess we’ll see what surprises await lol
post #5 of 8 (permalink) Old 02-04-2019, 05:55 PM
fernando8877's Avatar
Welcome to the club!
2014 Mazda 6 Touring....it's ALL stock (for now).
fernando8877 is offline
post #6 of 8 (permalink) Old 02-04-2019, 08:04 PM
GerryB's Avatar
Quoted: 332 Post(s)
Welcome aboard.
GerryB is offline
post #7 of 8 (permalink) Old 02-05-2019, 09:09 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2782 Post(s)
^^ Those guys have got you covered
Welcome to the forum!
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #8 of 8 (permalink) Old 02-07-2019, 10:13 PM
Rockinbluesron's Avatar
Quoted: 16 Post(s)
Welcome aboard!
Some wise advice here.
Keep us posted!
Blue Lapis, Motegi Racing MR-119 Satin Black Rally Cross S, Dunlop Sport Maxx 225/40/18, Tein Lowering Springs, Tanabe Sustec Strut Tower Bar & Under Brace, Max Drilled Slotted Discs, Max HP Pads, Painted Calipers, Spectre SRI Intake, MagnaFlow Cat-back Dual Exhaust, DDM HID Kit Slim Ballast 6000K 55W for Hi and Lo Beams, Isolation Relays, JDM Window Visors, Tint all around, Custom Engine Cover, Sylflex Aux In Mod, Stage 1 Exedy Clutch, Flywheel,
Rockinbluesron is offline
Similar Threads
can you a swap 5 speed atx with a 6 speed atx? waltertek Mazda6 (Atenza) 4 09-25-2017 09:54 PM
Price Drop Mazda Speed 6 24,000 CAD OBO Vancouver Ryan Cole Cars 0 07-26-2009 08:42 AM
New Speed 6 owner magellan Newbie Section 3 04-04-2007 02:17 AM
Automatic Climate Control on 06 Mazda 6 generalinq Mazda6 (Atenza) 24 04-29-2006 08:36 PM
For those that have / had a regular 6 b4 getting the SPEED TRiPLE 6 Mazdaspeed6 44 03-22-2006 12:27 AM
