2009 headlights - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 4 (permalink) Old 01-25-2019, 02:01 AM Thread Starter
2009 headlights
I have a 2009 Mazda 6 and need to replace headlight assembly. There is significant cost difference between 2009-2010 and 2011-2013 headlights but they look identical. Can I purchase cheaper 2011 headlight assembly and install in my 2009? The cost difference is $200.
Ben Zermeno is offline
post #2 of 4 (permalink) Old 01-25-2019, 05:01 AM
Mz6GreyGhost's Avatar
Quoted: 833 Post(s)
Groaned at 6 Times in 3 Posts
Make sure that you're getting the correct headlamps first, depending on the type of bulbs used. The headlamps used for halogen bulbs are different from the versions for HID/xenon bulbs, and may also be the reason for the price difference as well.
If they are the correct versions, then I'm 95% sure you can use a 2011-2013 in place of the 2009-2010. I've never tried that for myself, but the design and mounting points are identical IIRC...
Mz6GreyGhost is online now
post #3 of 4 (permalink) Old 01-25-2019, 10:39 AM
jman1200's Avatar
Quoted: 86 Post(s)
The Mazda6 enters 2011 with a slightly different headlight and foglight design, along with a new 17-inch alloy wheel design. Also, upper trims (Touring Plus and Grand Touring) get new side folding mirrors with integral turn signals.
Source
Most likely they'll fit but be aware there are differences.
jman1200 is offline
post #4 of 4 (permalink) Old 03-14-2019, 08:24 AM
Hi,,not to hijack,im new here and cant figure out how to post a question regarding 2010 mazda 6 issue with headlights when trying to adjust the low beams with phillips and spinning the wheel i noticed the ptojector housing seems loose, can move it up and down by hand,) did i mess it up by turning adjustment whheel to far? Im at a loss. I had recently put in led's so anywau going through wheel well i felt the projector tilt forward so i put hand on it and cokld move up and down. Probably ruined it. Sny ideas?
Mrhappypantz is offline
