2017 Mazda 6 Touring Tire Size - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 5 (permalink) Old 01-22-2019, 04:20 PM Thread Starter
Question 2017 Mazda 6 Touring Tire Size
Which alternate size is good fit for 2017 Mazda 6 touring model??
Is P245/45 R19 tire size good??
umg1989 is offline
post #2 of 5 (permalink) Old 01-22-2019, 05:22 PM
Quoted: 13 Post(s)
That size will fit no problem assuming you are on the stock wheel and stock suspension. It is about as wide as you can go on a stock 7.5" wheel. Keep in mind in addition to being wider, it will be a taller tire also and will throw off your speedometer reading.
keenyia is offline
post #3 of 5 (permalink) Old 01-23-2019, 12:39 AM
threedeuces's Avatar
Quoted: 13 Post(s)
On a 7.5" wide wheel I think max recommended is a 235/45. The 245/45 from most tire manufacturers calls for a minimum of an 8" wide wheel.
2018 Mazda6 GTR - Blue Reflex Mica, A6 - Parchment - Bone Stock
2018 Honda Accord Sport 2.0T - Lunar Silver, A10 - Bone Stock
2005 Pontiac GTO - Cyclone Gray, M6 - 19" VMR V803s; Chrome lug nuts; EE Catch Can; Revenge Designs Spoiler; JBA shorties; Tuned by Advanced Dyno; GMM Street
1965 Pontiac GTO - 439CI Poncho (440 hp/510 tq), 3 2bbl carbs (Tripower!), M4, Pro-Touring treatment (13"/12" brakes, fast ratio PS, tubular control arms, Global West suspension, etc.), 18" AR TT2 Classic wheels
threedeuces is offline
post #4 of 5 (permalink) Old 01-23-2019, 01:26 PM Thread Starter
Thank you for the quick responses.
OKay. So, ABS and Speedometer is depend on tire's outer diameter. If I put 245/45 tire, it will affect traction control & ABS performance??
Okay. I have to check that one. But 235/45 size tire is for Crossovers/SUVs, not for sedans.
umg1989 is offline
post #5 of 5 (permalink) Old 01-23-2019, 11:32 PM
Quoted: 13 Post(s)
I agree that 235 would be a better fitment. However, there isn't an industry standard as far as I know yet like the DOT or RMA that regulate this. My information does show that 245/45 would be a proper fitment for 7.5-9" wheels. I can say that this may depend on where or who you shop with. i.e. people who stretch tires for a living may not care for this safety issue.
If you look at just the facts and numbers, yes it will affect traction control and abs. Those two features are dependent on the sensors the measure the tires speed; so looking at that data, it will. However, I do have 245/35/20x8.5 on my vehicle which changes up the actual size and width with no issue either. There is a tolerance to this within a percentage, but it varies by manufacture.
https://tiresize.com/calculator/
Tiresize does have a good calculator to give you more info and data on the speedometer changes.
keenyia is offline
