Rusty subframe on 5speed 3.0 by, please help! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 2 (permalink) Old 01-08-2019, 07:06 PM Thread Starter
I have a 2006 mazda6 5speed 3.0L v6 with around 85k miles. Good buy, problem is that the frame is rotted out and I'm in dire need of a new one. Can anyone help me out, I'm in Ohio, thank you.
Andersinthe6 is offline
post #2 of 2 (permalink) Old 01-08-2019, 07:40 PM
bluedevil6's Avatar
Quoted: 204 Post(s)
Iím in Ohio too just outside Canton, I have the same problem mine is rotting above the exhaust to the right side. I am probably going to be replacing it with a scrapyard one, you should check pull a part if you are going to do the work yourself if not then try some other scrapyards that will pull it for you. I have already looked on eBay and could not find anything under $200. As for the replacement if you have the right tools it seems like a straight forward job just tedious because of things like hoses and the steering rack and suspension parts.
2007 6 Hatch 3.0 V6 ATX
Places to find me-
bluedevil6 is offline
