Battery problem Mazda 6 2015 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 4 (permalink) Old 01-02-2019, 10:24 AM Thread Starter
Unhappy Battery problem Mazda 6 2015
My Mazda 6 Grand Touring 2015, purchased in July 2014 is suddenly showing a warning "Battery Management System Inspection" warning. This Mazda does have the e-loop system which means a special battery must be used as a replacement, cost over $500!
Seems like Mazda should have warned buyers of this expensive replacement battery & that the original battery will last less then 5 years. Not happy at all with the performance of this battery. My last original battery with my other car, a Toyota last over 10 years and the replacement cost was less than $100
Will Mazda do anything about this problem. Do the new Mazda cars have this e-loop (I-Loop) system. If so, I would not be inclined to purchased another Mazda
TShelley is offline
post #2 of 4 (permalink) Old 01-02-2019, 02:13 PM
Archerfish's Avatar
Quoted: 86 Post(s)
I have read an article about reviving a dead battery by using Epsom salt. You might want to give it a try.
I don't have this feature but instead, what I have is i-Stop. I seldom use it and its almost automatic for me to turn it OFF whenever I drive. I've heard that it's possible to use an ordinary battery. However, i-Stop won't work.
Archerfish is offline
post #3 of 4 (permalink) Old 01-02-2019, 04:14 PM
Quoted: 6 Post(s)
Send a message via AIM to zrxsteve62 Send a message via Skype™ to zrxsteve62
I have read on this forum that it is possible to use any AGM battery of similar capacity that will fit the dimensions. I have heard it both ways though. One says you need the e-Loop battery because it has some special circuitry, the other group says that an AGM battery will work and have pictures of the batteries in their car. The advantage is that the AGM battery would be much less expensive. The marketing information about e-Loop says that it delivers ~ 2 mpg better gas mileage. I drive 17K miles per year. If I average 30 mpg with e-loop I purchase 566.6 gallons of gas per year. If I get 28 without E-Loop I purchase 607.14 gallons of gas per year. The delta is 40.54 gallons so at $2 a gallon I save about $80.00, $3 a gallon = $120. Who knows if it really saves that much. Just trying to help take a bit of the sting out of it, particularly if it is possible to get a much cheaper AGM battery.
I have seen posts on this site that says you have to use the Mazda E-Loop battery (called Q85) because it contains the high amp capacitor, but this is incorrect. I found a Mazda post that details the technology and the battery and the capacitor are separate.
That would tend to make me think an AGM battery would work. I also found posts for other car mfg's with engine stop/start technology that use a secondary and expensive battery like Mazda does for E-Loop, and it sounds like people are substituting AGM for them as well.
Steve
2017 Snowflake White Mazda 6 Grand Touring GT Premium Package.
zrxsteve62 is offline
post #4 of 4 (permalink) Old 01-03-2019, 10:00 AM
tickerguy's Avatar
Quoted: 876 Post(s)
Groaned at 7 Times in 7 Posts
It's just an AGM battery. The distinction is that AGM can take very high-rate charge and discharges without being damaged; a flooded battery CANNOT.
Find one that fits and has the correct terminal configuration and install it. Screw Mazda and their crazy markup -- an AGM battery will run you $200 or so. It's 12V and the capacitor is separate, so there you go.
BTW AGMs don't have materially longer service life - 3 years isn't terrible for a car battery. I replaced mine already in my 2015, but it's a Sport (the factory one was a Panasonic) and no, I didn't go to the stealer for it....
tickerguy is offline
