Digital Display - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 4 (permalink) Old 12-10-2018, 12:33 PM Thread Starter
Digital Display
I have a 2005 Mazda 6 S Sedan with Bose audio system. My display unit that shows the temp/radio stations/airflow images is not working. Is there anyway to find out if it is a 10 or 16 pin unit without pulling it out? The unit is a 3 button unit with the non-active 4th button spot.
kruzntaco is offline
post #2 of 4 (permalink) Old 12-10-2018, 10:34 PM
I guess itís your fuse, check the fuse under your dashboard area at the drivers side. Thereís a fuse thatís burnt just check for the exact and change. I had similar problem last week but itís all fine now
blackrazor is offline
post #3 of 4 (permalink) Old 12-11-2018, 03:26 PM Thread Starter
Thanks, I've tried that and the fuse is fine. I am pretty sure the unit is bad. I'm just trying to figure out how to order the correct replacement. From what I can tell, it could be 1 of 3 different models. Mazda dealership couldn't tell me without tearing it out either.
Worst case, I'll just pull it out eventually. I'm just trying to avoid messing with the console more than once.
post #4 of 4 (permalink) Old 12-11-2018, 03:28 PM
Okay you should also... Iím dealing with acceleration issue myself
