At wits end. 08 Mazda6. Right turn signal activates Hazzards - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 5 (permalink) Old 12-05-2018, 11:15 AM Thread Starter
Hello All, new guy here.
I just paid off my 08 Mazda 6 a few months ago, and got brand new tires a week ago. Wouldn't you know it, yesterday I started having problems. For some reason, every time I activate my right turn signal, my hazards come on. My left signal works fine. I disconnected the common ground block just below my engine bay fuse box, and it did seem a little corroded, so i cleaned it with CRC electronics cleaner, and used a wire brush to clean the tab that is used to attach it to the frame. Still have the same problem. Everything else seems to be working fine, except my auto portion of my drivers side window button doesnt work (where you push it down once and it rolls all the way down on its own), but it does roll up and down fine while holding the switch up/down.
While the turn signal/hazard light issue is mostly consistent, it does seem to correct every once in a while and work fine (say, every 25th time using the signal, it will work fine, the other 24 times it turns on my hazards).
Any Ideas?
sixstringhook is offline
post #2 of 5 (permalink) Old 12-05-2018, 01:28 PM
Trippp's Avatar
Quoted: 153 Post(s)
Throwing this out there... Maybe it’s the steering column switch, possibly a short is activating left and right signals together?
'18 Machine Gray GT Reserve
Trippp is online now
post #3 of 5 (permalink) Old 12-05-2018, 03:39 PM Thread Starter
I did think about that, and I tried spraying CRC electronics cleaner down in, but I have not yet pulled it out to check it.
post #4 of 5 (permalink) Old 12-06-2018, 11:04 AM Thread Starter
Well, last night was kind of a whirlwind of issues. When I left work, twice on my way home the car just died. I was able to put it in neutral and start it again without issue though. When I got home, I pulled the air cleaner box out to get better access to wiring. I pulled the common ground block and cleaned again, and put the ground leads into vinegar to clean of oxidation and cleaned with CRC again. still no luck. I opened my steering column and pulled the control arm out and cleaned it out, still having the same problem. I also pulled the turn signal bulb assembly and checked it out. the contacts seemed a little dirty, so i cleaned those, and there is no sign that the bulb is bad (both of the fillaments are in place).
post #5 of 5 (permalink) Old 12-06-2018, 02:58 PM Thread Starter
well, i decided to go ahead and buy a BCM. Bought a used one, we will see how that works. After doing some research, apparently the 2008 mazda 6 is prone to water leaking via the hood release lever cable, and drips right down on to the BCM. It kind of fits because 2 weeks ago it was raining pretty heavily where I am and i felt water dripping on to my left leg right under the BCM. Hope this fixes it.
