Driver side Low Beam wiring issue - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 3 (permalink) Old 10-21-2018, 08:47 AM Thread Starter
Need help with 2010 Mazda 6 driver side low beam headlight not working.
Replaced bulb, but not the issue. Looks like I lost the ground from the bulb (Blk/Gr) wire. Wiring is a birds nest under the fuse panel box and very difficult to move around once removed to trace wires.
Can anyone supply a 2010 Mazda 6 headlight wiring diagram? All the ones I can find have High and Low beam as 10A fused and what I have is 15A for high and 10A for low beam (one bulb, 2 fuses/bulb).
I tried to jump the ground from back of the bulb socket and then only the High beam goes on when I turn on the lights and nothing changes when I turn on the High beam switch.
The right wiring schematic would really help before I bite the bullet and get someone else to diagnose and repair.....
diano is offline
post #2 of 3 (permalink) Old 10-26-2018, 06:32 AM Thread Starter
See pics
diano is offline
post #3 of 3 (permalink) Old 10-26-2018, 09:35 AM
jman1200's Avatar
Quoted: 82 Post(s)
A had a similar situation with my SHO a few moths back. Did you move any relays around when troubleshooting?
I learned that although some relays looked the same, some had an extra pin which was used to share ground to other circuits. All worked fine after I placed the relays back to their original location, I had been using the horn relay to test the headlight circuits and never put them back in the same order.
jman1200 is offline
