High cost of maintenece/repair for Mazda 6? - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
 6Likes
post #21 of 32 (permalink) Old 01-08-2019, 11:15 AM
bluedevil6's Avatar
Quoted: 116 Post(s)
Originally Posted by GohanX View Post
nobody bothered to service them since it's not supposed to need service "for life."
This exactly, when I'm car shopping I don't know how many conversations go as follows
Person- "everything works great but reverse (or another gear) doesn't work"
Me- "when was the last time the transmission fluid was changed?"
Person- "Transmission fluid? I didn't think you had to change that."
Me- "How many miles did you say were on the car?"
Person- "170,000(or some other astronomical amount)"
Me- (usually in my own head, but it has actually come out before) " Do we see them problem here yet?!?"
2007 6 Hatch 3.0 V6 ATX
Still Want lowering springs, sway bars, subframe brace, strut tower brace
Places to find me-
bluedevil6 is online now
post #22 of 32 (permalink) Old 01-08-2019, 11:45 AM
idrive's Avatar
Quoted: 249 Post(s)
Groans: 6
Did the 1st and 2nd Gen's claim to be "life time" tranny fluid as the Gen 3 does?
Build Thread:
idrive is offline
post #23 of 32 (permalink) Old 01-08-2019, 12:04 PM
bluedevil6's Avatar
Quoted: 116 Post(s)
I donít know about the 2nd gen but the 1st gen didnít necessarily say it was lifetime but the owners manual and even the fsm as far as I know donít have a listed service interval
Kalalicious likes this.
Places to find me-
post #24 of 32 (permalink) Old 01-08-2019, 01:03 PM
Quoted: 24 Post(s)
2015....with 96K.
I haven't even changed the plugs yet.
The Dunlops made it to 35K and the Continentals are still going strong.
I have had to replace the rotors and pads twice.
I wished Mazda had gone with at least a 2 piston caliper.
Other than that just gas and oil.
I have an inquire to Akebono to see if they have any multi piston calipers that will just bolt on.
Next car is probably going to be a CX-5. This is my 3rd Mazda....had a B2600 4x4 too.
RedBluff is offline
post #25 of 32 (permalink) Old 01-08-2019, 01:09 PM
Quoted: 4 Post(s)
Originally Posted by bluedevil6 View Post
I donít know about the 2nd gen but the 1st gen didnít necessary say it was lifetime but the owners manual and even the fsm as far as I know donít have a listed service interval
Yeah, when I picked up my 2006 6s a few months ago I started planning all the maintenance that should be done at around the 100k mark (it only had 107k ), and found the same lack of information on the ATX fluid in the user manual and the shop manual.
I figured that was crazy and looked around on here and found most everyone recommended changing it, or at least starting the process of dumping and adding, if not earlier, then at least at 100k. So I picked up some appropriate ATX fluid and plan on doing that as soon as I get around to making my car ramps. I'll also be adding a tranny cooler and inline filter at the same time.
Tungsten Gray 2006 Mazda 6s Grand Touring - Finally another 1st Gen 6 to play with! New-to-me Oct 2018 with 107K miles!
Performance White 2003 6i Sport - dead, after 240K miles
Kalalicious is offline
post #26 of 32 (permalink) Old 01-08-2019, 01:13 PM
bluedevil6's Avatar
Quoted: 116 Post(s)
I would caution you against the in-line filter, I used a Magnifine one and found that it significantly restricted the fluid flow. Iím jealous of your mileage lol Iím at 161,650 but still no major mechanical issues
Places to find me-
The Following User Says Thank You to bluedevil6 For This Useful Post:
Kalalicious (01-09-2019)
post #27 of 32 (permalink) Old 01-09-2019, 10:49 AM
tickerguy's Avatar
Quoted: 843 Post(s)
Groaned at 7 Times in 7 Posts
I don't think they ever think about life past 100k miles, which is right around the point you should change the transmission fluid. When I was shopping for cheap early 2000's cars last year it was really common for otherwise reliable cars to have automatic transmission issues. Honda, Mazda, didn't matter. I wonder if it's because the transmissions themselves are bad it if nobody bothered to service them since it's not supposed to need service "for life."
ALL ATXes are intentionally designed in a fashion that encourages and eventually will lead to failures.
All.
Specifically the wetted area of the transmission contains friction materials (in the clutches) that inherently shed into the fluid. This is like putting brake dust in your motor oil and over time has the same sort of result.
In addition the filter is a joke compared with even full-flow (say much less bypass design) motor oil filters and is intentionally inside the case, making easy changes impossible. Would you tolerate having to drop the oil pan to change the engine oil filter? Well?
Third, they're designed (on purpose) so that draining (and thus changing) the entire fluid load is nearly impossible. Specifically, the torque converter is designed in such a fashion that it cannot be drained nor does it drain back automatically when the car is shut down and it holds a LOT of fluid. Would you tolerate an engine design that only allowed you to change 1/2 or so of the engine oil, forcing you to leave the other half of the dirty oil in the engine? Well?
And you wonder why they fail? They're designed to fail once you get into the six-digit mileage category, and avoiding those failures is difficult at best.
It's much like passenger diesel DPFs which are (1) non-separable from the cat so you can't remove and clean them -- heavy truck units, on the other hand, are SEPARATE (for this exactly reason) and (2) three to five times as expensive as they should be due to integration with the cat, which does NOT typically wear out yet MUST be replaced when the DPF wears out. That too is an intentional design decision which is why I will never own a modern-emissions diesel passenger vehicle.
tickerguy is online now
post #28 of 32 (permalink) Old 01-09-2019, 01:15 PM
Quoted: 4 Post(s)
I know, the mileage is quite nice! Perfect time for catching a bunch of maintenance items before they become/cause bigger issues!
Thanks for the warning on the in-line filter. That does sound like something to be aware of. I'll be sure to do more research on that particular topic to see if there's something that will work or if it's simply best to avoid. Thanks!
post #29 of 32 (permalink) Old 01-09-2019, 02:44 PM
tickerguy's Avatar
Quoted: 843 Post(s)
If you're going to do an external filter for the transmission make it a bypass filter -- this way you do not restrict flow AND you get superior (depth-based) filtration at the same time.
post #30 of 32 (permalink) Old 01-10-2019, 03:20 AM
Quoted: 94 Post(s)
See this discussion, post 7: https://forum.mazda6club.com/3rd-gen...e-service.html
And see this one, post 11: 100k mile service? https://forum.mazda6club.com/3rd-gen/434266-100k-mile-service.html
Cdn17Sport6MT
Vancouver, BC Canada
Cdn17Sport6MT is online now
