2004 Mazda 6 3.0 rebuilt engine install - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Administrator, AG Jeff, AldoWest, b1lk1, Byakuya, DragginFrame, Insane, jmhinkle, kpjimmy, Mazda Gremlyn, MrTea, Mz6GreyGhost, Shanook, SubscriptionSupport, Young6er
post #1 of 5 (permalink) Old 04-26-2018, 08:41 AM Thread Starter
Exclamation 2004 Mazda 6 3.0 rebuilt engine install
Hello to all,
My mazda 6 had 186,000 miles on it when the engine was ready for rebuild. I then installed the engine with a new stage 1 clutch, new starter and battery. Fast forward, I'm ready for first start and all I get is crank but no start. I hooked the battery charger to it and it picked up a bit but not enough to start the motor. Is it something I'm missing? a ECU issue I'm not aware of? I've heard a rumor that when there's a rebuild or new motor going in. the car has to go to the dealer to clear a code before the motor will turn over....Is there any truth to this or is it just purely fiction, please help!!
guapogordo is offline
post #2 of 5 (permalink) Old 04-26-2018, 09:12 AM
b1lk1's Avatar
Quoted: 312 Post(s)
Groans: 20
No, there is no need for the dealer to do anything after an engine install.
Carefully go over the wiring, especially the grounds. Make sure the fuel pump is kicking on and such.
b1lk1 is offline
post #3 of 5 (permalink) Old 04-26-2018, 09:23 AM Thread Starter
ok, I cleaned the ground connection going to the back of the transmission, is that the block ground? there is also another ground on the front of the transmission. Any other grounds I may be missing?? the fuel pump is working, I took out a spark plug and basically ruled that out
post #4 of 5 (permalink) Old 04-26-2018, 10:57 AM
Shiro Shinobi
Byakuya's Avatar
Quoted: 2895 Post(s)
1) Holy tagged userlist to this thread.... Only maybe 3 people on there still visit this forum on a regular basis.
2) Sorry to hear your rebuild isn't working 100% yet.
3) b1lk1 is absolutely correct.
4) Create an account and use this 'holy grail' of information to check over everything: 6Crew.com
Current:
, Sold:
, 3rd Generation
Need a Part Number? Find it
Byakuya is offline
post #5 of 5 (permalink) Old 04-27-2018, 09:43 AM Thread Starter
yes, last night I was checking over the wiring and (basic power and ground checks) and it lead me to the fuse box. when I run a voltmeter across the terminals (across the main fuse) going to the fuse box I get nothing. the fuse box is hard lined to the battery, I am supposed to read battery voltage across those terminals correct??
