Low beam head lights not working - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
post #1 of 16 (permalink) Old 04-13-2010, 09:11 PM Thread Starter
I have a 2006 Mazda 6, went to leave for work yesterday morning & my low beam head lights didn't come on. The high beams works, as well as all other lights on the car. Changed the head lights & checked all fuses, seem to be good. I have no clue what the problem can be. Can anyone help me with this? I'd rather not have to take it to the dealership & pay $75 an hour if I can help it.
MJM6 is offline
post #2 of 16 (permalink) Old 04-14-2010, 08:05 AM
mwalker46's Avatar
every bulb has a ground wire on it, check to see if you have any loose wires that connect to the low beam, it'll be its owe seprate wire
mwalker46 is offline
post #3 of 16 (permalink) Old 04-14-2010, 11:12 AM Thread Starter
Thank you, I'll try that. I was also told that I could only replace the head light bulbs with factory bulbs I had to purchase at the Mazda dealership, that because I replaced the bulbs with ones I purchased from AutoZone, that is the reason they are not working. I'm not sure if I believe since, the owners manual also states they have to be replaced at the dealership, due to the complexity of it, I'm a woman and figured it out, thanks to directions I found on here. Feel they are just trying to get money out of me.
MJM6 is offline
post #4 of 16 (permalink) Old 04-14-2010, 11:40 AM
TalonTsi90's Avatar
Quoted: 92 Post(s)
Groans: 5
Groaned at 7 Times in 7 Posts
Well, do you have the HID or Xenon's? Makes a big difference. If you have regular Xenon's, i highly recommend Sylvania Silver Stars. Much worth the $40/pair price tag.
2006 6 Hatch Grand Touring 5spd Sunroof
TalonTsi90 is offline
post #5 of 16 (permalink) Old 04-14-2010, 12:26 PM Thread Starter
Question is do I have to purchase the bulbs from Mazda directly? I was told they are still not working because I replaced them with bulbs I purchased from AutoZone. I don't see where I purchased them from making a difference & that being the reason they are not working.
MJM6 is offline
post #6 of 16 (permalink) Old 04-14-2010, 12:29 PM
Quoted: 11 Post(s)
it doesnt. dealerships just want to make money.
2009 Mazda 6 - Performance White V6
Ankit69 is offline
post #7 of 16 (permalink) Old 04-14-2010, 12:33 PM
TalonTsi90's Avatar
Quoted: 92 Post(s)
Groans: 5
In this instance, Stealership is a more appropriate name
But, no, you dont HAVE to buy them there, unless NO ONE else has them. Which, in this case, is not true.
post #8 of 16 (permalink) Old 04-14-2010, 12:46 PM Thread Starter
That's what I thought also. Thank you. Do you know how to change the headlight switch? I can't seem to find directions on that anywhere
MJM6 is offline
post #9 of 16 (permalink) Old 04-14-2010, 12:56 PM
TalonTsi90's Avatar
Quoted: 92 Post(s)
Groans: 5
Im not exactly sure, but im thinking youll have to pull the steering wheel. If not, at least take off the trim collar and go from there. One guy is selling the turn signal piece, maybe he can tell you how.
post #10 of 16 (permalink) Old 04-16-2010, 01:10 PM Thread Starter
I have fixed the problem, it was a loose wire. Thanks for all the advice
MJM6 is offline
